perf: minor efficiency improvements
fix: fix bug introduced in last change to putstr() for empty strings
feat: added output stream error-checking to putstr(), putint(), and putflt()
fix: added handling of writing longer long's that architecture supports
More 64-bit addressing fixes
Reduced size limit for fread() & fwrite() again and other minor changes
Added error checking to putbinary()
Changed fread/fwrite call threshold to 256 bytes -- seemed more reasonable
Minor optimization should not affect behavior
Moved putc and getc overrides to rtio.h
Added fread() and fwrite() replacements
Added check for EOF in getflt() and completed ANSIficiation
Added handling of overflow and underflow conditions in putflt()
Made exact zero work for 5-byte floating point i/o
Added #undef for getc/putc where they were being replaced
Added redirection for getc() and putc() on threaded C library
Added <math.h> include to get frexp() and ldexp() declarations
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug caused by last change for negative values in getflt()
minor improvement of getflt() accuracy (bug introduced 96/05/28
Changes for PC port
