root/radiance/ray/src/common/paths.h
Revision: 2.20
Committed: Tue Oct 21 19:19:28 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 2.19: +3 -1 lines
# User Rev Content
1 schorsch 2.20 /* RCSid $Id: paths.h,v 2.19 2003/07/14 22:23:59 schorsch Exp $ */
2 greg 2.1 /*
3     * Definitions for paths on different machines
4 greg 2.9 */
5 schorsch 2.12 #ifndef _RAD_PATHS_H_
6     #define _RAD_PATHS_H_
7 greg 2.1
8 schorsch 2.16 #include <stdio.h>
9 schorsch 2.13 #include <stdlib.h>
10     #include <string.h>
11 schorsch 2.17 #include <fcntl.h>
12     #include <sys/types.h>
13     #include <sys/stat.h>
14 schorsch 2.16
15 schorsch 2.13 #ifdef _WIN32
16 schorsch 2.14 #include <io.h>
17 schorsch 2.18 #include <direct.h> /* getcwd(), chdir(), etc. */
18 greg 2.1
19 schorsch 2.14 #define access _access
20     #define PATH_MAX _MAX_PATH
21 schorsch 2.20 #define NULL_DEVICE "NUL"
22 schorsch 2.14 #define DIRSEP '/'
23     #define ISDIRSEP(c) ((c)=='/' || (c)=='\\')
24     #define ISABS(s) ((s)!=NULL \
25     && (s[0])!='\0' \
26     && ( ISDIRSEP(s[0]) \
27     || ( (s[1])!='\0' \
28     && (isupper(s[0])||islower(s[0])) \
29     && (s[1])==':')))
30     #define CASEDIRSEP case '/': case '\\'
31     #define PATHSEP ';'
32     #define CURDIR '.'
33     #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
34     #define TEMPLATE "rtXXXXXX"
35     #define TEMPLEN 8
36     #define ULIBVAR "RAYPATH"
37     #ifndef DEFPATH
38     #define DEFPATH ";c:/ray/lib"
39     #endif
40     /* <io.h> only does half the work for access() */
41     #ifndef F_OK
42     #define F_OK 00
43     #define X_OK 01
44     #define W_OK 02
45     #define R_OK 04
46     #endif
47 schorsch 2.17 /* to make the permissions user specific we'd need to use CreateFile() */
48     #ifndef S_IRUSR
49     #define S_IRUSR _S_IREAD
50     #define S_IWUSR _S_IWRITE
51     #endif
52 schorsch 2.19
53     #ifdef __cplusplus
54     extern "C" {
55     #endif
56     extern char *fixargv0();
57     #ifdef __cplusplus
58     }
59     #endif
60 greg 2.1
61 schorsch 2.16 #else /* everything but Windows */
62     #include <unistd.h>
63     #include <sys/param.h>
64
65     #define RMAX_PATH_MAX 4096 /* our own maximum */
66     #ifndef PATH_MAX
67     #define PATH_MAX 512
68     #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
69     #undef PATH_MAX
70     #define PATH_MAX RMAX_PATH_MAX
71 schorsch 2.14 #endif
72
73     #ifdef AMIGA
74
75 schorsch 2.20 #define NULL_DEVICE "NIL:"
76 schorsch 2.14 #define DIRSEP '/'
77     #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
78     #define PATHSEP ';'
79     #define CURDIR '.'
80     #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
81     #define TEMPLATE "/tmp/rtXXXXXX"
82     #define TEMPLEN 13
83     #define ULIBVAR "RAYPATH"
84     #ifndef DEFPATH
85     #define DEFPATH ";/ray/lib"
86     #endif
87     #define fixargv0(a0) (a0)
88
89     #else
90
91 schorsch 2.16 /* posix */
92
93     /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
94     #define NULL_DEVICE "/dev/null"
95 schorsch 2.14 #define DIRSEP '/'
96     #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0])))
97     #define PATHSEP ':'
98     #define CURDIR '.'
99     #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
100     #define TEMPLATE "/usr/tmp/rtXXXXXX"
101     #define TEMPLEN 17
102     #define ULIBVAR "RAYPATH"
103     #ifndef DEFPATH
104     #define DEFPATH ":/usr/local/lib/ray"
105     #endif
106     #define fixargv0(a0) (a0)
107 greg 2.1
108 schorsch 2.14 #endif
109 greg 2.2 #endif
110
111     #ifndef ISDIRSEP
112 schorsch 2.14 #define ISDIRSEP(c) ((c)==DIRSEP)
113 greg 2.2 #endif
114     #ifndef CASEDIRSEP
115 schorsch 2.14 #define CASEDIRSEP case DIRSEP
116 greg 2.1 #endif
117
118 schorsch 2.19 #ifdef __cplusplus
119     extern "C" {
120     #endif
121 schorsch 2.13
122     /* Find a writeable directory for temporary files */
123     /* If s is NULL, we return a static string */
124     extern char *temp_directory(char *s, size_t len);
125
126     /* Compose a *currently* unique name within a temporary directory */
127     /* If s is NULL, we return a static string */
128     /* If templ is NULL, we take our default template */
129     /* WARNING: On Windows, there's a maximum of 27 unique names within
130     one process for the same template. */
131     extern char *temp_filename(char *s, size_t len, char *templ);
132
133     /* Same as above, but also open the file and return the descriptor */
134     /* This one is supposed to protect against race conditions on unix */
135     /* WARNING: On Windows, there's no protection against race conditions */
136 schorsch 2.16 extern int temp_fd(char *s, size_t len, char *templ);
137
138     /* Same as above, but return a file pointer instead of a descriptor */
139     extern FILE *temp_fp(char *s, size_t len, char *templ);
140 schorsch 2.13
141     /* Concatenate two strings, leaving exactly one DIRSEP in between */
142     extern char *append_filepath(char *s1, char *s2, size_t len);
143 schorsch 2.12
144
145     #ifdef __cplusplus
146     }
147     #endif
148     #endif /* _RAD_PATHS_H_ */
149
