root/radiance/ray/src/common/portio.c
Mon Jul 12 17:42:51 2021 UTC (2 years, 9 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.26 , to selected 2.3
perf: minor efficiency improvements
Fri Feb 19 18:00:29 2021 UTC (3 years, 2 months ago) by greg
Diff to previous 2.25 , to selected 2.3
fix: fix bug introduced in last change to putstr() for empty strings
Fri Feb 19 16:15:23 2021 UTC (3 years, 2 months ago) by greg
Changes since 2.24: +11 -8 lines
Diff to previous 2.24 , to selected 2.3
feat: added output stream error-checking to putstr(), putint(), and putflt()
Fri Feb 19 02:59:32 2021 UTC (3 years, 2 months ago) by greg
Changes since 2.23: +8 -2 lines
Diff to previous 2.23 , to selected 2.3
fix: added handling of writing longer long's that architecture supports
Fri Jan 15 18:31:38 2021 UTC (3 years, 3 months ago) by greg
Diff to previous 2.22 , to selected 2.3
More 64-bit addressing fixes
Mon Jul 15 21:27:25 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.21: +6 -5 lines
Diff to previous 2.21 , to selected 2.3
Reduced size limit for fread() & fwrite() again and other minor changes
Fri Jul 5 03:04:22 2019 UTC (4 years, 10 months ago) by greg
Diff to previous 2.20 , to selected 2.3
Added error checking to putbinary()
Thu Jul 4 02:06:32 2019 UTC (4 years, 10 months ago) by greg
Diff to previous 2.19 , to selected 2.3
Changed fread/fwrite call threshold to 256 bytes -- seemed more reasonable
Thu Aug 18 00:52:48 2016 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.18: +8 -6 lines
Diff to previous 2.18 , to selected 2.3
Tue Mar 15 13:57:09 2016 UTC (8 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 2.3
Minor optimization should not affect behavior
Thu Mar 3 22:09:59 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.16: +1 -8 lines
Diff to previous 2.16 , to selected 2.3
Moved putc and getc overrides to rtio.h
Thu Mar 3 22:06:18 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.15: +42 -1 lines
Diff to previous 2.15 , to selected 2.3
Added fread() and fwrite() replacements
Fri Oct 19 01:40:33 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.14: +31 -23 lines
Diff to previous 2.14 , to selected 2.3
Added check for EOF in getflt() and completed ANSIficiation
Sat Dec 23 17:27:45 2006 UTC (17 years, 4 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Changes since 2.13: +2 -4 lines
Diff to previous 2.13 , to selected 2.3
Tue May 3 05:10:13 2005 UTC (19 years ago) by greg
Changes since 2.12: +11 -2 lines
Diff to previous 2.12 , to selected 2.3
Added handling of overflow and underflow conditions in putflt()
Fri Feb 18 16:34:27 2005 UTC (19 years, 2 months ago) by greg
Changes since 2.11: +5 -1 lines
Diff to previous 2.11 , to selected 2.3
Made exact zero work for 5-byte floating point i/o
Tue Sep 14 02:53:50 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Added #undef for getc/putc where they were being replaced
Tue Dec 9 15:51:42 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.9: +6 -1 lines
Diff to previous 2.9 , to selected 2.3
Added redirection for getc() and putc() on threaded C library
Thu Nov 13 16:42:17 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.8: +2 -7 lines
Added <math.h> include to get frexp() and ldexp() declarations
Changes since 2.5: +63 -4 lines
Fri Nov 15 16:20:35 1996 UTC (27 years, 6 months ago) by greg
fixed bug caused by last change for negative values in getflt()
Fri Nov 15 16:17:05 1996 UTC (27 years, 6 months ago) by greg
minor improvement of getflt() accuracy (bug introduced 96/05/28
Fri Oct 2 16:09:57 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +7 -2 lines
Mon Sep 21 12:02:23 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.1: +4 -3 lines
Changes for PC port
Mon Jul 13 15:36:01 1992 UTC (31 years, 10 months ago) by greg
Diff to selected 2.3
