root/radiance/ray/src/common/paths.h
Revision: 2.32
Committed: Tue Jun 3 21:31:51 2025 UTC (2 months ago) by greg
Changes since 2.31: +5 -4 lines
1 /* RCSid $Id: paths.h,v 2.31 2023/04/07 19:06:18 greg Exp $ */
2 /*
3 * Definitions for paths on different machines
4 */
5 #ifndef _RAD_PATHS_H_
6 #define _RAD_PATHS_H_
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include <fcntl.h>
12 #include <sys/types.h>
13 #include <sys/stat.h>
14
15 #if defined(_WIN32) || defined(_WIN64)
16 #include <io.h>
17 #include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */
18 #define getcwd _getcwd
19 #define chdir _chdir
20
21 #define access _access
22 #define mkdir(dirname,perms) _mkdir(dirname)
23 /* The windows _popen with the native shell breaks '\\\n' escapes.
24 * RT_WINPROC (used by SCons) enables our replacement functions to fix that.
25 * XXX This should really not depend on the compiler used! */
26 #if 1 /* defined(_MSC_VER) && !defined(RT_WINPROC) */
27 #define popen(cmd,mode) _popen(cmd,mode)
28 #define pclose(p) _pclose(p)
29 #else
30 #define popen(cmd,mode) win_popen(cmd,mode)
31 #define pclose(p) win_pclose(p)
32 #endif
33 #define kill(pid,sig) win_kill(pid,sig)
34 #define nice(inc) win_nice(inc)
35 #define PATH_MAX _MAX_PATH
36 #define NULL_DEVICE "NUL"
37 #define DIRSEP '/'
38 #define ISDIRSEP(c) (((c)=='/') | ((c)=='\\'))
39 #define ISABS(s) ( ISDIRSEP((s)[0]) \
40 || ( isupper((s)[0]) | islower((s)[0]) \
41 && (s)[1]==':' && ISDIRSEP((s)[2]) ) )
42 #define CASEDIRSEP case '/': case '\\'
43 #define PATHSEP ';'
44 #define CURDIR '.'
45 #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
46 #define TEMPLATE "rtXXXXXX"
47 #define TEMPLEN 8
48 #define ULIBVAR "RAYPATH"
49 #ifndef DEFPATH
50 #define DEFPATH ";c:/ray/lib"
51 #endif
52 #define SPECIALS " \t\"$*?|"
53 #define QUOTCHAR '"'
54 /* <io.h> only does half the work for access() */
55 #ifndef F_OK
56 #define F_OK 00
57 #define W_OK 02
58 #endif
59 #ifndef R_OK
60 #define X_OK 01
61 #define R_OK 04
62 #endif
63 /* to make the permissions user specific we'd need to use CreateFile() */
64 #ifndef S_IRUSR
65 #define S_IRUSR _S_IREAD
66 #define S_IWUSR _S_IWRITE
67 #endif
68
69 #else /* everything but Windows */
70 #include <unistd.h>
71 #include <sys/param.h>
72
73 #define RMAX_PATH_MAX 4096 /* our own maximum */
74 #ifndef PATH_MAX
75 #define PATH_MAX 512
76 #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
77 #undef PATH_MAX
78 #define PATH_MAX RMAX_PATH_MAX
79 #endif
80
81 #ifdef AMIGA
82
83 #define NULL_DEVICE "NIL:"
84 #define DIRSEP '/'
85 #define ISABS(s) ISDIRSEP((s)[0])
86 #define PATHSEP ';'
87 #define CURDIR '.'
88 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
89 #define TEMPLATE "/tmp/rtXXXXXX"
90 #define TEMPLEN 13
91 #define ULIBVAR "RAYPATH"
92 #ifndef DEFPATH
93 #define DEFPATH ";/ray/lib"
94 #endif
95
96 #else
97
98 /* posix */
99
100 /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
101 #define NULL_DEVICE "/dev/null"
102 #define DIRSEP '/'
103 #define ISABS(s) ISDIRSEP((s)[0])
104 #define PATHSEP ':'
105 #define CURDIR '.'
106 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
107 #define TEMPLATE "/tmp/rtXXXXXX"
108 #define TEMPLEN 13
109 #define ULIBVAR "RAYPATH"
110 #ifndef DEFPATH
111 #define DEFPATH ":/usr/local/lib/ray"
112 #endif
113 #define SPECIALS " \t\n'\"()${}*?[];|&"
114 #define QUOTCHAR '\''
115 #define ALTQUOT '"'
116
117 #endif
118 #endif
119
120 #ifndef ISDIRSEP
121 #define ISDIRSEP(c) ((c)==DIRSEP)
122 #endif
123 #ifndef CASEDIRSEP
124 #define CASEDIRSEP case DIRSEP
125 #endif
126
127 #ifdef __cplusplus
128 extern "C" {
129 #endif
130
131 #if defined(_WIN32) || defined(_WIN64)
132 extern FILE *win_popen(char *command, char *type);
133 extern int win_pclose(FILE *p);
134 #endif
135
136 /* Set global progname and return path-free version of argv[0] */
137 extern char *fixargv0(char *arg0);
138 extern char *progname;
139
140 /* Check if any of the characters in str2 are found in str1 */
141 extern int matchany(const char *str1, const char *str2);
142
143 /* Convert a set of arguments into a command line for pipe() or system() */
144 extern char *convert_commandline(char *cmd, const int len, char *av[]);
145
146 /* Find a writeable directory for temporary files */
147 /* If s is NULL, we return a static string */
148 extern char *temp_directory(char *s, size_t len);
149
150 /* Compose a *currently* unique name within a temporary directory */
151 /* If s is NULL, we return a static string */
152 /* If templ is NULL, we take our default template */
153 /* WARNING: On Windows, there's a maximum of 27 unique names within
154 one process for the same template. */
155 extern char *temp_filename(char *s, size_t len, char *templ);
156
157 /* Same as above, but also open the file and return the descriptor */
158 /* This one is supposed to protect against race conditions on unix */
159 /* WARNING: On Windows, there's no protection against race conditions */
160 extern int temp_fd(char *s, size_t len, char *templ);
161
162 /* Same as above, but return a file pointer instead of a descriptor */
163 extern FILE *temp_fp(char *s, size_t len, char *templ);
164
165 /* Concatenate two strings, leaving exactly one DIRSEP in between */
166 extern char *append_filepath(char *s1, char *s2, size_t len);
167
168
169 #ifdef __cplusplus
170 }
171 #endif
172 #endif /* _RAD_PATHS_H_ */
173
