--- ray/src/common/paths.h 2003/06/08 12:01:52 2.13 +++ ray/src/common/paths.h 2003/07/14 22:23:59 2.19 @@ -1,105 +1,122 @@ -/* RCSid $Id: paths.h,v 2.13 2003/06/08 12:01:52 schorsch Exp $ */ +/* RCSid $Id: paths.h,v 2.19 2003/07/14 22:23:59 schorsch Exp $ */ /* * Definitions for paths on different machines */ #ifndef _RAD_PATHS_H_ #define _RAD_PATHS_H_ -#ifdef __cplusplus -extern "C" { -#endif -#include "copyright.h" - +#include #include #include -#ifdef _WIN32 - #include - #define access _access - #define PATH_MAX _MAX_PATH -#else /* _WIN32 */ - #include - #include -#endif /* _WIN32 */ +#include +#include +#include #ifdef _WIN32 + #include + #include /* getcwd(), chdir(), etc. */ -#define DIRSEP '/' -#define ISDIRSEP(c) ((c)=='/' || (c)=='\\') -#define ISABS(s) ((s)!=NULL \ - && (s[0])!='\0' \ - && ( ISDIRSEP(s[0]) \ - || ( (s[1])!='\0' \ - && (isupper(s[0])||islower(s[0])) \ - && (s[1])==':'))) -#define CASEDIRSEP case '/': case '\\' -#define PATHSEP ';' -#define MAXPATH 128 -#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} -#define TEMPLATE "rtXXXXXX" -#define TEMPLEN 8 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";c:/ray/lib" -#endif -/* only does half the work for access() */ -#ifndef F_OK -#define F_OK 00 -#define W_OK 02 -#define R_OK 04 -#endif -extern char *fixargv0(); + #define access _access + #define PATH_MAX _MAX_PATH + #define DIRSEP '/' + #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') + #define ISABS(s) ((s)!=NULL \ + && (s[0])!='\0' \ + && ( ISDIRSEP(s[0]) \ + || ( (s[1])!='\0' \ + && (isupper(s[0])||islower(s[0])) \ + && (s[1])==':'))) + #define CASEDIRSEP case '/': case '\\' + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" + #define TEMPLEN 8 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";c:/ray/lib" + #endif + /* only does half the work for access() */ + #ifndef F_OK + #define F_OK 00 + #define X_OK 01 + #define W_OK 02 + #define R_OK 04 + #endif + /* to make the permissions user specific we'd need to use CreateFile() */ + #ifndef S_IRUSR + #define S_IRUSR _S_IREAD + #define S_IWUSR _S_IWRITE + #endif -#else -#ifdef AMIGA + #ifdef __cplusplus + extern "C" { + #endif + extern char *fixargv0(); + #ifdef __cplusplus + } + #endif -#define DIRSEP '/' -#define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) -#define PATHSEP ';' -#define MAXPATH 128 -#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} -#define TEMPLATE "/tmp/rtXXXXXX" -#define TEMPLEN 13 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";/ray/lib" -#endif -#define fixargv0(a0) (a0) +#else /* everything but Windows */ + #include + #include -#else + #define RMAX_PATH_MAX 4096 /* our own maximum */ + #ifndef PATH_MAX + #define PATH_MAX 512 + #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ + #undef PATH_MAX + #define PATH_MAX RMAX_PATH_MAX + #endif -#define DIRSEP '/' -#define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) -#define PATHSEP ':' -#define MAXPATH 256 -#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} -#define TEMPLATE "/usr/tmp/rtXXXXXX" -#define TEMPLEN 17 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ":/usr/local/lib/ray" -#endif -#define fixargv0(a0) (a0) + #ifdef AMIGA + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ';' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" + #define TEMPLEN 13 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";/ray/lib" + #endif + #define fixargv0(a0) (a0) + + #else + + /* posix */ + + /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ + #define NULL_DEVICE "/dev/null" + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ':' + #define CURDIR '.' + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/usr/tmp/rtXXXXXX" + #define TEMPLEN 17 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ":/usr/local/lib/ray" + #endif + #define fixargv0(a0) (a0) + + #endif #endif -#endif #ifndef ISDIRSEP -#define ISDIRSEP(c) ((c)==DIRSEP) + #define ISDIRSEP(c) ((c)==DIRSEP) #endif #ifndef CASEDIRSEP -#define CASEDIRSEP case DIRSEP + #define CASEDIRSEP case DIRSEP #endif -extern char *mktemp(), *getenv(); - -#ifdef BSD -extern char *getwd(); -#else -extern char *getcwd(); -#define getwd(p) getcwd(p, sizeof(p)) +#ifdef __cplusplus +extern "C" { #endif - /* Find a writeable directory for temporary files */ /* If s is NULL, we return a static string */ extern char *temp_directory(char *s, size_t len); @@ -114,7 +131,10 @@ extern char *temp_filename(char *s, size_t len, char * /* Same as above, but also open the file and return the descriptor */ /* This one is supposed to protect against race conditions on unix */ /* WARNING: On Windows, there's no protection against race conditions */ -extern int temp_file(char *s, size_t len, char *templ); +extern int temp_fd(char *s, size_t len, char *templ); + +/* Same as above, but return a file pointer instead of a descriptor */ +extern FILE *temp_fp(char *s, size_t len, char *templ); /* Concatenate two strings, leaving exactly one DIRSEP in between */ extern char *append_filepath(char *s1, char *s2, size_t len);
