| 1 |
/* variables and declarations for client RPC library for software frame
| 2 |
buffer approach */
| 3 |
| 4 |
#include <netdb.h>
| 5 |
#include <rpc/rpc.h>
| 6 |
#include <sys/socket.h>
| 7 |
#include <sys/time.h>
| 8 |
| 9 |
/* if Limpel-Zev is used, a directive to define WIDEAREA is included
| 10 |
on the compile line */
| 11 |
| 12 |
| 13 |
#define SUNFRONT /* Sun is client */
| 14 |
| 15 |
#define PCPORT 2000 /* hard-wired PC port */
| 16 |
| 17 |
#define PROGNUM 1000 /* program number */
| 18 |
#define TESTVERS 1 /* version */
| 19 |
| 20 |
/* remote procedure numbers */
| 21 |
| 22 |
/* used in both metafile and software frame buffer approaches */
| 23 |
| 24 |
#define AUTHPROC 1 /* authorization procedure */
| 25 |
#define INITPROC 2 /* initialize VTR or videodisk */
| 26 |
#define RECORDPROC 4 /* record frame */
| 27 |
#define CLOSEPROC 5 /* relinquish control */
| 28 |
| 29 |
/* used only in software frame buffer approach */
| 30 |
| 31 |
#define NOCOMPRESS 6 /* no compression */
| 32 |
#define DISPLAY 7 /* display using TARGA graphics calls */
| 33 |
#define SENDUDP 13 /* send scan lines using UDP preliminary to
| 34 |
display */
| 35 |
#define MAPPROC 8 /* receive color map */
| 36 |
| 37 |
/* test RPC for rough timing estimates */
| 38 |
| 39 |
#define TESTRPC 14
| 40 |
| 41 |
/* definitions and variables common to both metafile and frame
| 42 |
| 43 |
| 44 |
/* give up after certain amount of time */
| 45 |
extern struct timeval total_timeout ;
| 46 |
/* client handle */
| 47 |
extern CLIENT *client ;
| 48 |
| 49 |
#define UDP 0 /* UDP protocol */
| 50 |
#define TCP 1 /* TCP protocol */
| 51 |
| 52 |
extern short protocol ; /* which protocol */
| 53 |
| 54 |
#define PREVIEW 0 /* preview mode */
| 55 |
| 56 |
extern FILE *vcr_rec ; /* records starting and ending frame numbers */
| 57 |
extern int curr_frame ; /* current frame number */
| 58 |
extern int copy_num ; /* number of frames to record image on */
| 59 |
extern int record ; /* preview or record */
| 60 |
extern bool_t optflag ; /* video workstation has optical disk */
| 61 |
| 62 |
struct netuser /* user description structure */
| 63 |
| 64 |
int nu_uid ; /* effective user id */
| 65 |
unsigned int nu_glen ; /* number of groups user in */
| 66 |
int *nu_gids ; /* groups user is in */
| 67 |
| 68 |
| 69 |
struct record
| 70 |
| 71 |
int in_at ; /* start recording image at */
| 72 |
int out_at ; /* finish recording image at */
| 73 |
| 74 |
| 75 |
| 76 |
| 77 |
#define NONE 0 /* no compression */
| 78 |
#define BTC 1 /* BTC compression */
| 79 |
#define COLORMAP 2 /* BTC and color map compression */
| 80 |
/* hereafter referred to as color map */
| 81 |
| 82 |
extern short compression ; /* type of compression */
| 83 |
| 84 |
struct mapstore
| 85 |
| 86 |
short mapnum ; /* number of entries in color map */
| 87 |
unsigned short map[256] ; /* entries in color map */
| 88 |
| 89 |
| 90 |
| 91 |
struct scan_packet
| 92 |
| 93 |
bool_t first ; /* first frame - no frame-frame differencing */
| 94 |
| 95 |
| 96 |
short linenum ; /* scan line number (0 to 399) */
| 97 |
int index ; /* used by server as index into piece of
| 98 |
incoming buffer */
| 99 |
int total1, total2 ; /* server uses in building up compressed
| 100 |
frame buffer from incoming pieces */
| 101 |
#ifdef WIDEAREA
| 102 |
/* number of bytes in compressed frame (Limpel_Zev only) */
| 103 |
int total_lz ;
| 104 |
#endif
| 105 |
int in_at, out_at ; /* starting, ending numbers to
| 106 |
record image on */
| 107 |
| 108 |
unsigned short map[256] ; /* color map */
| 109 |
short num_bytes[100] ; /* number of bytes in each group of
| 110 |
4 compressed scan lines */
| 111 |
unsigned char pack[76800] ; /* compressed frame buffer or piece thereof */
| 112 |
/* 2 scan lines stored here when compression
| 113 |
not used */
| 114 |
