root/radiance/ray/src/common/process.c
Tue Oct 29 00:35:06 2024 UTC (9 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.12
refactor: Changed some calls to use const type for better C++ callability
Mon Jun 3 18:55:51 2024 UTC (14 months, 1 week ago) by greg
refactor: Changed buffer types in process(), readbuf(), writebuf()
Fri Jan 15 19:01:53 2021 UTC (4 years, 6 months ago) by greg
fix: more 64-bit fixes
Fri Apr 3 17:06:16 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.9: +1 -3 lines
Added input ray queue for more efficient batch processing
Fri Feb 28 05:18:49 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.8: +10 -10 lines
Fri Sep 17 21:43:49 2004 UTC (20 years, 10 months ago) by greg
Thu Jun 26 00:58:09 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.6: +25 -85 lines
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.4: +60 -4 lines
Fri Apr 16 10:26:45 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.3: +18 -4 lines
made readbuf() and writebuf() retry after interrupted system call
Thu Apr 1 11:08:05 1993 UTC (32 years, 4 months ago) by greg
fixed potential bug in readbuf() and writebuf() for zero requests
Thu Mar 19 09:32:02 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +1 -3 lines
added vfork.h include file
Tue Nov 12 16:56:02 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Tue Jul 23 15:56:57 1991 UTC (34 years ago) by greg
