--- ray/src/common/popen.c 1992/09/08 09:08:02 2.1
+++ ray/src/common/popen.c 2003/02/22 02:07:22 2.5
@@ -1,14 +1,70 @@
-/* Copyright (c) 1992 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: popen.c,v 2.5 2003/02/22 02:07:22 greg Exp $";
#endif
* popen() and pclose() calls for systems without pipe facilities
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
+#include
#include
#include "paths.h"
@@ -27,29 +83,47 @@ popen(cmd, mode) /* open command for reading or writi
register char *cmd;
char *mode;
- extern FILE *fopen();
- extern char *malloc(), *mktemp(), *strcpy();
- static int fnum = 0;
FILE *fp;
char *newcmd, *fname;
register char *cp, *cp2 = NULL;
int quote = '\0', paren = 0;
- fname = malloc(TEMPLEN+1);
- newcmd = malloc(TEMPLEN+6+strlen(cmd));
+ while (isspace(*cmd))
+ cmd++;
+ if (!*cmd)
+ return(NULL);
+ fname = (char *)malloc(TEMPLEN+1);
+ newcmd = (char *)malloc(TEMPLEN+6+strlen(cmd));
if (fname == NULL | newcmd == NULL)
return(NULL);
mktemp(strcpy(fname,TEMPLATE));
/* build our command */
for (cp = newcmd; ; cmd++) {
switch (*cmd) {
- case '"':
case '\'':
+ case '"':
if (!quote)
quote = *cmd;
else if (quote == *cmd)
quote = '\0';
+#ifdef MSDOS
+ else
+ break;
+ *cp++ = '"'; /* double quotes only */
+ continue;
+ case '\\':
+ if (!quote && cmd[1] == '\n') {
+ *cp++ = ' ';
+ cmd++;
+ continue;
+ cmd++;
break;
+#else
+ break;
+ case '\\':
+ *cp++ = *cmd++;
+ break;
case '(':
if (!quote)
paren++;
@@ -58,19 +132,18 @@ char *mode;
if (!quote && paren)
paren--;
break;
- case '\\':
- if (!quote && cmd[1] == '\n') {
- *cp++ = ' ';
- cmd++;
- continue;
- *cp++ = *cmd++;
- break;
- case '|':
case ';':
+#endif
+ case '|':
if (!quote && !paren && cp2 == NULL)
cp2 = fname;
break;
+ case ' ':
+ case '\t':
+ if (!quote)
+ while (isspace(cmd[1]))
+ cmd++;
+ break;
case '\n':
case '\0':
if (cp2 == NULL)
@@ -78,7 +151,7 @@ char *mode;
break;
if (cp2 == fname && *mode == 'w') { /* add input file */
- *cp++ = ' '; *cp++ = '<'; *cp++ = ' ';
+ *cp++ = ' '; *cp++ = '<';
while (*cp2)
*cp++ = *cp2++;
*cp++ = ' ';
@@ -90,7 +163,7 @@ char *mode;
if (*mode == 'r') { /* add output file */
while (isspace(cp[-1]) || cp[-1] == ';')
cp--;
- *cp++ = ' '; *cp++ = '>'; *cp++ = ' ';
+ *cp++ = ' '; *cp++ = '>';
while (*cp2)
*cp++ = *cp2++;
*cp = '\0';
@@ -102,8 +175,8 @@ char *mode;
return(NULL);
if (fileno(fp) >= NFILE) {
- fputs("popen: too many open files\n", stderr);
- exit(1);
+ eputs("popen: too many open files\n");
+ quit(1);
pips[fileno(fp)].f = fname;
if (*mode == 'r') {
