--- ray/src/common/paths.h 2003/07/14 22:23:59 2.19 +++ ray/src/common/paths.h 2016/03/07 01:15:01 2.28 @@ -1,4 +1,4 @@ -/* RCSid $Id: paths.h,v 2.19 2003/07/14 22:23:59 schorsch Exp $ */ +/* RCSid $Id: paths.h,v 2.28 2016/03/07 01:15:01 schorsch Exp $ */ /* * Definitions for paths on different machines */ @@ -12,51 +12,60 @@ #include #include -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) #include - #include /* getcwd(), chdir(), etc. */ + #include /* getcwd(), chdir(), _mkdir(), etc. */ + #define getcwd _getcwd + #define chdir _chdir - #define access _access - #define PATH_MAX _MAX_PATH + #define access _access + #define mkdir(dirname,perms) _mkdir(dirname) + /* The windows _popen with the native shell breaks '\\\n' escapes. + * RT_WINPROC (used by SCons) enables our replacement functions to fix that. + * XXX This should really not depend on the compiler used! */ + #if defined(_MSC_VER) && !defined(RT_WINPROC) + #define popen(cmd,mode) _popen(cmd,mode) + #define pclose(p) _pclose(p) + #else + #define popen(cmd,mode) win_popen(cmd,mode) + #define pclose(p) win_pclose(p) + #endif + #define kill(pid,sig) win_kill(pid,sig) + #define nice(inc) win_nice(inc) + #define PATH_MAX _MAX_PATH + #define NULL_DEVICE "NUL" #define DIRSEP '/' - #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') - #define ISABS(s) ((s)!=NULL \ - && (s[0])!='\0' \ - && ( ISDIRSEP(s[0]) \ - || ( (s[1])!='\0' \ - && (isupper(s[0])||islower(s[0])) \ - && (s[1])==':'))) - #define CASEDIRSEP case '/': case '\\' + #define ISDIRSEP(c) (((c)=='/') | ((c)=='\\')) + #define ISABS(s) ( ISDIRSEP((s)[0]) \ + || ( isupper((s)[0]) | islower((s)[0]) \ + && (s)[1]==':' && ISDIRSEP((s)[2]) ) ) + #define CASEDIRSEP case '/': case '\\' #define PATHSEP ';' #define CURDIR '.' - #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} - #define TEMPLATE "rtXXXXXX" + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" #define TEMPLEN 8 #define ULIBVAR "RAYPATH" #ifndef DEFPATH #define DEFPATH ";c:/ray/lib" #endif + #define SPECIALS " \t\"$*?|" + #define QUOTCHAR '"' /* only does half the work for access() */ #ifndef F_OK #define F_OK 00 - #define X_OK 01 #define W_OK 02 - #define R_OK 04 #endif + #ifndef R_OK + #define X_OK 01 + #define R_OK 04 + #endif /* to make the permissions user specific we'd need to use CreateFile() */ #ifndef S_IRUSR #define S_IRUSR _S_IREAD #define S_IWUSR _S_IWRITE #endif - #ifdef __cplusplus - extern "C" { - #endif - extern char *fixargv0(); - #ifdef __cplusplus - } - #endif - #else /* everything but Windows */ #include #include @@ -71,12 +80,13 @@ #ifdef AMIGA + #define NULL_DEVICE "NIL:" #define DIRSEP '/' - #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define ISABS(s) ISDIRSEP((s)[0]) #define PATHSEP ';' #define CURDIR '.' - #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} - #define TEMPLATE "/tmp/rtXXXXXX" + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" #define TEMPLEN 13 #define ULIBVAR "RAYPATH" #ifndef DEFPATH @@ -91,16 +101,19 @@ /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ #define NULL_DEVICE "/dev/null" #define DIRSEP '/' - #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define ISABS(s) ISDIRSEP((s)[0]) #define PATHSEP ':' #define CURDIR '.' - #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} - #define TEMPLATE "/usr/tmp/rtXXXXXX" + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" #define TEMPLEN 17 #define ULIBVAR "RAYPATH" #ifndef DEFPATH #define DEFPATH ":/usr/local/lib/ray" #endif + #define SPECIALS " \t\n'\"()${}*?[];|&" + #define QUOTCHAR '\'' + #define ALTQUOT '"' #define fixargv0(a0) (a0) #endif @@ -116,6 +129,18 @@ #ifdef __cplusplus extern "C" { #endif + +#if defined(_WIN32) || defined(_WIN64) + extern FILE *win_popen(char *command, char *type); + extern int win_pclose(FILE *p); + extern char *fixargv0(); +#endif + +/* Check if any of the characters in str2 are found in str1 */ +extern int matchany(const char *str1, const char *str2); + +/* Convert a set of arguments into a command line for pipe() or system() */ +extern char *convert_commandline(char *cmd, const int len, char *av[]); /* Find a writeable directory for temporary files */ /* If s is NULL, we return a static string */
