root/radiance/ray/src/common/platform.h
Wed Jan 22 19:41:55 2025 UTC (4 months, 1 week ago) by greg
Changes since 3.17: +5 -1 lines
Diff to previous 3.17
feat: Added hopeful equivalents to ftello(), fseeko() for Windows
Wed May 22 15:37:31 2024 UTC (12 months, 2 weeks ago) by greg
Changes since 3.16: +7 -2 lines
Diff to previous 3.16
fix: Qualifying fpurge() for Linux (and removing for Windows)
Tue Mar 20 22:45:29 2018 UTC (7 years, 2 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Changes since 3.15: +6 -2 lines
Diff to previous 3.15
Created replacement usleep() function for Windows
Thu Dec 22 17:07:46 2016 UTC (8 years, 5 months ago) by greg
Changes since 3.14: +18 -1 lines
Diff to previous 3.14
Added a bunch of #undef statements to avoid macro redefinition warnings
Thu Aug 18 17:57:57 2016 UTC (8 years, 9 months ago) by greg
Changes since 3.13: +8 -2 lines
Diff to previous 3.13
Fri Aug 5 00:12:46 2016 UTC (8 years, 10 months ago) by greg
Diff to previous 3.12
Minor fixes for Windows suggested by Nathaniel Jones
Sun Mar 6 01:13:17 2016 UTC (9 years, 3 months ago) by schorsch
Changes since 3.11: +39 -7 lines
Diff to previous 3.11
Mon Oct 27 10:19:31 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 3.10: +1 -4 lines
Diff to previous 3.10
Tue Oct 21 19:19:28 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 3.9: +2 -1 lines
Diff to previous 3.9
Thu Jul 17 09:21:29 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.8: +2 -1 lines
Diff to previous 3.8
Mon Jul 14 22:23:59 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.7: +6 -4 lines
Diff to previous 3.7
Thu Jul 3 22:41:44 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.6: +7 -2 lines
Diff to previous 3.6
Mon Jun 30 19:58:37 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.5: +11 -6 lines
Diff to previous 3.5
Got some feature dependency backwards.
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.4: +29 -27 lines
Diff to previous 3.4
Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.3: +1 -3 lines
Diff to previous 3.3
Sun Jun 8 12:03:09 2003 UTC (22 years ago) by schorsch
Changes since 3.2: +4 -2 lines
Diff to previous 3.2
Fri Jun 6 16:38:47 2003 UTC (22 years ago) by schorsch
Changes since 3.1: +9 -5 lines
*** empty log message ***
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
