Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Cross-platform functions to find a writeable directory for tempfiles, create unique filenames therein, and create a file.
*** empty log message ***
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added conditional use of getwd() or getcwd()
changed temporary directory for DOS to CWD
fixed incorrect template length for UNIX
changed default temp directory to /usr/tmp under UNIX
Changes for 32-bit PC port
Changes for PC port
