root/radiance/ray/src/common/paths.h
Revision: 2.27
Committed: Sun Mar 6 01:13:17 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 2.26: +5 -3 lines
1 /* RCSid $Id: paths.h,v 2.26 2016/02/03 22:41:35 greg Exp $ */
2 /*
3 * Definitions for paths on different machines
4 */
5 #ifndef _RAD_PATHS_H_
6 #define _RAD_PATHS_H_
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include <fcntl.h>
12 #include <sys/types.h>
13 #include <sys/stat.h>
14
15 #if defined(_WIN32) || defined(_WIN64)
16 #include <io.h>
17 #include <direct.h> /* getcwd(), chdir(), _mkdir(), etc. */
18 #define getcwd _getcwd
19 #define chdir _chdir
20
21 #define access _access
22 #define mkdir(dirname,perms) _mkdir(dirname)
23 #ifdef _MSC_VER
24 #define popen(cmd,mode) _popen(cmd,mode)
25 #define pclose(p) _pclose(p)
26 #else
27 #define popen(cmd,mode) win_popen(cmd,mode)
28 #define pclose(p) win_pclose(p)
29 #endif
30 #define kill(pid,sig) win_kill(pid,sig)
31 #define nice(inc) win_nice(inc)
32 #define PATH_MAX _MAX_PATH
33 #define NULL_DEVICE "NUL"
34 #define DIRSEP '/'
35 #define ISDIRSEP(c) (((c)=='/') | ((c)=='\\'))
36 #define ISABS(s) ( ISDIRSEP((s)[0]) \
37 || ( isupper((s)[0]) | islower((s)[0]) \
38 && (s)[1]==':' && ISDIRSEP((s)[2]) ) )
39 #define CASEDIRSEP case '/': case '\\'
40 #define PATHSEP ';'
41 #define CURDIR '.'
42 #define DEFAULT_TEMPDIRS {"C:/TMP", "C:/TEMP", ".", NULL}
43 #define TEMPLATE "rtXXXXXX"
44 #define TEMPLEN 8
45 #define ULIBVAR "RAYPATH"
46 #ifndef DEFPATH
47 #define DEFPATH ";c:/ray/lib"
48 #endif
49 #define SPECIALS " \t\"$*?|"
50 #define QUOTCHAR '"'
51 /* <io.h> only does half the work for access() */
52 #ifndef F_OK
53 #define F_OK 00
54 #define W_OK 02
55 #endif
56 #ifndef R_OK
57 #define X_OK 01
58 #define R_OK 04
59 #endif
60 /* to make the permissions user specific we'd need to use CreateFile() */
61 #ifndef S_IRUSR
62 #define S_IRUSR _S_IREAD
63 #define S_IWUSR _S_IWRITE
64 #endif
65
66 #else /* everything but Windows */
67 #include <unistd.h>
68 #include <sys/param.h>
69
70 #define RMAX_PATH_MAX 4096 /* our own maximum */
71 #ifndef PATH_MAX
72 #define PATH_MAX 512
73 #elif PATH_MAX > RMAX_PATH_MAX /* the OS is exaggerating */
74 #undef PATH_MAX
75 #define PATH_MAX RMAX_PATH_MAX
76 #endif
77
78 #ifdef AMIGA
79
80 #define NULL_DEVICE "NIL:"
81 #define DIRSEP '/'
82 #define ISABS(s) ISDIRSEP((s)[0])
83 #define PATHSEP ';'
84 #define CURDIR '.'
85 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
86 #define TEMPLATE "/tmp/rtXXXXXX"
87 #define TEMPLEN 13
88 #define ULIBVAR "RAYPATH"
89 #ifndef DEFPATH
90 #define DEFPATH ";/ray/lib"
91 #endif
92 #define fixargv0(a0) (a0)
93
94 #else
95
96 /* posix */
97
98 /* this is defined as _PATH_DEVNULL in /usr/include/paths.h on Linux */
99 #define NULL_DEVICE "/dev/null"
100 #define DIRSEP '/'
101 #define ISABS(s) ISDIRSEP((s)[0])
102 #define PATHSEP ':'
103 #define CURDIR '.'
104 #define DEFAULT_TEMPDIRS {"/var/tmp", "/usr/tmp", "/tmp", ".", NULL}
105 #define TEMPLATE "/tmp/rtXXXXXX"
106 #define TEMPLEN 17
107 #define ULIBVAR "RAYPATH"
108 #ifndef DEFPATH
109 #define DEFPATH ":/usr/local/lib/ray"
110 #endif
111 #define SPECIALS " \t\n'\"()${}*?[];|&"
112 #define QUOTCHAR '\''
113 #define ALTQUOT '"'
114 #define fixargv0(a0) (a0)
115
116 #endif
117 #endif
118
119 #ifndef ISDIRSEP
120 #define ISDIRSEP(c) ((c)==DIRSEP)
121 #endif
122 #ifndef CASEDIRSEP
123 #define CASEDIRSEP case DIRSEP
124 #endif
125
126 #ifdef __cplusplus
127 extern "C" {
128 #endif
129
130 #if defined(_WIN32) || defined(_WIN64)
131 extern FILE *win_popen(char *command, char *type);
132 extern int win_pclose(FILE *p);
133 extern char *fixargv0();
134 #endif
135
136 /* Check if any of the characters in str2 are found in str1 */
137 extern int matchany(const char *str1, const char *str2);
138
139 /* Convert a set of arguments into a command line for pipe() or system() */
140 extern char *convert_commandline(char *cmd, const int len, char *av[]);
141
142 /* Find a writeable directory for temporary files */
143 /* If s is NULL, we return a static string */
144 extern char *temp_directory(char *s, size_t len);
145
146 /* Compose a *currently* unique name within a temporary directory */
147 /* If s is NULL, we return a static string */
148 /* If templ is NULL, we take our default template */
149 /* WARNING: On Windows, there's a maximum of 27 unique names within
150 one process for the same template. */
151 extern char *temp_filename(char *s, size_t len, char *templ);
152
153 /* Same as above, but also open the file and return the descriptor */
154 /* This one is supposed to protect against race conditions on unix */
155 /* WARNING: On Windows, there's no protection against race conditions */
156 extern int temp_fd(char *s, size_t len, char *templ);
157
158 /* Same as above, but return a file pointer instead of a descriptor */
159 extern FILE *temp_fp(char *s, size_t len, char *templ);
160
161 /* Concatenate two strings, leaving exactly one DIRSEP in between */
162 extern char *append_filepath(char *s1, char *s2, size_t len);
163
164
165 #ifdef __cplusplus
166 }
167 #endif
168 #endif /* _RAD_PATHS_H_ */
169
