--- ray/src/common/paths.h 1992/12/09 12:59:45 2.5 +++ ray/src/common/paths.h 2003/07/14 22:23:59 2.19 @@ -1,61 +1,147 @@ -/* Copyright (c) 1992 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: paths.h,v 2.19 2003/07/14 22:23:59 schorsch Exp $ */ /* * Definitions for paths on different machines */ +#ifndef _RAD_PATHS_H_ +#define _RAD_PATHS_H_ -#ifdef MSDOS +#include +#include +#include +#include +#include +#include -#define DIRSEP '/' -#define ISDIRSEP(c) ((c)=='/' || (c)=='\\') -#define CASEDIRSEP case '/': case '\\' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "c:\\tmp\\rtXXXXXX" -#define TEMPLEN 15 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";c:/ray/lib" -#endif -extern char *fixargv0(); +#ifdef _WIN32 + #include + #include /* getcwd(), chdir(), etc. */ -#else -#ifdef AMIGA + #define access _access + #define PATH_MAX _MAX_PATH + #define DIRSEP '/' + #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') + #define ISABS(s) ((s)!=NULL \ + && (s[0])!='\0' \ + && ( ISDIRSEP(s[0]) \ + || ( (s[1])!='\0' \ + && (isupper(s[0])||islower(s[0])) \ + && (s[1])==':'))) + #define CASEDIRSEP case '/': case '\\' + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" + #define TEMPLEN 8 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";c:/ray/lib" + #endif + /* only does half the work for access() */ + #ifndef F_OK + #define F_OK 00 + #define X_OK 01 + #define W_OK 02 + #define R_OK 04 + #endif + /* to make the permissions user specific we'd need to use CreateFile() */ + #ifndef S_IRUSR + #define S_IRUSR _S_IREAD + #define S_IWUSR _S_IWRITE + #endif -#define DIRSEP '/' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "/tmp/rtXXXXXX" -#define TEMPLEN 13 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";/ray/lib" -#endif -#define fixargv0(a0) (a0) + #ifdef __cplusplus + extern "C" { + #endif + extern char *fixargv0(); + #ifdef __cplusplus + } + #endif -#else +#else /* everything but Windows */ + #include + #include -#define DIRSEP '/' -#define PATHSEP ':' -#define MAXPATH 256 -#define TEMPLATE "/usr/tmp/rtXXXXXX" -#define TEMPLEN 13 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ":/usr/local/lib/ray" -#endif -#define fixargv0(a0) (a0) + #define RMAX_PATH_MAX 4096 /* our own maximum */ + #ifndef PATH_MAX + #define PATH_MAX 512 + #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ + #undef PATH_MAX + #define PATH_MAX RMAX_PATH_MAX + #endif + #ifdef AMIGA + + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" + #define TEMPLEN 13 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";/ray/lib" + #endif + #define fixargv0(a0) (a0) + + #else + + /* posix */ + + /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ + #define NULL_DEVICE "/dev/null" + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ':' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/usr/tmp/rtXXXXXX" + #define TEMPLEN 17 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ":/usr/local/lib/ray" + #endif + #define fixargv0(a0) (a0) + + #endif #endif -#endif #ifndef ISDIRSEP -#define ISDIRSEP(c) ((c)==DIRSEP) + #define ISDIRSEP(c) ((c)==DIRSEP) #endif #ifndef CASEDIRSEP -#define CASEDIRSEP case DIRSEP + #define CASEDIRSEP case DIRSEP #endif -extern char *mktemp(), *getenv(); +#ifdef __cplusplus +extern "C" { +#endif + +/* Find a writeable directory for temporary files */ +/* If s is NULL, we return a static string */ +extern char *temp_directory(char *s, size_t len); + +/* Compose a *currently* unique name within a temporary directory */ +/* If s is NULL, we return a static string */ +/* If templ is NULL, we take our default template */ +/* WARNING: On Windows, there's a maximum of 27 unique names within + one process for the same template. */ +extern char *temp_filename(char *s, size_t len, char *templ); + +/* Same as above, but also open the file and return the descriptor */ +/* This one is supposed to protect against race conditions on unix */ +/* WARNING: On Windows, there's no protection against race conditions */ +extern int temp_fd(char *s, size_t len, char *templ); + +/* Same as above, but return a file pointer instead of a descriptor */ +extern FILE *temp_fp(char *s, size_t len, char *templ); + +/* Concatenate two strings, leaving exactly one DIRSEP in between */ +extern char *append_filepath(char *s1, char *s2, size_t len); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_PATHS_H_ */ +
