root/radiance/ray/src/common/paths.h
Fri Apr 7 19:06:18 2023 UTC (2 years ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.30
fix: win_popen() stopped working for some reason under Windows 11
Mon Jul 10 20:15:18 2017 UTC (7 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R3
Diff to previous 2.29
Corrected TEMPLEN macro value for Unix
Mon May 8 16:58:52 2017 UTC (7 years, 11 months ago) by greg
Diff to previous 2.28
ANSIfication needs pointed out by Nathaniel Jones
Mon Mar 7 01:15:01 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.27: +5 -2 lines
Diff to previous 2.27
Enable SCons windows build
Sun Mar 6 01:13:17 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.26: +5 -3 lines
Diff to previous 2.26
Wed Feb 3 22:41:35 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.25: +2 -3 lines
Diff to previous 2.25
Fixed errors introduced in Windows
Tue Feb 2 18:02:32 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.24: +41 -22 lines
Diff to previous 2.24
Fri Jun 29 23:09:06 2012 UTC (12 years, 10 months ago) by greg
Changes since 2.23: +7 -10 lines
Diff to previous 2.23
Fixed check of absolute paths for frlibopen() under Windows
Wed Oct 5 17:20:55 2011 UTC (13 years, 7 months ago) by greg
Changes since 2.22: +5 -3 lines
Diff to previous 2.22
Windows compatibility changes from Bill Hoffman
Mon Sep 19 11:30:10 2005 UTC (19 years, 7 months ago) by schorsch
Diff to previous 2.21
Sat Oct 30 04:59:41 2004 UTC (20 years, 6 months ago) by greg
Diff to previous 2.20
Tue Oct 21 19:19:28 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.19: +3 -1 lines
Diff to previous 2.19
Mon Jul 14 22:23:59 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.18: +12 -5 lines
Diff to previous 2.18
Mon Jul 14 20:02:29 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.17
Thu Jul 3 22:41:44 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.16: +9 -4 lines
Diff to previous 2.16
Mon Jun 30 14:59:11 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.15: +24 -23 lines
Diff to previous 2.15
Fri Jun 27 06:53:21 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.14: +1 -3 lines
Diff to previous 2.14
Thu Jun 26 00:58:09 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.13: +70 -62 lines
Diff to previous 2.13
Sun Jun 8 12:01:52 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.12: +49 -1 lines
Diff to previous 2.12
Cross-platform functions to find a writeable directory for tempfiles,
create unique filenames therein, and create a file.
Fri Jun 6 16:38:47 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.11: +13 -1 lines
*** empty log message ***
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.9: +2 -57 lines
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.8: +58 -4 lines
Mon Jun 24 10:01:11 1996 UTC (28 years, 10 months ago) by greg
Changes since 2.7: +7 -0 lines
added conditional use of getwd() or getcwd()
Wed Jul 21 10:00:57 1993 UTC (31 years, 9 months ago) by greg
changed temporary directory for DOS to CWD
Wed Jan 20 13:57:58 1993 UTC (32 years, 3 months ago) by greg
fixed incorrect template length for UNIX
Wed Dec 9 12:59:45 1992 UTC (32 years, 5 months ago) by greg
changed default temp directory to /usr/tmp under UNIX
Fri Oct 9 10:26:17 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +3 -0 lines
Changes for 32-bit PC port
Mon Sep 21 12:02:07 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.2: +9 -12 lines
Changes for PC port
Tue Sep 8 10:04:36 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.1: +15 -3 lines
Tue Sep 8 09:08:02 1992 UTC (32 years, 8 months ago) by greg
