| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* popen() and pclose() calls for systems without pipe facilities
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
#include <ctype.h>
| 13 |
#include "paths.h"
| 14 |
| 15 |
#ifndef NFILE
| 16 |
#define NFILE 32
| 17 |
#endif
| 18 |
| 19 |
static struct {
| 20 |
char *f; /* file name, NULL if inactive */
| 21 |
char *c; /* command if writing */
| 22 |
} pips[NFILE];
| 23 |
| 24 |
| 25 |
FILE *
| 26 |
popen(cmd, mode) /* open command for reading or writing */
| 27 |
register char *cmd;
| 28 |
char *mode;
| 29 |
| 30 |
extern FILE *fopen();
| 31 |
extern char *malloc(), *mktemp(), *strcpy();
| 32 |
static int fnum = 0;
| 33 |
FILE *fp;
| 34 |
char *newcmd, *fname;
| 35 |
register char *cp, *cp2 = NULL;
| 36 |
int quote = '\0', paren = 0;
| 37 |
| 38 |
fname = malloc(TEMPLEN+1);
| 39 |
newcmd = malloc(TEMPLEN+6+strlen(cmd));
| 40 |
if (fname == NULL | newcmd == NULL)
| 41 |
return(NULL);
| 42 |
mktemp(strcpy(fname,TEMPLATE));
| 43 |
/* build our command */
| 44 |
for (cp = newcmd; ; cmd++) {
| 45 |
switch (*cmd) {
| 46 |
case '\'':
| 47 |
case '"':
| 48 |
if (!quote)
| 49 |
quote = *cmd;
| 50 |
else if (quote == *cmd)
| 51 |
quote = '\0';
| 52 |
#ifdef MSDOS
| 53 |
else
| 54 |
break;
| 55 |
*cp++ = '"'; /* double quotes only */
| 56 |
continue;
| 57 |
#else
| 58 |
break;
| 59 |
#endif
| 60 |
#ifndef MSDOS
| 61 |
case '(':
| 62 |
if (!quote)
| 63 |
paren++;
| 64 |
break;
| 65 |
case ')':
| 66 |
if (!quote && paren)
| 67 |
paren--;
| 68 |
break;
| 69 |
case '\\':
| 70 |
if (!quote && cmd[1] == '\n') {
| 71 |
*cp++ = ' ';
| 72 |
cmd++;
| 73 |
continue;
| 74 |
| 75 |
*cp++ = *cmd++;
| 76 |
break;
| 77 |
#endif
| 78 |
case ' ':
| 79 |
case '\t':
| 80 |
if (!quote)
| 81 |
while (isspace(cmd[1]))
| 82 |
cmd++;
| 83 |
break;
| 84 |
case '|':
| 85 |
case ';':
| 86 |
if (!quote && !paren && cp2 == NULL)
| 87 |
cp2 = fname;
| 88 |
break;
| 89 |
case '\n':
| 90 |
case '\0':
| 91 |
if (cp2 == NULL)
| 92 |
cp2 = fname;
| 93 |
break;
| 94 |
| 95 |
if (cp2 == fname && *mode == 'w') { /* add input file */
| 96 |
*cp++ = ' '; *cp++ = '<'; *cp++ = ' ';
| 97 |
while (*cp2)
| 98 |
*cp++ = *cp2++;
| 99 |
*cp++ = ' ';
| 100 |
| 101 |
if (!(*cp = *cmd))
| 102 |
break;
| 103 |
cp++;
| 104 |
| 105 |
if (*mode == 'r') { /* add output file */
| 106 |
while (isspace(cp[-1]) || cp[-1] == ';')
| 107 |
cp--;
| 108 |
*cp++ = ' '; *cp++ = '>'; *cp++ = ' ';
| 109 |
while (*cp2)
| 110 |
*cp++ = *cp2++;
| 111 |
*cp = '\0';
| 112 |
system(newcmd); /* execute command first */
| 113 |
| 114 |
if ((fp = fopen(fname, mode)) == NULL) { /* open file */
| 115 |
free(fname);
| 116 |
free(newcmd);
| 117 |
return(NULL);
| 118 |
| 119 |
if (fileno(fp) >= NFILE) {
| 120 |
eputs("popen: too many open files\n");
| 121 |
quit(1);
| 122 |
| 123 |
pips[fileno(fp)].f = fname;
| 124 |
if (*mode == 'r') {
| 125 |
free(newcmd);
| 126 |
pips[fileno(fp)].c = NULL;
| 127 |
} else
| 128 |
pips[fileno(fp)].c = newcmd;
| 129 |
return(fp);
| 130 |
| 131 |
| 132 |
| 133 |
pclose(fp) /* close pipe and cleanup */
| 134 |
FILE *fp;
| 135 |
| 136 |
register int pn = fileno(fp);
| 137 |
| 138 |
if (pn >= NFILE || pips[pn].f == NULL || fclose(fp) == -1)
| 139 |
return(-1);
| 140 |
if (pips[pn].c != NULL) {
| 141 |
system(pips[pn].c); /* execute command last */
| 142 |
free(pips[pn].c);
| 143 |
| 144 |
unlink(pips[pn].f); /* remove temp file */
| 145 |
free(pips[pn].f);
| 146 |
pips[pn].f = NULL;
| 147 |
return(0);
| 148 |
