root/radiance/ray/src/common/paths.h
Revision: 2.19
Committed: Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.18: +12 -5 lines
1 /* RCSid $Id: paths.h,v 2.18 2003/07/14 20:02:29 schorsch Exp $ */
2 /*
3 * Definitions for paths on different machines
4 */
5 #ifndef _RAD_PATHS_H_
6 #define _RAD_PATHS_H_
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include <fcntl.h>
12 #include <sys/types.h>
13 #include <sys/stat.h>
14
15 #ifdef _WIN32
16 #include <io.h>
17 #include <direct.h> /* getcwd(), chdir(), etc. */
18
19 #define access _access
20 #define PATH_MAX _MAX_PATH
21 #define DIRSEP '/'
22 #define ISDIRSEP(c) ((c)=='/' || (c)=='\\')
23 #define ISABS(s) ((s)!=NULL \
24 && (s[0])!='\0' \
25 && ( ISDIRSEP(s[0]) \
26 || ( (s[1])!='\0' \
27 && (isupper(s[0])||islower(s[0])) \
28 && (s[1])==':')))
29 #define CASEDIRSEP case '/': case '\\'
30 #define PATHSEP ';'
31 #define CURDIR '.'
32 #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
33 #define TEMPLATE "rtXXXXXX"
34 #define TEMPLEN 8
35 #define ULIBVAR "RAYPATH"
36 #ifndef DEFPATH
37 #define DEFPATH ";c:/ray/lib"
38 #endif
39 /* <io.h> only does half the work for access() */
40 #ifndef F_OK
41 #define F_OK 00
42 #define X_OK 01
43 #define W_OK 02
44 #define R_OK 04
45 #endif
46 /* to make the permissions user specific we'd need to use CreateFile() */
47 #ifndef S_IRUSR
48 #define S_IRUSR _S_IREAD
49 #define S_IWUSR _S_IWRITE
50 #endif
51
52 #ifdef __cplusplus
53 extern "C" {
54 #endif
55 extern char *fixargv0();
56 #ifdef __cplusplus
57 }
58 #endif
59
60 #else /* everything but Windows */
61 #include <unistd.h>
62 #include <sys/param.h>
63
64 #define RMAX_PATH_MAX 4096 /* our own maximum */
65 #ifndef PATH_MAX
66 #define PATH_MAX 512
67 #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
68 #undef PATH_MAX
69 #define PATH_MAX RMAX_PATH_MAX
70 #endif
71
72 #ifdef AMIGA
73
74 #define DIRSEP '/'
75 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
76 #define PATHSEP ';'
77 #define CURDIR '.'
78 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
79 #define TEMPLATE "/tmp/rtXXXXXX"
80 #define TEMPLEN 13
81 #define ULIBVAR "RAYPATH"
82 #ifndef DEFPATH
83 #define DEFPATH ";/ray/lib"
84 #endif
85 #define fixargv0(a0) (a0)
86
87 #else
88
89 /* posix */
90
91 /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
92 #define NULL_DEVICE "/dev/null"
93 #define DIRSEP '/'
94 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
95 #define PATHSEP ':'
96 #define CURDIR '.'
97 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
98 #define TEMPLATE "/usr/tmp/rtXXXXXX"
99 #define TEMPLEN 17
100 #define ULIBVAR "RAYPATH"
101 #ifndef DEFPATH
102 #define DEFPATH ":/usr/local/lib/ray"
103 #endif
104 #define fixargv0(a0) (a0)
105
106 #endif
107 #endif
108
109 #ifndef ISDIRSEP
110 #define ISDIRSEP(c) ((c)==DIRSEP)
111 #endif
112 #ifndef CASEDIRSEP
113 #define CASEDIRSEP case DIRSEP
114 #endif
115
116 #ifdef __cplusplus
117 extern "C" {
118 #endif
119
120 /* Find a writeable directory for temporary files */
121 /* If s is NULL, we return a static string */
122 extern char *temp_directory(char *s, size_t len);
123
124 /* Compose a *currently* unique name within a temporary directory */
125 /* If s is NULL, we return a static string */
126 /* If templ is NULL, we take our default template */
127 /* WARNING: On Windows, there's a maximum of 27 unique names within
128 one process for the same template. */
129 extern char *temp_filename(char *s, size_t len, char *templ);
130
131 /* Same as above, but also open the file and return the descriptor */
132 /* This one is supposed to protect against race conditions on unix */
133 /* WARNING: On Windows, there's no protection against race conditions */
134 extern int temp_fd(char *s, size_t len, char *templ);
135
136 /* Same as above, but return a file pointer instead of a descriptor */
137 extern FILE *temp_fp(char *s, size_t len, char *templ);
138
139 /* Concatenate two strings, leaving exactly one DIRSEP in between */
140 extern char *append_filepath(char *s1, char *s2, size_t len);
141
142
143 #ifdef __cplusplus
144 }
145 #endif
146 #endif /* _RAD_PATHS_H_ */
147
