1 |
/* RCSid $Id: paths.h,v 2.32 2025/06/03 21:31:51 greg Exp $ */ |
2 |
3 |
* Definitions for paths on different machines |
4 |
5 |
#ifndef _RAD_PATHS_H_ |
6 |
#define _RAD_PATHS_H_ |
7 |
8 |
#include <stdio.h> |
9 |
#include <stdlib.h> |
10 |
#include <string.h> |
11 |
#include <fcntl.h> |
12 |
#include <sys/types.h> |
13 |
#include <sys/stat.h> |
14 |
15 |
#if defined(_WIN32) || defined(_WIN64) |
16 |
#include <io.h> |
17 |
#include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */ |
18 |
#define getcwd _getcwd |
19 |
#define chdir _chdir |
20 |
21 |
#define access _access |
22 |
#define mkdir(dirname,perms) _mkdir(dirname) |
23 |
/* The windows _popen with the native shell breaks '\\\n' escapes. |
24 |
* RT_WINPROC (used by SCons) enables our replacement functions to fix that. |
25 |
* XXX This should really not depend on the compiler used! */ |
26 |
#if 1 /* defined(_MSC_VER) && !defined(RT_WINPROC) */ |
27 |
#define popen(cmd,mode) _popen(cmd,mode) |
28 |
#define pclose(p) _pclose(p) |
29 |
#else |
30 |
#define popen(cmd,mode) win_popen(cmd,mode) |
31 |
#define pclose(p) win_pclose(p) |
32 |
#endif |
33 |
#define kill(pid,sig) win_kill(pid,sig) |
34 |
#define nice(inc) win_nice(inc) |
35 |
#define PATH_MAX _MAX_PATH |
36 |
#define NULL_DEVICE "NUL" |
37 |
#define DIRSEP '/' |
38 |
#define ISDIRSEP(c) (((c)=='/') | ((c)=='\\')) |
39 |
#define ISABS(s) ( ISDIRSEP((s)[0]) \ |
40 |
|| ( isupper((s)[0]) | islower((s)[0]) \ |
41 |
&& (s)[1]==':' && ISDIRSEP((s)[2]) ) ) |
42 |
#define CASEDIRSEP case '/': case '\\' |
43 |
#define PATHSEP ';' |
44 |
#define CURDIR '.' |
45 |
#define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL} |
46 |
#define TEMPLATE "rtXXXXXX" |
47 |
#define TEMPLEN 8 |
48 |
#define ULIBVAR "RAYPATH" |
49 |
#ifndef DEFPATH |
50 |
#define DEFPATH ";c:/ray/lib" |
51 |
#endif |
52 |
#define SPECIALS " \t\"$*?|" |
53 |
#define QUOTCHAR '"' |
54 |
/* <io.h> only does half the work for access() */ |
55 |
#ifndef F_OK |
56 |
#define F_OK 00 |
57 |
#define W_OK 02 |
58 |
#endif |
59 |
#ifndef R_OK |
60 |
#define X_OK 01 |
61 |
#define R_OK 04 |
62 |
#endif |
63 |
/* to make the permissions user specific we'd need to use CreateFile() */ |
64 |
#ifndef S_IRUSR |
65 |
#define S_IRUSR _S_IREAD |
66 |
#define S_IWUSR _S_IWRITE |
67 |
#endif |
68 |
69 |
#else /* everything but Windows */ |
70 |
#include <unistd.h> |
71 |
#include <sys/param.h> |
72 |
73 |
#define RMAX_PATH_MAX 4096 /* our own maximum */ |
74 |
#ifndef PATH_MAX |
75 |
#define PATH_MAX 512 |
76 |
#elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */ |
77 |
#undef PATH_MAX |
78 |
#define PATH_MAX RMAX_PATH_MAX |
79 |
#endif |
80 |
81 |
#ifdef AMIGA |
82 |
83 |
#define NULL_DEVICE "NIL:" |
84 |
85 |
#define ISABS(s) ISDIRSEP((s)[0]) |
86 |
87 |
88 |
#define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL} |
89 |
#define TEMPLATE "/tmp/rtXXXXXX" |
90 |
#define TEMPLEN 13 |
91 |
92 |
#ifndef DEFPATH |
93 |
#define DEFPATH ";/ray/lib" |
94 |
#endif |
95 |
96 |
#else |
97 |
98 |
/* posix */ |
99 |
100 |
/* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */ |
101 |
#define NULL_DEVICE "/dev/null" |
102 |
103 |
104 |
#define PATHSEP ':' |
105 |
106 |
107 |
108 |
109 |
110 |
#ifndef DEFPATH |
111 |
#define DEFPATH ":/usr/local/lib/ray" |
112 |
#endif |
113 |
#define SPECIALS " \t\n'\"()${}*?[];|&" |
114 |
#define QUOTCHAR '\'' |
115 |
#define ALTQUOT '"' |
116 |
117 |
#endif |
118 |
#endif |
119 |
120 |
#ifndef ISDIRSEP |
121 |
#define ISDIRSEP(c) ((c)==DIRSEP) |
122 |
#endif |
123 |
#ifndef CASEDIRSEP |
124 |
#define CASEDIRSEP case DIRSEP |
125 |
#endif |
126 |
127 |
#ifdef __cplusplus |
128 |
extern "C" { |
129 |
#endif |
130 |
131 |
132 |
extern FILE *win_popen(char *command, char *type); |
133 |
extern int win_pclose(FILE *p); |
134 |
#endif |
135 |
136 |
/* Set global progname and return path-free version of argv[0] */ |
137 |
extern char *fixargv0(char *arg0); |
138 |
extern char *progname; |
139 |
140 |
/* Print program arguments to file; side effect is to set progname */ |
141 |
extern void printargs(int ac, char **av, FILE *fp); |
142 |
143 |
/* Check if any of the characters in str2 are found in str1 */ |
144 |
extern int matchany(const char *str1, const char *str2); |
145 |
146 |
/* Convert a set of arguments into a command line for pipe() or system() */ |
147 |
extern char *convert_commandline(char *cmd, const int len, char *av[]); |
148 |
149 |
/* Find a writeable directory for temporary files */ |
150 |
/* If s is NULL, we return a static string */ |
151 |
extern char *temp_directory(char *s, size_t len); |
152 |
153 |
/* Compose a *currently* unique name within a temporary directory */ |
154 |
155 |
/* If templ is NULL, we take our default template */ |
156 |
/* WARNING: On Windows, there's a maximum of 27 unique names within |
157 |
one process for the same template. */ |
158 |
extern char *temp_filename(char *s, size_t len, char *templ); |
159 |
160 |
/* Same as above, but also open the file and return the descriptor */ |
161 |
/* This one is supposed to protect against race conditions on unix */ |
162 |
/* WARNING: On Windows, there's no protection against race conditions */ |
163 |
extern int temp_fd(char *s, size_t len, char *templ); |
164 |
165 |
/* Same as above, but return a file pointer instead of a descriptor */ |
166 |
extern FILE *temp_fp(char *s, size_t len, char *templ); |
167 |
168 |
/* Concatenate two strings, leaving exactly one DIRSEP in between */ |
169 |
extern char *append_filepath(char *s1, char *s2, size_t len); |
170 |
/* defined in fropen.c */ |
171 |
extern FILE *frlibopen(char *fname); |
172 |
/* defined in getlibpath.c */ |
173 |
extern char *getrlibpath(void); |
174 |
/* defined in gethomedir.c */ |
175 |
extern char *gethomedir(char *uname, char *path, int plen); |
176 |
/* defined in getpath.c */ |
177 |
extern char *getpath(char *fname, char *searchpath, int mode); |
178 |
179 |
180 |
181 |
#endif |
182 |
#endif /* _RAD_PATHS_H_ */ |
183 |
