--- ray/src/common/paths.h 1993/07/21 10:00:57 2.7 +++ ray/src/common/paths.h 2003/06/08 12:01:52 2.13 @@ -1,32 +1,62 @@ -/* Copyright (c) 1992 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: paths.h,v 2.13 2003/06/08 12:01:52 schorsch Exp $ */ /* * Definitions for paths on different machines */ +#ifndef _RAD_PATHS_H_ +#define _RAD_PATHS_H_ +#ifdef __cplusplus +extern "C" { +#endif -#ifdef MSDOS +#include "copyright.h" +#include +#include +#ifdef _WIN32 + #include + #define access _access + #define PATH_MAX _MAX_PATH +#else /* _WIN32 */ + #include + #include +#endif /* _WIN32 */ + +#ifdef _WIN32 + #define DIRSEP '/' #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') +#define ISABS(s) ((s)!=NULL \ + && (s[0])!='\0' \ + && ( ISDIRSEP(s[0]) \ + || ( (s[1])!='\0' \ + && (isupper(s[0])||islower(s[0])) \ + && (s[1])==':'))) #define CASEDIRSEP case '/': case '\\' #define PATHSEP ';' #define MAXPATH 128 +#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} #define TEMPLATE "rtXXXXXX" #define TEMPLEN 8 #define ULIBVAR "RAYPATH" #ifndef DEFPATH #define DEFPATH ";c:/ray/lib" #endif +/* only does half the work for access() */ +#ifndef F_OK +#define F_OK 00 +#define W_OK 02 +#define R_OK 04 +#endif extern char *fixargv0(); #else #ifdef AMIGA #define DIRSEP '/' +#define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) #define PATHSEP ';' #define MAXPATH 128 +#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} #define TEMPLATE "/tmp/rtXXXXXX" #define TEMPLEN 13 #define ULIBVAR "RAYPATH" @@ -38,8 +68,10 @@ extern char *fixargv0(); #else #define DIRSEP '/' +#define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) #define PATHSEP ':' #define MAXPATH 256 +#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} #define TEMPLATE "/usr/tmp/rtXXXXXX" #define TEMPLEN 17 #define ULIBVAR "RAYPATH" @@ -59,3 +91,37 @@ extern char *fixargv0(); #endif extern char *mktemp(), *getenv(); + +#ifdef BSD +extern char *getwd(); +#else +extern char *getcwd(); +#define getwd(p) getcwd(p, sizeof(p)) +#endif + + +/* Find a writeable directory for temporary files */ +/* If s is NULL, we return a static string */ +extern char *temp_directory(char *s, size_t len); + +/* Compose a *currently* unique name within a temporary directory */ +/* If s is NULL, we return a static string */ +/* If templ is NULL, we take our default template */ +/* WARNING: On Windows, there's a maximum of 27 unique names within + one process for the same template. */ +extern char *temp_filename(char *s, size_t len, char *templ); + +/* Same as above, but also open the file and return the descriptor */ +/* This one is supposed to protect against race conditions on unix */ +/* WARNING: On Windows, there's no protection against race conditions */ +extern int temp_file(char *s, size_t len, char *templ); + +/* Concatenate two strings, leaving exactly one DIRSEP in between */ +extern char *append_filepath(char *s1, char *s2, size_t len); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_PATHS_H_ */ +
