1 |
/* RCSid $Id: paths.h,v 2.23 2011/10/05 17:20:55 greg Exp $ */ |
2 |
3 |
* Definitions for paths on different machines |
4 |
5 |
#ifndef _RAD_PATHS_H_ |
6 |
#define _RAD_PATHS_H_ |
7 |
8 |
#include <stdio.h> |
9 |
#include <stdlib.h> |
10 |
#include <string.h> |
11 |
#include <fcntl.h> |
12 |
#include <sys/types.h> |
13 |
#include <sys/stat.h> |
14 |
15 |
#ifdef _WIN32 |
16 |
#include <io.h> |
17 |
#include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */ |
18 |
19 |
#define access _access |
20 |
#define mkdir(dirname,perms) _mkdir(dirname) |
21 |
#define PATH_MAX _MAX_PATH |
22 |
#define NULL_DEVICE "NUL" |
23 |
#define DIRSEP '/' |
24 |
#define ISDIRSEP(c) (((c)=='/') | ((c)=='\\')) |
25 |
#define ISABS(s) ( ISDIRSEP((s)[0]) \ |
26 |
|| ( isupper((s)[0]) | islower((s)[0]) \ |
27 |
&& (s)[1]==':' && ISDIRSEP((s)[2]) ) ) |
28 |
#define CASEDIRSEP case '/': case '\\' |
29 |
#define PATHSEP ';' |
30 |
#define CURDIR '.' |
31 |
#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} |
32 |
#define TEMPLATE "rtXXXXXX" |
33 |
#define TEMPLEN 8 |
34 |
#define ULIBVAR "RAYPATH" |
35 |
#ifndef DEFPATH |
36 |
#define DEFPATH ";c:/ray/lib" |
37 |
#endif |
38 |
/* <io.h> only does half the work for access() */ |
39 |
#ifndef F_OK |
40 |
#define F_OK 00 |
41 |
#define W_OK 02 |
42 |
#endif |
43 |
#ifndef R_OK |
44 |
#define X_OK 01 |
45 |
#define R_OK 04 |
46 |
#endif |
47 |
/* to make the permissions user specific we'd need to use CreateFile() */ |
48 |
#ifndef S_IRUSR |
49 |
#define S_IRUSR _S_IREAD |
50 |
#define S_IWUSR _S_IWRITE |
51 |
#endif |
52 |
53 |
#ifdef __cplusplus |
54 |
extern "C" { |
55 |
#endif |
56 |
extern char *fixargv0(); |
57 |
58 |
59 |
#endif |
60 |
61 |
#else /* everything but Windows */ |
62 |
#include <unistd.h> |
63 |
#include <sys/param.h> |
64 |
65 |
#define RMAX_PATH_MAX 4096 /* our own maximum */ |
66 |
#ifndef PATH_MAX |
67 |
#define PATH_MAX 512 |
68 |
#elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ |
69 |
#undef PATH_MAX |
70 |
#define PATH_MAX RMAX_PATH_MAX |
71 |
#endif |
72 |
73 |
#ifdef AMIGA |
74 |
75 |
#define NULL_DEVICE "NIL:" |
76 |
77 |
#define ISABS(s) ISDIRSEP((s)[0]) |
78 |
79 |
80 |
#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} |
81 |
#define TEMPLATE "/tmp/rtXXXXXX" |
82 |
#define TEMPLEN 13 |
83 |
84 |
#ifndef DEFPATH |
85 |
#define DEFPATH ";/ray/lib" |
86 |
#endif |
87 |
#define fixargv0(a0) (a0) |
88 |
89 |
#else |
90 |
91 |
/* posix */ |
92 |
93 |
/* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ |
94 |
#define NULL_DEVICE "/dev/null" |
95 |
96 |
97 |
#define PATHSEP ':' |
98 |
99 |
100 |
101 |
#define TEMPLEN 17 |
102 |
103 |
#ifndef DEFPATH |
104 |
#define DEFPATH ":/usr/local/lib/ray" |
105 |
#endif |
106 |
107 |
108 |
#endif |
109 |
#endif |
110 |
111 |
#ifndef ISDIRSEP |
112 |
#define ISDIRSEP(c) ((c)==DIRSEP) |
113 |
#endif |
114 |
#ifndef CASEDIRSEP |
115 |
#define CASEDIRSEP case DIRSEP |
116 |
#endif |
117 |
118 |
119 |
extern "C" { |
120 |
#endif |
121 |
122 |
/* Find a writeable directory for temporary files */ |
123 |
/* If s is NULL, we return a static string */ |
124 |
extern char *temp_directory(char *s, size_t len); |
125 |
126 |
/* Compose a *currently* unique name within a temporary directory */ |
127 |
128 |
/* If templ is NULL, we take our default template */ |
129 |
/* WARNING: On Windows, there's a maximum of 27 unique names within |
130 |
one process for the same template. */ |
131 |
extern char *temp_filename(char *s, size_t len, char *templ); |
132 |
133 |
/* Same as above, but also open the file and return the descriptor */ |
134 |
/* This one is supposed to protect against race conditions on unix */ |
135 |
/* WARNING: On Windows, there's no protection against race conditions */ |
136 |
extern int temp_fd(char *s, size_t len, char *templ); |
137 |
138 |
/* Same as above, but return a file pointer instead of a descriptor */ |
139 |
extern FILE *temp_fp(char *s, size_t len, char *templ); |
140 |
141 |
/* Concatenate two strings, leaving exactly one DIRSEP in between */ |
142 |
extern char *append_filepath(char *s1, char *s2, size_t len); |
143 |
144 |
145 |
146 |
147 |
#endif |
148 |
#endif /* _RAD_PATHS_H_ */ |
149 |
