root/radiance/ray/src/common/paths.h
Fri Jun 29 23:09:06 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.23: +7 -10 lines
Diff to previous 2.23 , to selected 2.17
Fixed check of absolute paths for frlibopen() under Windows
Wed Oct 5 17:20:55 2011 UTC (12 years, 7 months ago) by greg
Changes since 2.22: +5 -3 lines
Diff to previous 2.22 , to selected 2.17
Windows compatibility changes from Bill Hoffman
Mon Sep 19 11:30:10 2005 UTC (18 years, 8 months ago) by schorsch
Diff to previous 2.21 , to selected 2.17
Sat Oct 30 04:59:41 2004 UTC (19 years, 6 months ago) by greg
Diff to previous 2.20 , to selected 2.17
Tue Oct 21 19:19:28 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.19: +3 -1 lines
Diff to previous 2.19 , to selected 2.17
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.18: +12 -5 lines
Diff to previous 2.18 , to selected 2.17
Mon Jul 14 20:02:29 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Thu Jul 3 22:41:44 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.16: +9 -4 lines
Diff to previous 2.16
Changes since 2.15: +24 -23 lines
Diff to previous 2.15 , to selected 2.17
Changes since 2.14: +1 -3 lines
Diff to previous 2.14 , to selected 2.17
Changes since 2.13: +70 -62 lines
Diff to previous 2.13 , to selected 2.17
Sun Jun 8 12:01:52 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.12: +49 -1 lines
Diff to previous 2.12 , to selected 2.17
Cross-platform functions to find a writeable directory for tempfiles,
create unique filenames therein, and create a file.
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.11: +13 -1 lines
Diff to previous 2.11 , to selected 2.17
*** empty log message ***
Diff to previous 2.10 , to selected 2.17
Changes since 2.9: +2 -57 lines
Diff to previous 2.9 , to selected 2.17
Changes since 2.8: +58 -4 lines
Diff to previous 2.8 , to selected 2.17
Mon Jun 24 10:01:11 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.7: +7 -0 lines
Diff to previous 2.7 , to selected 2.17
added conditional use of getwd() or getcwd()
Wed Jul 21 10:00:57 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 2.17
changed temporary directory for DOS to CWD
Wed Jan 20 13:57:58 1993 UTC (31 years, 4 months ago) by greg
Diff to previous 2.5 , to selected 2.17
fixed incorrect template length for UNIX
Wed Dec 9 12:59:45 1992 UTC (31 years, 5 months ago) by greg
Diff to previous 2.4 , to selected 2.17
changed default temp directory to /usr/tmp under UNIX
Fri Oct 9 10:26:17 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.3: +3 -0 lines
Diff to previous 2.3 , to selected 2.17
Changes for 32-bit PC port
Mon Sep 21 12:02:07 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +9 -12 lines
Diff to previous 2.2 , to selected 2.17
Changes for PC port
Tue Sep 8 10:04:36 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +15 -3 lines
Diff to previous 2.1 , to selected 2.17
Tue Sep 8 09:08:02 1992 UTC (31 years, 8 months ago) by greg
Diff to selected 2.17
