root/radiance/ray/src/common/paths.h
Revision: 2.14
Committed: Thu Jun 26 00:58:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.13: +70 -62 lines
1 /* RCSid $Id: paths.h,v 2.13 2003/06/08 12:01:52 schorsch Exp $ */
2 /*
3 * Definitions for paths on different machines
4 */
5 #ifndef _RAD_PATHS_H_
6 #define _RAD_PATHS_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include "copyright.h"
12
13 #include <stdlib.h>
14 #include <string.h>
15 #ifdef _WIN32
16 #include <io.h>
17 #else /* _WIN32 */
18 #include <unistd.h>
19 #include <sys/param.h>
20 #endif /* _WIN32 */
21
22 #ifdef _WIN32
23
24 #define access _access
25 #define PATH_MAX _MAX_PATH
26 #define DIRSEP '/'
27 #define ISDIRSEP(c) ((c)=='/' || (c)=='\\')
28 #define ISABS(s) ((s)!=NULL \
29 && (s[0])!='\0' \
30 && ( ISDIRSEP(s[0]) \
31 || ( (s[1])!='\0' \
32 && (isupper(s[0])||islower(s[0])) \
33 && (s[1])==':')))
34 #define CASEDIRSEP case '/': case '\\'
35 #define PATHSEP ';'
36 #define CURDIR '.'
37 #define MAXPATH 512 /* XXX obsoleted by posix PATH_MAX */
38 #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
39 #define TEMPLATE "rtXXXXXX"
40 #define TEMPLEN 8
41 #define ULIBVAR "RAYPATH"
42 #ifndef DEFPATH
43 #define DEFPATH ";c:/ray/lib"
44 #endif
45 /* <io.h> only does half the work for access() */
46 #ifndef F_OK
47 #define F_OK 00
48 #define X_OK 01
49 #define W_OK 02
50 #define R_OK 04
51 #endif
52 extern char *fixargv0();
53
54 #else
55 #ifndef PATH_MAX /* doesn't implement posix? */
56 #define PATH_MAX 512 /* quite conservative (I think...) */
57 #endif
58
59 #ifdef AMIGA
60
61 #define DIRSEP '/'
62 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
63 #define PATHSEP ';'
64 #define CURDIR '.'
65 #define MAXPATH 128
66 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
67 #define TEMPLATE "/tmp/rtXXXXXX"
68 #define TEMPLEN 13
69 #define ULIBVAR "RAYPATH"
70 #ifndef DEFPATH
71 #define DEFPATH ";/ray/lib"
72 #endif
73 #define fixargv0(a0) (a0)
74
75 #else
76
77 #define DIRSEP '/'
78 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
79 #define PATHSEP ':'
80 #define CURDIR '.'
81 #define MAXPATH 256
82 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
83 #define TEMPLATE "/usr/tmp/rtXXXXXX"
84 #define TEMPLEN 17
85 #define ULIBVAR "RAYPATH"
86 #ifndef DEFPATH
87 #define DEFPATH ":/usr/local/lib/ray"
88 #endif
89 #define fixargv0(a0) (a0)
90
91 #endif
92 #endif
93
94 #ifndef ISDIRSEP
95 #define ISDIRSEP(c) ((c)==DIRSEP)
96 #endif
97 #ifndef CASEDIRSEP
98 #define CASEDIRSEP case DIRSEP
99 #endif
100
101 extern char *mktemp(), *getenv();
102
103 #ifdef BSD
104 extern char *getwd();
105 #else
106 extern char *getcwd();
107 #define getwd(p) getcwd(p, sizeof(p))
108 #endif
109
110
111 /* Find a writeable directory for temporary files */
112 /* If s is NULL, we return a static string */
113 extern char *temp_directory(char *s, size_t len);
114
115 /* Compose a *currently* unique name within a temporary directory */
116 /* If s is NULL, we return a static string */
117 /* If templ is NULL, we take our default template */
118 /* WARNING: On Windows, there's a maximum of 27 unique names within
119 one process for the same template. */
120 extern char *temp_filename(char *s, size_t len, char *templ);
121
122 /* Same as above, but also open the file and return the descriptor */
123 /* This one is supposed to protect against race conditions on unix */
124 /* WARNING: On Windows, there's no protection against race conditions */
125 extern int temp_file(char *s, size_t len, char *templ);
126
127 /* Concatenate two strings, leaving exactly one DIRSEP in between */
128 extern char *append_filepath(char *s1, char *s2, size_t len);
129
130
131 #ifdef __cplusplus
132 }
133 #endif
134 #endif /* _RAD_PATHS_H_ */
135
