--- ray/src/common/paths.h 2003/06/26 00:58:09 2.14 +++ ray/src/common/paths.h 2016/03/06 01:13:17 2.27 @@ -1,70 +1,89 @@ -/* RCSid $Id: paths.h,v 2.14 2003/06/26 00:58:09 schorsch Exp $ */ +/* RCSid $Id: paths.h,v 2.27 2016/03/06 01:13:17 schorsch Exp $ */ /* * Definitions for paths on different machines */ #ifndef _RAD_PATHS_H_ #define _RAD_PATHS_H_ -#ifdef __cplusplus -extern "C" { -#endif -#include "copyright.h" - +#include #include #include -#ifdef _WIN32 +#include +#include +#include + +#if defined(_WIN32) || defined(_WIN64) #include -#else /* _WIN32 */ - #include - #include -#endif /* _WIN32 */ + #include /* getcwd(), chdir(), _mkdir(), etc. */ + #define getcwd _getcwd + #define chdir _chdir -#ifdef _WIN32 - - #define access _access - #define PATH_MAX _MAX_PATH + #define access _access + #define mkdir(dirname,perms) _mkdir(dirname) + #ifdef _MSC_VER + #define popen(cmd,mode) _popen(cmd,mode) + #define pclose(p) _pclose(p) + #else + #define popen(cmd,mode) win_popen(cmd,mode) + #define pclose(p) win_pclose(p) + #endif + #define kill(pid,sig) win_kill(pid,sig) + #define nice(inc) win_nice(inc) + #define PATH_MAX _MAX_PATH + #define NULL_DEVICE "NUL" #define DIRSEP '/' - #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') - #define ISABS(s) ((s)!=NULL \ - && (s[0])!='\0' \ - && ( ISDIRSEP(s[0]) \ - || ( (s[1])!='\0' \ - && (isupper(s[0])||islower(s[0])) \ - && (s[1])==':'))) - #define CASEDIRSEP case '/': case '\\' + #define ISDIRSEP(c) (((c)=='/') | ((c)=='\\')) + #define ISABS(s) ( ISDIRSEP((s)[0]) \ + || ( isupper((s)[0]) | islower((s)[0]) \ + && (s)[1]==':' && ISDIRSEP((s)[2]) ) ) + #define CASEDIRSEP case '/': case '\\' #define PATHSEP ';' #define CURDIR '.' - #define MAXPATH 512 /* XXX obsoleted by posix PATH_MAX */ - #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} - #define TEMPLATE "rtXXXXXX" + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" #define TEMPLEN 8 #define ULIBVAR "RAYPATH" #ifndef DEFPATH #define DEFPATH ";c:/ray/lib" #endif + #define SPECIALS " \t\"$*?|" + #define QUOTCHAR '"' /* only does half the work for access() */ #ifndef F_OK #define F_OK 00 - #define X_OK 01 #define W_OK 02 - #define R_OK 04 #endif -extern char *fixargv0(); + #ifndef R_OK + #define X_OK 01 + #define R_OK 04 + #endif + /* to make the permissions user specific we'd need to use CreateFile() */ + #ifndef S_IRUSR + #define S_IRUSR _S_IREAD + #define S_IWUSR _S_IWRITE + #endif -#else - #ifndef PATH_MAX /* doesn't implement posix? */ - #define PATH_MAX 512 /* quite conservative (I think...) */ +#else /* everything but Windows */ + #include + #include + + #define RMAX_PATH_MAX 4096 /* our own maximum */ + #ifndef PATH_MAX + #define PATH_MAX 512 + #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ + #undef PATH_MAX + #define PATH_MAX RMAX_PATH_MAX #endif #ifdef AMIGA + #define NULL_DEVICE "NIL:" #define DIRSEP '/' - #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define ISABS(s) ISDIRSEP((s)[0]) #define PATHSEP ';' #define CURDIR '.' - #define MAXPATH 128 - #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} - #define TEMPLATE "/tmp/rtXXXXXX" + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" #define TEMPLEN 13 #define ULIBVAR "RAYPATH" #ifndef DEFPATH @@ -74,18 +93,24 @@ extern char *fixargv0(); #else + /* posix */ + + /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ + #define NULL_DEVICE "/dev/null" #define DIRSEP '/' - #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define ISABS(s) ISDIRSEP((s)[0]) #define PATHSEP ':' #define CURDIR '.' - #define MAXPATH 256 - #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} - #define TEMPLATE "/usr/tmp/rtXXXXXX" + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" #define TEMPLEN 17 #define ULIBVAR "RAYPATH" #ifndef DEFPATH #define DEFPATH ":/usr/local/lib/ray" #endif + #define SPECIALS " \t\n'\"()${}*?[];|&" + #define QUOTCHAR '\'' + #define ALTQUOT '"' #define fixargv0(a0) (a0) #endif @@ -98,16 +123,22 @@ extern char *fixargv0(); #define CASEDIRSEP case DIRSEP #endif -extern char *mktemp(), *getenv(); +#ifdef __cplusplus +extern "C" { +#endif -#ifdef BSD -extern char *getwd(); -#else -extern char *getcwd(); -#define getwd(p) getcwd(p, sizeof(p)) +#if defined(_WIN32) || defined(_WIN64) + extern FILE *win_popen(char *command, char *type); + extern int win_pclose(FILE *p); + extern char *fixargv0(); #endif +/* Check if any of the characters in str2 are found in str1 */ +extern int matchany(const char *str1, const char *str2); +/* Convert a set of arguments into a command line for pipe() or system() */ +extern char *convert_commandline(char *cmd, const int len, char *av[]); + /* Find a writeable directory for temporary files */ /* If s is NULL, we return a static string */ extern char *temp_directory(char *s, size_t len); @@ -122,7 +153,10 @@ extern char *temp_filename(char *s, size_t len, char * /* Same as above, but also open the file and return the descriptor */ /* This one is supposed to protect against race conditions on unix */ /* WARNING: On Windows, there's no protection against race conditions */ -extern int temp_file(char *s, size_t len, char *templ); +extern int temp_fd(char *s, size_t len, char *templ); + +/* Same as above, but return a file pointer instead of a descriptor */ +extern FILE *temp_fp(char *s, size_t len, char *templ); /* Concatenate two strings, leaving exactly one DIRSEP in between */ extern char *append_filepath(char *s1, char *s2, size_t len);
