1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: paths.c,v 2.4 2003/07/01 21:21:40 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Find a writeable tempfile directory. |
6 |
* Create unique filenames therein, and possibly open the file. |
7 |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "paths.h" |
13 |
14 |
15 |
#define TEMPFILE_TEMPLATE "rtXXXXXX" |
16 |
static const char *defaultpaths[] = DEFAULT_TEMPDIRS; |
17 |
18 |
19 |
/* Return a writeable directory for temporary files */ |
20 |
/* If s is NULL, we return a static string */ |
21 |
char * |
22 |
temp_directory(char *s, size_t len) |
23 |
24 |
static char td[PATH_MAX]; /* remember */ |
25 |
char * ts = NULL; |
26 |
int i = 0; |
27 |
28 |
if (td[0] != '\0') { /* we already have one */ |
29 |
if (s == NULL) { return td; } |
30 |
strncpy(s, td, len); |
31 |
s[len-1] = '\0'; |
32 |
return s; |
33 |
34 |
/* check where TMP and TEMP point to */ |
35 |
ts = getenv("TMP"); |
36 |
if (ts != NULL && access(ts, W_OK) == 0) { |
37 |
strncpy(td, ts, sizeof(td)); |
38 |
td[sizeof(td)-1] = '\0'; |
39 |
40 |
if (ts == NULL) { |
41 |
ts = getenv("TEMP"); |
42 |
43 |
44 |
45 |
46 |
47 |
/* check the platform specific default paths in order */ |
48 |
while (ts == NULL) { |
49 |
if (defaultpaths[i] == NULL) { |
50 |
break; |
51 |
52 |
if (access(defaultpaths[i], W_OK) == 0) { |
53 |
ts = strncpy(td, defaultpaths[i], sizeof(td)); |
54 |
55 |
break; |
56 |
57 |
i++; |
58 |
59 |
/* we found something */ |
60 |
if (ts != NULL) { |
61 |
62 |
strncpy(s, ts, len); |
63 |
s[len-1] = '\0'; |
64 |
return s; |
65 |
66 |
return NULL; |
67 |
68 |
69 |
70 |
/* Concatenate two strings, leaving exactly one DIRSEP in between */ |
71 |
char * |
72 |
append_filepath(char *s1, char *s2, size_t len) |
73 |
74 |
size_t siz; |
75 |
char *s; |
76 |
77 |
siz = strlen(s1); |
78 |
if (siz > 0) { |
79 |
/* XXX siz > len is an error */ |
80 |
while (siz > 1 && ISDIRSEP(s1[siz-1])) { |
81 |
s1[siz-1] = '\0'; |
82 |
siz--; |
83 |
84 |
if (siz+1 <= len) { |
85 |
s1[siz] = DIRSEP; |
86 |
siz++; |
87 |
88 |
} else if (len >= 2) { /* first path empty */ |
89 |
s1[0] = CURDIR; |
90 |
s1[1] = DIRSEP; |
91 |
siz = 2; |
92 |
} else { |
93 |
return NULL; |
94 |
95 |
while (ISDIRSEP(s2[0])) { |
96 |
s2++; |
97 |
98 |
s = strncat(s1, s2, len-siz); |
99 |
return s; |
100 |
101 |
102 |
103 |
/* Do the actual work for tempfiles, except for the uniquification */ |
104 |
static char * |
105 |
prepare_tmpname(char *s, size_t len, char *templ) |
106 |
107 |
static char lp[PATH_MAX] = "\0"; |
108 |
char *ts = NULL; |
109 |
110 |
if (s == NULL) { /* return our static string */ |
111 |
s = lp; |
112 |
len = sizeof(lp); |
113 |
114 |
115 |
ts = temp_directory(s, len); |
116 |
if (ts == NULL) { return NULL; } |
117 |
ts = append_filepath(ts, templ != NULL ? templ : TEMPFILE_TEMPLATE, len); |
118 |
return ts; |
119 |
120 |
121 |
122 |
/* Compose a *currently* unique name within a temporary directory */ |
123 |
124 |
/* If templ is NULL, we take our default template */ |
125 |
/* WARNING: On Windows, there's a maximum of 27 unique names within |
126 |
one process for the same template. */ |
127 |
char * |
128 |
temp_filename(char *s, size_t len, char *templ) |
129 |
130 |
char *ts = NULL; |
131 |
132 |
ts = prepare_tmpname(s, len, templ); |
133 |
134 |
return mktemp(ts); |
135 |
136 |
137 |
138 |
/* Open a unique temp file in a safe way (not safe on Windows) */ |
139 |
/* If s is NULL, we use a static string the caller won't learn about */ |
140 |
141 |
/* This one is supposed to protect against race conditions on unix */ |
142 |
/* WARNING: On Windows, there's no protection against race conditions */ |
143 |
144 |
145 |
int |
146 |
temp_fd(char *s, size_t len, char *templ) |
147 |
148 |
char *ts = NULL; |
149 |
150 |
151 |
if (ts == NULL) return -1; |
152 |
#if defined(_WIN32) || defined(_WIN64) |
153 |
ts = mktemp(ts); |
154 |
155 |
return open(ts, O_CREAT|O_EXCL, S_IRUSR|S_IWUSR); |
156 |
#else |
157 |
return mkstemp(ts); |
158 |
#endif |
159 |
160 |
161 |
/* As above, but returns a file pointer instead of a descriptor */ |
162 |
FILE * |
163 |
temp_fp(char *s, size_t len, char *templ) |
164 |
165 |
int fd = temp_fd(s, len, templ); |
166 |
if (fd < 0) return NULL; |
167 |
return fdopen(fd, "w+"); |
168 |
169 |
170 |
171 |
#ifdef TEST_MODULE |
172 |
int main() |
173 |
174 |
static char p[PATH_MAX] = "\0"; |
175 |
char * pp, *qq = NULL; |
176 |
pp = temp_directory(p, sizeof(p)); |
177 |
printf("%s\n", pp); |
178 |
179 |
qq = temp_filename(pp, sizeof(p), "//something/else_XXXXXX"); |
180 |
printf("%s\n", qq); |
181 |
182 |
qq = temp_filename(pp, sizeof(p), NULL); |
183 |
184 |
185 |
#endif |
186 |
