--- ray/src/common/paths.h 1993/07/21 10:00:57 2.7 +++ ray/src/common/paths.h 2025/06/07 05:09:45 2.33 @@ -1,61 +1,183 @@ -/* Copyright (c) 1992 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: paths.h,v 2.33 2025/06/07 05:09:45 greg Exp $ */ /* * Definitions for paths on different machines */ +#ifndef _RAD_PATHS_H_ +#define _RAD_PATHS_H_ -#ifdef MSDOS +#include +#include +#include +#include +#include +#include -#define DIRSEP '/' -#define ISDIRSEP(c) ((c)=='/' || (c)=='\\') -#define CASEDIRSEP case '/': case '\\' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "rtXXXXXX" -#define TEMPLEN 8 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";c:/ray/lib" -#endif -extern char *fixargv0(); +#if defined(_WIN32) || defined(_WIN64) + #include + #include /* getcwd(), chdir(), _mkdir(), etc. */ + #define getcwd _getcwd + #define chdir _chdir -#else -#ifdef AMIGA + #define access _access + #define mkdir(dirname,perms) _mkdir(dirname) + /* The windows _popen with the native shell breaks '\\\n' escapes. + * RT_WINPROC (used by SCons) enables our replacement functions to fix that. + * XXX This should really not depend on the compiler used! */ + #if 1 /* defined(_MSC_VER) && !defined(RT_WINPROC) */ + #define popen(cmd,mode) _popen(cmd,mode) + #define pclose(p) _pclose(p) + #else + #define popen(cmd,mode) win_popen(cmd,mode) + #define pclose(p) win_pclose(p) + #endif + #define kill(pid,sig) win_kill(pid,sig) + #define nice(inc) win_nice(inc) + #define PATH_MAX _MAX_PATH + #define NULL_DEVICE "NUL" + #define DIRSEP '/' + #define ISDIRSEP(c) (((c)=='/') | ((c)=='\\')) + #define ISABS(s) ( ISDIRSEP((s)[0]) \ + || ( isupper((s)[0]) | islower((s)[0]) \ + && (s)[1]==':' && ISDIRSEP((s)[2]) ) ) + #define CASEDIRSEP case '/': case '\\' + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" + #define TEMPLEN 8 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";c:/ray/lib" + #endif + #define SPECIALS " \t\"$*?|" + #define QUOTCHAR '"' + /* only does half the work for access() */ + #ifndef F_OK + #define F_OK 00 + #define W_OK 02 + #endif + #ifndef R_OK + #define X_OK 01 + #define R_OK 04 + #endif + /* to make the permissions user specific we'd need to use CreateFile() */ + #ifndef S_IRUSR + #define S_IRUSR _S_IREAD + #define S_IWUSR _S_IWRITE + #endif -#define DIRSEP '/' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "/tmp/rtXXXXXX" -#define TEMPLEN 13 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";/ray/lib" -#endif -#define fixargv0(a0) (a0) +#else /* everything but Windows */ + #include + #include -#else + #define RMAX_PATH_MAX 4096 /* our own maximum */ + #ifndef PATH_MAX + #define PATH_MAX 512 + #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ + #undef PATH_MAX + #define PATH_MAX RMAX_PATH_MAX + #endif -#define DIRSEP '/' -#define PATHSEP ':' -#define MAXPATH 256 -#define TEMPLATE "/usr/tmp/rtXXXXXX" -#define TEMPLEN 17 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ":/usr/local/lib/ray" -#endif -#define fixargv0(a0) (a0) + #ifdef AMIGA + #define NULL_DEVICE "NIL:" + #define DIRSEP '/' + #define ISABS(s) ISDIRSEP((s)[0]) + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" + #define TEMPLEN 13 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";/ray/lib" + #endif + + #else + + /* posix */ + + /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ + #define NULL_DEVICE "/dev/null" + #define DIRSEP '/' + #define ISABS(s) ISDIRSEP((s)[0]) + #define PATHSEP ':' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" + #define TEMPLEN 13 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ":/usr/local/lib/ray" + #endif + #define SPECIALS " \t\n'\"()${}*?[];|&" + #define QUOTCHAR '\'' + #define ALTQUOT '"' + + #endif #endif -#endif #ifndef ISDIRSEP -#define ISDIRSEP(c) ((c)==DIRSEP) + #define ISDIRSEP(c) ((c)==DIRSEP) #endif #ifndef CASEDIRSEP -#define CASEDIRSEP case DIRSEP + #define CASEDIRSEP case DIRSEP #endif -extern char *mktemp(), *getenv(); +#ifdef __cplusplus +extern "C" { +#endif + +#if defined(_WIN32) || defined(_WIN64) + extern FILE *win_popen(char *command, char *type); + extern int win_pclose(FILE *p); +#endif + +/* Set global progname and return path-free version of argv[0] */ +extern char *fixargv0(char *arg0); +extern char *progname; + +/* Print program arguments to file; side effect is to set progname */ +extern void printargs(int ac, char **av, FILE *fp); + +/* Check if any of the characters in str2 are found in str1 */ +extern int matchany(const char *str1, const char *str2); + +/* Convert a set of arguments into a command line for pipe() or system() */ +extern char *convert_commandline(char *cmd, const int len, char *av[]); + +/* Find a writeable directory for temporary files */ +/* If s is NULL, we return a static string */ +extern char *temp_directory(char *s, size_t len); + +/* Compose a *currently* unique name within a temporary directory */ +/* If s is NULL, we return a static string */ +/* If templ is NULL, we take our default template */ +/* WARNING: On Windows, there's a maximum of 27 unique names within + one process for the same template. */ +extern char *temp_filename(char *s, size_t len, char *templ); + +/* Same as above, but also open the file and return the descriptor */ +/* This one is supposed to protect against race conditions on unix */ +/* WARNING: On Windows, there's no protection against race conditions */ +extern int temp_fd(char *s, size_t len, char *templ); + +/* Same as above, but return a file pointer instead of a descriptor */ +extern FILE *temp_fp(char *s, size_t len, char *templ); + +/* Concatenate two strings, leaving exactly one DIRSEP in between */ +extern char *append_filepath(char *s1, char *s2, size_t len); + /* defined in fropen.c */ +extern FILE *frlibopen(char *fname); + /* defined in getlibpath.c */ +extern char *getrlibpath(void); + /* defined in gethomedir.c */ +extern char *gethomedir(char *uname, char *path, int plen); + /* defined in getpath.c */ +extern char *getpath(char *fname, char *searchpath, int mode); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_PATHS_H_ */ +
