root/radiance/ray/src/common/otypes.h
Revision: 2.8
Committed: Sat Feb 22 02:07:22 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.7: +57 -5 lines
1 /* RCSid: $Id$ */
2 /*
3 * otypes.h - defines for object types.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 typedef struct {
64 char *funame; /* function name */
65 int flags; /* type flags */
66 int (*funp)(); /* pointer to function */
67 } FUN;
68 /* object types in decreasing frequency */
69 #define OBJ_FACE 0 /* polygon */
70 #define OBJ_CONE 1 /* cone */
71 #define OBJ_SPHERE 2 /* sphere */
72 #define TEX_FUNC 3 /* surface texture function */
73 #define OBJ_RING 4 /* disk */
74 #define OBJ_CYLINDER 5 /* cylinder */
75 #define OBJ_INSTANCE 6 /* octree instance */
76 #define OBJ_CUP 7 /* inverted cone */
77 #define OBJ_BUBBLE 8 /* inverted sphere */
78 #define OBJ_TUBE 9 /* inverted cylinder */
79 #define MAT_PLASTIC 10 /* plastic surface */
80 #define MAT_METAL 11 /* metal surface */
81 #define MAT_GLASS 12 /* thin glass surface */
82 #define MAT_TRANS 13 /* translucent material */
83 #define MAT_DIELECTRIC 14 /* dielectric material */
84 #define MAT_PLASTIC2 15 /* anisotropic plastic */
85 #define MAT_METAL2 16 /* anisotropic metal */
86 #define MAT_TRANS2 17 /* anisotropic translucent material */
87 #define MAT_INTERFACE 18 /* dielectric interface */
88 #define MAT_PFUNC 19 /* plastic brdf function */
89 #define MAT_MFUNC 20 /* metal brdf function */
90 #define PAT_BFUNC 21 /* brightness function */
91 #define PAT_BDATA 22 /* brightness data */
92 #define PAT_BTEXT 23 /* monochromatic text */
93 #define PAT_CPICT 24 /* color picture */
94 #define MAT_GLOW 25 /* proximity light source */
95 #define OBJ_SOURCE 26 /* distant source */
96 #define MAT_LIGHT 27 /* primary light source */
97 #define MAT_ILLUM 28 /* secondary light source */
98 #define MAT_SPOT 29 /* spot light source */
99 #define MAT_MIST 30 /* mist medium */
100 #define MAT_MIRROR 31 /* mirror (secondary source) */
101 #define MAT_TFUNC 32 /* trans brdf function */
102 #define MAT_BRTDF 33 /* brtd function */
103 #define MAT_PDATA 34 /* plastic brdf data */
104 #define MAT_MDATA 35 /* metal brdf data */
105 #define MAT_TDATA 36 /* trans brdf data */
106 #define PAT_CFUNC 37 /* color function */
107 #define MAT_CLIP 38 /* clipping surface */
108 #define PAT_CDATA 39 /* color data */
109 #define PAT_CTEXT 40 /* colored text */
110 #define TEX_DATA 41 /* surface texture data */
111 #define MIX_FUNC 42 /* mixing function */
112 #define MIX_DATA 43 /* mixing data */
113 #define MIX_TEXT 44 /* mixing text */
114 #define MIX_PICT 45 /* mixing picture */
115 #define MAT_DIRECT1 46 /* unidirecting material */
116 #define MAT_DIRECT2 47 /* bidirecting material */
117 /* number of object types */
118 #define NUMOTYPE 48
119 /* type flags */
120 #define T_S 01 /* surface (object) */
121 #define T_M 02 /* material */
122 #define T_P 04 /* pattern */
123 #define T_T 010 /* texture */
124 #define T_X 020 /* mixture */
125 #define T_V 040 /* volume */
126 #define T_L 0100 /* light source modifier */
127 #define T_LV 0200 /* virtual light source modifier */
128 #define T_F 0400 /* function */
129 #define T_D 01000 /* data */
130 #define T_I 02000 /* picture */
131 #define T_E 04000 /* text */
132 /* user-defined types */
133 #define T_SP1 010000
134 #define T_SP2 020000
135 #define T_SP3 040000
136
137 extern FUN ofun[]; /* our type list */
138
139 #define issurface(t) (ofun[t].flags & T_S)
140 #define isvolume(t) (ofun[t].flags & T_V)
141 #define ismodifier(t) (!(ofun[t].flags & (T_S|T_V)))
142 #define ismaterial(t) (ofun[t].flags & T_M)
143 #define islight(t) (ofun[t].flags & T_L)
144 #define isvlight(t) (ofun[t].flags & T_LV)
145 #define hasdata(t) (ofun[t].flags & (T_D|T_I))
146 #define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I))
147 #define hastext(t) (ofun[t].flags & T_E)
148 #define isflat(t) ((t)==OBJ_FACE || (t)==OBJ_RING)
149
150 extern int o_default();
151 /* type list initialization */
152 #define INIT_OTYPE { { "polygon", T_S, o_default }, \
153 { "cone", T_S, o_default }, \
154 { "sphere", T_S, o_default }, \
155 { "texfunc", T_T|T_F, o_default }, \
156 { "ring", T_S, o_default }, \
157 { "cylinder", T_S, o_default }, \
158 { "instance", T_V, o_default }, \
159 { "cup", T_S, o_default }, \
160 { "bubble", T_S, o_default }, \
161 { "tube", T_S, o_default }, \
162 { "plastic", T_M, o_default }, \
163 { "metal", T_M, o_default }, \
164 { "glass", T_M, o_default }, \
165 { "trans", T_M, o_default }, \
166 { "dielectric", T_M, o_default }, \
167 { "plastic2", T_M|T_F, o_default }, \
168 { "metal2", T_M|T_F, o_default }, \
169 { "trans2", T_M|T_F, o_default }, \
170 { "interface", T_M, o_default }, \
171 { "plasfunc", T_M|T_F, o_default }, \
172 { "metfunc", T_M|T_F, o_default }, \
173 { "brightfunc", T_P|T_F, o_default }, \
174 { "brightdata", T_P|T_D, o_default }, \
175 { "brighttext", T_P|T_E, o_default }, \
176 { "colorpict", T_P|T_I, o_default }, \
177 { "glow", T_M|T_L, o_default }, \
178 { "source", T_S, o_default }, \
179 { "light", T_M|T_L, o_default }, \
180 { "illum", T_M|T_L, o_default }, \
181 { "spotlight", T_M|T_L, o_default }, \
182 { "mist", T_M, o_default }, \
183 { "mirror", T_M|T_LV, o_default }, \
184 { "transfunc", T_M|T_F, o_default }, \
185 { "BRTDfunc", T_M|T_F, o_default }, \
186 { "plasdata", T_M|T_D, o_default }, \
187 { "metdata", T_M|T_D, o_default }, \
188 { "transdata", T_M|T_D, o_default }, \
189 { "colorfunc", T_P|T_F, o_default }, \
190 { "antimatter", T_M, o_default }, \
191 { "colordata", T_P|T_D, o_default }, \
192 { "colortext", T_P|T_E, o_default }, \
193 { "texdata", T_T|T_D, o_default }, \
194 { "mixfunc", T_X|T_F, o_default }, \
195 { "mixdata", T_X|T_D, o_default }, \
196 { "mixtext", T_X|T_E, o_default }, \
197 { "mixpict", T_X|T_I, o_default }, \
198 { "prism1", T_M|T_F|T_LV, o_default }, \
199 { "prism2", T_M|T_F|T_LV, o_default }, \
200 }
201
202 #define ALIASID "alias" /* alias type identifier */
