| 1 |
/* RCSid $Id: paths.h,v 2.31 2023/04/07 19:06:18 greg Exp $ */
| 2 |
| 3 |
* Definitions for paths on different machines
| 4 |
| 5 |
#ifndef _RAD_PATHS_H_
| 6 |
#define _RAD_PATHS_H_
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <stdlib.h>
| 10 |
#include <string.h>
| 11 |
#include <fcntl.h>
| 12 |
#include <sys/types.h>
| 13 |
#include <sys/stat.h>
| 14 |
| 15 |
#if defined(_WIN32) || defined(_WIN64)
| 16 |
#include <io.h>
| 17 |
#include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */
| 18 |
#define getcwd _getcwd
| 19 |
#define chdir _chdir
| 20 |
| 21 |
#define access _access
| 22 |
#define mkdir(dirname,perms) _mkdir(dirname)
| 23 |
/* The windows _popen with the native shell breaks '\\\n' escapes.
| 24 |
* RT_WINPROC (used by SCons) enables our replacement functions to fix that.
| 25 |
* XXX This should really not depend on the compiler used! */
| 26 |
#if 1 /* defined(_MSC_VER) && !defined(RT_WINPROC) */
| 27 |
#define popen(cmd,mode) _popen(cmd,mode)
| 28 |
#define pclose(p) _pclose(p)
| 29 |
#else
| 30 |
#define popen(cmd,mode) win_popen(cmd,mode)
| 31 |
#define pclose(p) win_pclose(p)
| 32 |
#endif
| 33 |
#define kill(pid,sig) win_kill(pid,sig)
| 34 |
#define nice(inc) win_nice(inc)
| 35 |
#define PATH_MAX _MAX_PATH
| 36 |
#define NULL_DEVICE "NUL"
| 37 |
#define DIRSEP '/'
| 38 |
#define ISDIRSEP(c) (((c)=='/') | ((c)=='\\'))
| 39 |
#define ISABS(s) ( ISDIRSEP((s)[0]) \
| 40 |
|| ( isupper((s)[0]) | islower((s)[0]) \
| 41 |
&& (s)[1]==':' && ISDIRSEP((s)[2]) ) )
| 42 |
#define CASEDIRSEP case '/': case '\\'
| 43 |
#define PATHSEP ';'
| 44 |
#define CURDIR '.'
| 45 |
#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
| 46 |
#define TEMPLATE "rtXXXXXX"
| 47 |
#define TEMPLEN 8
| 48 |
#define ULIBVAR "RAYPATH"
| 49 |
#ifndef DEFPATH
| 50 |
#define DEFPATH ";c:/ray/lib"
| 51 |
#endif
| 52 |
#define SPECIALS " \t\"$*?|"
| 53 |
#define QUOTCHAR '"'
| 54 |
/* <io.h> only does half the work for access() */
| 55 |
#ifndef F_OK
| 56 |
#define F_OK 00
| 57 |
#define W_OK 02
| 58 |
#endif
| 59 |
#ifndef R_OK
| 60 |
#define X_OK 01
| 61 |
#define R_OK 04
| 62 |
#endif
| 63 |
/* to make the permissions user specific we'd need to use CreateFile() */
| 64 |
#ifndef S_IRUSR
| 65 |
#define S_IRUSR _S_IREAD
| 66 |
#define S_IWUSR _S_IWRITE
| 67 |
#endif
| 68 |
| 69 |
#else /* everything but Windows */
| 70 |
#include <unistd.h>
| 71 |
#include <sys/param.h>
| 72 |
| 73 |
#define RMAX_PATH_MAX 4096 /* our own maximum */
| 74 |
#ifndef PATH_MAX
| 75 |
#define PATH_MAX 512
| 76 |
#elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
| 77 |
#undef PATH_MAX
| 78 |
#define PATH_MAX RMAX_PATH_MAX
| 79 |
#endif
| 80 |
| 81 |
#ifdef AMIGA
| 82 |
| 83 |
#define NULL_DEVICE "NIL:"
| 84 |
#define DIRSEP '/'
| 85 |
#define ISABS(s) ISDIRSEP((s)[0])
| 86 |
#define PATHSEP ';'
| 87 |
#define CURDIR '.'
| 88 |
#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
| 89 |
#define TEMPLATE "/tmp/rtXXXXXX"
| 90 |
#define TEMPLEN 13
| 91 |
| 92 |
#ifndef DEFPATH
| 93 |
#define DEFPATH ";/ray/lib"
| 94 |
#endif
| 95 |
| 96 |
#else
| 97 |
| 98 |
/* posix */
| 99 |
| 100 |
/* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
| 101 |
#define NULL_DEVICE "/dev/null"
| 102 |
#define DIRSEP '/'
| 103 |
| 104 |
#define PATHSEP ':'
| 105 |
#define CURDIR '.'
| 106 |
| 107 |
| 108 |
#define TEMPLEN 13
| 109 |
| 110 |
#ifndef DEFPATH
| 111 |
#define DEFPATH ":/usr/local/lib/ray"
| 112 |
#endif
| 113 |
#define SPECIALS " \t\n'\"()${}*?[];|&"
| 114 |
#define QUOTCHAR '\''
| 115 |
#define ALTQUOT '"'
| 116 |
| 117 |
#endif
| 118 |
#endif
| 119 |
| 120 |
#ifndef ISDIRSEP
| 121 |
#define ISDIRSEP(c) ((c)==DIRSEP)
| 122 |
#endif
| 123 |
#ifndef CASEDIRSEP
| 124 |
#define CASEDIRSEP case DIRSEP
| 125 |
#endif
| 126 |
| 127 |
#ifdef __cplusplus
| 128 |
extern "C" {
| 129 |
#endif
| 130 |
| 131 |
| 132 |
extern FILE *win_popen(char *command, char *type);
| 133 |
extern int win_pclose(FILE *p);
| 134 |
#endif
| 135 |
| 136 |
/* Set global progname and return path-free version of argv[0] */
| 137 |
extern char *fixargv0(char *arg0);
| 138 |
extern char *progname;
| 139 |
| 140 |
/* Check if any of the characters in str2 are found in str1 */
| 141 |
extern int matchany(const char *str1, const char *str2);
| 142 |
| 143 |
/* Convert a set of arguments into a command line for pipe() or system() */
| 144 |
extern char *convert_commandline(char *cmd, const int len, char *av[]);
| 145 |
| 146 |
/* Find a writeable directory for temporary files */
| 147 |
/* If s is NULL, we return a static string */
| 148 |
extern char *temp_directory(char *s, size_t len);
| 149 |
| 150 |
/* Compose a *currently* unique name within a temporary directory */
| 151 |
| 152 |
/* If templ is NULL, we take our default template */
| 153 |
/* WARNING: On Windows, there's a maximum of 27 unique names within
| 154 |
one process for the same template. */
| 155 |
extern char *temp_filename(char *s, size_t len, char *templ);
| 156 |
| 157 |
/* Same as above, but also open the file and return the descriptor */
| 158 |
/* This one is supposed to protect against race conditions on unix */
| 159 |
/* WARNING: On Windows, there's no protection against race conditions */
| 160 |
extern int temp_fd(char *s, size_t len, char *templ);
| 161 |
| 162 |
/* Same as above, but return a file pointer instead of a descriptor */
| 163 |
extern FILE *temp_fp(char *s, size_t len, char *templ);
| 164 |
| 165 |
/* Concatenate two strings, leaving exactly one DIRSEP in between */
| 166 |
extern char *append_filepath(char *s1, char *s2, size_t len);
| 167 |
| 168 |
| 169 |
#ifdef __cplusplus
| 170 |
| 171 |
#endif
| 172 |
#endif /* _RAD_PATHS_H_ */
| 173 |
