1 |
/* RCSid $Id: paths.h,v 2.18 2003/07/14 20:02:29 schorsch Exp $ */ |
2 |
3 |
* Definitions for paths on different machines |
4 |
5 |
#ifndef _RAD_PATHS_H_ |
6 |
#define _RAD_PATHS_H_ |
7 |
8 |
#include <stdio.h> |
9 |
#include <stdlib.h> |
10 |
#include <string.h> |
11 |
#include <fcntl.h> |
12 |
#include <sys/types.h> |
13 |
#include <sys/stat.h> |
14 |
15 |
#ifdef _WIN32 |
16 |
#include <io.h> |
17 |
#include <direct.h> /* getcwd(), chdir(), etc. */ |
18 |
19 |
#define access _access |
20 |
#define PATH_MAX _MAX_PATH |
21 |
#define DIRSEP '/' |
22 |
#define ISDIRSEP(c) ((c)=='/' || (c)=='\\') |
23 |
#define ISABS(s) ((s)!=NULL \ |
24 |
&& (s[0])!='\0' \ |
25 |
&& ( ISDIRSEP(s[0]) \ |
26 |
|| ( (s[1])!='\0' \ |
27 |
&& (isupper(s[0])||islower(s[0])) \ |
28 |
&& (s[1])==':'))) |
29 |
#define CASEDIRSEP case '/': case '\\' |
30 |
#define PATHSEP ';' |
31 |
#define CURDIR '.' |
32 |
#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} |
33 |
#define TEMPLATE "rtXXXXXX" |
34 |
#define TEMPLEN 8 |
35 |
#define ULIBVAR "RAYPATH" |
36 |
#ifndef DEFPATH |
37 |
#define DEFPATH ";c:/ray/lib" |
38 |
#endif |
39 |
/* <io.h> only does half the work for access() */ |
40 |
#ifndef F_OK |
41 |
#define F_OK 00 |
42 |
#define X_OK 01 |
43 |
#define W_OK 02 |
44 |
#define R_OK 04 |
45 |
#endif |
46 |
/* to make the permissions user specific we'd need to use CreateFile() */ |
47 |
#ifndef S_IRUSR |
48 |
#define S_IRUSR _S_IREAD |
49 |
#define S_IWUSR _S_IWRITE |
50 |
#endif |
51 |
52 |
#ifdef __cplusplus |
53 |
extern "C" { |
54 |
#endif |
55 |
extern char *fixargv0(); |
56 |
57 |
58 |
#endif |
59 |
60 |
#else /* everything but Windows */ |
61 |
#include <unistd.h> |
62 |
#include <sys/param.h> |
63 |
64 |
#define RMAX_PATH_MAX 4096 /* our own maximum */ |
65 |
#ifndef PATH_MAX |
66 |
#define PATH_MAX 512 |
67 |
#elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ |
68 |
#undef PATH_MAX |
69 |
#define PATH_MAX RMAX_PATH_MAX |
70 |
#endif |
71 |
72 |
#ifdef AMIGA |
73 |
74 |
75 |
#define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) |
76 |
77 |
78 |
#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} |
79 |
#define TEMPLATE "/tmp/rtXXXXXX" |
80 |
#define TEMPLEN 13 |
81 |
82 |
#ifndef DEFPATH |
83 |
#define DEFPATH ";/ray/lib" |
84 |
#endif |
85 |
#define fixargv0(a0) (a0) |
86 |
87 |
#else |
88 |
89 |
/* posix */ |
90 |
91 |
/* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ |
92 |
#define NULL_DEVICE "/dev/null" |
93 |
94 |
95 |
#define PATHSEP ':' |
96 |
97 |
98 |
#define TEMPLATE "/usr/tmp/rtXXXXXX" |
99 |
#define TEMPLEN 17 |
100 |
101 |
#ifndef DEFPATH |
102 |
#define DEFPATH ":/usr/local/lib/ray" |
103 |
#endif |
104 |
105 |
106 |
#endif |
107 |
#endif |
108 |
109 |
#ifndef ISDIRSEP |
110 |
#define ISDIRSEP(c) ((c)==DIRSEP) |
111 |
#endif |
112 |
#ifndef CASEDIRSEP |
113 |
#define CASEDIRSEP case DIRSEP |
114 |
#endif |
115 |
116 |
117 |
extern "C" { |
118 |
#endif |
119 |
120 |
/* Find a writeable directory for temporary files */ |
121 |
/* If s is NULL, we return a static string */ |
122 |
extern char *temp_directory(char *s, size_t len); |
123 |
124 |
/* Compose a *currently* unique name within a temporary directory */ |
125 |
126 |
/* If templ is NULL, we take our default template */ |
127 |
/* WARNING: On Windows, there's a maximum of 27 unique names within |
128 |
one process for the same template. */ |
129 |
extern char *temp_filename(char *s, size_t len, char *templ); |
130 |
131 |
/* Same as above, but also open the file and return the descriptor */ |
132 |
/* This one is supposed to protect against race conditions on unix */ |
133 |
/* WARNING: On Windows, there's no protection against race conditions */ |
134 |
extern int temp_fd(char *s, size_t len, char *templ); |
135 |
136 |
/* Same as above, but return a file pointer instead of a descriptor */ |
137 |
extern FILE *temp_fp(char *s, size_t len, char *templ); |
138 |
139 |
/* Concatenate two strings, leaving exactly one DIRSEP in between */ |
140 |
extern char *append_filepath(char *s1, char *s2, size_t len); |
141 |
142 |
143 |
144 |
145 |
#endif |
146 |
#endif /* _RAD_PATHS_H_ */ |
147 |
