root/Development/ray/src/common/paths.h
Revision: 2.22
Committed: Mon Sep 19 11:30:10 2005 UTC (20 years, 1 month ago) by schorsch
CVS Tags: rad4R0, rad3R9, rad3R8
1 /* RCSid $Id: paths.h,v 2.21 2004/10/30 04:59:41 greg Exp $ */
2 /*
3 * Definitions for paths on different machines
4 */
5 #ifndef _RAD_PATHS_H_
6 #define _RAD_PATHS_H_
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include <fcntl.h>
12 #include <sys/types.h>
13 #include <sys/stat.h>
14
15 #ifdef _WIN32
16 #include <io.h>
17 #include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */
18
19 #define access _access
20 #define mkdir(dirname,perms) _mkdir(dirname)
21 #define PATH_MAX _MAX_PATH
22 #define NULL_DEVICE "NUL"
23 #define DIRSEP '/'
24 #define ISDIRSEP(c) ((c)=='/' || (c)=='\\')
25 #define ISABS(s) ((s)!=NULL \
26 && (s[0])!='\0' \
27 && ( ISDIRSEP(s[0]) \
28 || ( (s[1])!='\0' \
29 && (isupper(s[0])||islower(s[0])) \
30 && (s[1])==':')))
31 #define CASEDIRSEP case '/': case '\\'
32 #define PATHSEP ';'
33 #define CURDIR '.'
34 #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
35 #define TEMPLATE "rtXXXXXX"
36 #define TEMPLEN 8
37 #define ULIBVAR "RAYPATH"
38 #ifndef DEFPATH
39 #define DEFPATH ";c:/ray/lib"
40 #endif
41 /* <io.h> only does half the work for access() */
42 #ifndef F_OK
43 #define F_OK 00
44 #define X_OK 01
45 #define W_OK 02
46 #define R_OK 04
47 #endif
48 /* to make the permissions user specific we'd need to use CreateFile() */
49 #ifndef S_IRUSR
50 #define S_IRUSR _S_IREAD
51 #define S_IWUSR _S_IWRITE
52 #endif
53
54 #ifdef __cplusplus
55 extern "C" {
56 #endif
57 extern char *fixargv0();
58 #ifdef __cplusplus
59 }
60 #endif
61
62 #else /* everything but Windows */
63 #include <unistd.h>
64 #include <sys/param.h>
65
66 #define RMAX_PATH_MAX 4096 /* our own maximum */
67 #ifndef PATH_MAX
68 #define PATH_MAX 512
69 #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
70 #undef PATH_MAX
71 #define PATH_MAX RMAX_PATH_MAX
72 #endif
73
74 #ifdef AMIGA
75
76 #define NULL_DEVICE "NIL:"
77 #define DIRSEP '/'
78 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
79 #define PATHSEP ';'
80 #define CURDIR '.'
81 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
82 #define TEMPLATE "/tmp/rtXXXXXX"
83 #define TEMPLEN 13
84 #define ULIBVAR "RAYPATH"
85 #ifndef DEFPATH
86 #define DEFPATH ";/ray/lib"
87 #endif
88 #define fixargv0(a0) (a0)
89
90 #else
91
92 /* posix */
93
94 /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
95 #define NULL_DEVICE "/dev/null"
96 #define DIRSEP '/'
97 #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
98 #define PATHSEP ':'
99 #define CURDIR '.'
100 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
101 #define TEMPLATE "/tmp/rtXXXXXX"
102 #define TEMPLEN 17
103 #define ULIBVAR "RAYPATH"
104 #ifndef DEFPATH
105 #define DEFPATH ":/usr/local/lib/ray"
106 #endif
107 #define fixargv0(a0) (a0)
108
109 #endif
110 #endif
111
112 #ifndef ISDIRSEP
113 #define ISDIRSEP(c) ((c)==DIRSEP)
114 #endif
115 #ifndef CASEDIRSEP
116 #define CASEDIRSEP case DIRSEP
117 #endif
118
119 #ifdef __cplusplus
120 extern "C" {
121 #endif
122
123 /* Find a writeable directory for temporary files */
124 /* If s is NULL, we return a static string */
125 extern char *temp_directory(char *s, size_t len);
126
127 /* Compose a *currently* unique name within a temporary directory */
128 /* If s is NULL, we return a static string */
129 /* If templ is NULL, we take our default template */
130 /* WARNING: On Windows, there's a maximum of 27 unique names within
131 one process for the same template. */
132 extern char *temp_filename(char *s, size_t len, char *templ);
133
134 /* Same as above, but also open the file and return the descriptor */
135 /* This one is supposed to protect against race conditions on unix */
136 /* WARNING: On Windows, there's no protection against race conditions */
137 extern int temp_fd(char *s, size_t len, char *templ);
138
139 /* Same as above, but return a file pointer instead of a descriptor */
140 extern FILE *temp_fp(char *s, size_t len, char *templ);
141
142 /* Concatenate two strings, leaving exactly one DIRSEP in between */
143 extern char *append_filepath(char *s1, char *s2, size_t len);
144
145
146 #ifdef __cplusplus
147 }
148 #endif
149 #endif /* _RAD_PATHS_H_ */
150
