--- ray/src/common/paths.h 2003/06/06 16:38:47 2.12 +++ ray/src/common/paths.h 2003/06/26 00:58:09 2.14 @@ -1,4 +1,4 @@ -/* RCSid $Id: paths.h,v 2.12 2003/06/06 16:38:47 schorsch Exp $ */ +/* RCSid $Id: paths.h,v 2.14 2003/06/26 00:58:09 schorsch Exp $ */ /* * Definitions for paths on different machines */ @@ -10,56 +10,92 @@ extern "C" { #include "copyright.h" +#include +#include #ifdef _WIN32 + #include +#else /* _WIN32 */ + #include + #include +#endif /* _WIN32 */ -#define DIRSEP '/' -#define ISDIRSEP(c) ((c)=='/' || (c)=='\\') -#define CASEDIRSEP case '/': case '\\' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "rtXXXXXX" -#define TEMPLEN 8 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";c:/ray/lib" -#endif +#ifdef _WIN32 + + #define access _access + #define PATH_MAX _MAX_PATH + #define DIRSEP '/' + #define ISDIRSEP(c) ((c)=='/' || (c)=='\\') + #define ISABS(s) ((s)!=NULL \ + && (s[0])!='\0' \ + && ( ISDIRSEP(s[0]) \ + || ( (s[1])!='\0' \ + && (isupper(s[0])||islower(s[0])) \ + && (s[1])==':'))) + #define CASEDIRSEP case '/': case '\\' + #define PATHSEP ';' + #define CURDIR '.' + #define MAXPATH 512 /* XXX obsoleted by posix PATH_MAX */ + #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} + #define TEMPLATE "rtXXXXXX" + #define TEMPLEN 8 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";c:/ray/lib" + #endif + /* only does half the work for access() */ + #ifndef F_OK + #define F_OK 00 + #define X_OK 01 + #define W_OK 02 + #define R_OK 04 + #endif extern char *fixargv0(); #else -#ifdef AMIGA + #ifndef PATH_MAX /* doesn't implement posix? */ + #define PATH_MAX 512 /* quite conservative (I think...) */ + #endif -#define DIRSEP '/' -#define PATHSEP ';' -#define MAXPATH 128 -#define TEMPLATE "/tmp/rtXXXXXX" -#define TEMPLEN 13 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ";/ray/lib" -#endif -#define fixargv0(a0) (a0) + #ifdef AMIGA -#else + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ';' + #define CURDIR '.' + #define MAXPATH 128 + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/tmp/rtXXXXXX" + #define TEMPLEN 13 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ";/ray/lib" + #endif + #define fixargv0(a0) (a0) -#define DIRSEP '/' -#define PATHSEP ':' -#define MAXPATH 256 -#define TEMPLATE "/usr/tmp/rtXXXXXX" -#define TEMPLEN 17 -#define ULIBVAR "RAYPATH" -#ifndef DEFPATH -#define DEFPATH ":/usr/local/lib/ray" -#endif -#define fixargv0(a0) (a0) + #else + #define DIRSEP '/' + #define ISABS(s) ((s)!=NULL && (ISDIRSEP(s[0]))) + #define PATHSEP ':' + #define CURDIR '.' + #define MAXPATH 256 + #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} + #define TEMPLATE "/usr/tmp/rtXXXXXX" + #define TEMPLEN 17 + #define ULIBVAR "RAYPATH" + #ifndef DEFPATH + #define DEFPATH ":/usr/local/lib/ray" + #endif + #define fixargv0(a0) (a0) + + #endif #endif -#endif #ifndef ISDIRSEP -#define ISDIRSEP(c) ((c)==DIRSEP) + #define ISDIRSEP(c) ((c)==DIRSEP) #endif #ifndef CASEDIRSEP -#define CASEDIRSEP case DIRSEP + #define CASEDIRSEP case DIRSEP #endif extern char *mktemp(), *getenv(); @@ -70,6 +106,26 @@ extern char *getwd(); extern char *getcwd(); #define getwd(p) getcwd(p, sizeof(p)) #endif + + +/* Find a writeable directory for temporary files */ +/* If s is NULL, we return a static string */ +extern char *temp_directory(char *s, size_t len); + +/* Compose a *currently* unique name within a temporary directory */ +/* If s is NULL, we return a static string */ +/* If templ is NULL, we take our default template */ +/* WARNING: On Windows, there's a maximum of 27 unique names within + one process for the same template. */ +extern char *temp_filename(char *s, size_t len, char *templ); + +/* Same as above, but also open the file and return the descriptor */ +/* This one is supposed to protect against race conditions on unix */ +/* WARNING: On Windows, there's no protection against race conditions */ +extern int temp_file(char *s, size_t len, char *templ); + +/* Concatenate two strings, leaving exactly one DIRSEP in between */ +extern char *append_filepath(char *s1, char *s2, size_t len); #ifdef __cplusplus
