1 |
/* RCSid $Id: otypes.h,v 2.15 2004/03/28 20:33:12 schorsch Exp $ */ |
2 |
3 |
* otypes.h - defines for object types. |
4 |
5 |
#ifndef _RAD_OTYPES_H_ |
6 |
#define _RAD_OTYPES_H_ |
7 |
#ifdef __cplusplus |
8 |
extern "C" { |
9 |
#endif |
10 |
11 |
typedef struct { |
12 |
char *funame; /* function name */ |
13 |
int flags; /* type flags */ |
14 |
#ifdef FUN_ARGLIST |
15 |
int (*funp)(FUN_ARGLIST); /* pointer to function */ |
16 |
#else |
17 |
int (*funp)(); /* pointer to function */ |
18 |
#endif |
19 |
} FUN; |
20 |
21 |
22 |
extern int o_default(FUN_ARGLIST); |
23 |
#else |
24 |
extern int o_default(); /* XXX conflict with radogl.h */ |
25 |
#endif |
26 |
27 |
/* object types in decreasing frequency */ |
28 |
#define OBJ_FACE 0 /* polygon */ |
29 |
#define OBJ_CONE 1 /* cone */ |
30 |
#define OBJ_SPHERE 2 /* sphere */ |
31 |
#define TEX_FUNC 3 /* surface texture function */ |
32 |
#define OBJ_RING 4 /* disk */ |
33 |
#define OBJ_CYLINDER 5 /* cylinder */ |
34 |
#define OBJ_INSTANCE 6 /* octree instance */ |
35 |
#define OBJ_CUP 7 /* inverted cone */ |
36 |
#define OBJ_BUBBLE 8 /* inverted sphere */ |
37 |
#define OBJ_TUBE 9 /* inverted cylinder */ |
38 |
#define OBJ_MESH 10 /* mesh instance */ |
39 |
#define MOD_ALIAS 11 /* modifier alias */ |
40 |
#define MAT_PLASTIC 12 /* plastic surface */ |
41 |
#define MAT_METAL 13 /* metal surface */ |
42 |
#define MAT_GLASS 14 /* thin glass surface */ |
43 |
#define MAT_TRANS 15 /* translucent material */ |
44 |
#define MAT_DIELECTRIC 16 /* dielectric material */ |
45 |
#define MAT_PLASTIC2 17 /* anisotropic plastic */ |
46 |
#define MAT_METAL2 18 /* anisotropic metal */ |
47 |
#define MAT_TRANS2 19 /* anisotropic translucent material */ |
48 |
#define MAT_INTERFACE 20 /* dielectric interface */ |
49 |
#define MAT_PFUNC 21 /* plastic brdf function */ |
50 |
#define MAT_MFUNC 22 /* metal brdf function */ |
51 |
#define PAT_BFUNC 23 /* brightness function */ |
52 |
#define PAT_BDATA 24 /* brightness data */ |
53 |
#define PAT_BTEXT 25 /* monochromatic text */ |
54 |
#define PAT_CPICT 26 /* color picture */ |
55 |
#define MAT_GLOW 27 /* proximity light source */ |
56 |
#define OBJ_SOURCE 28 /* distant source */ |
57 |
#define MAT_LIGHT 29 /* primary light source */ |
58 |
#define MAT_ILLUM 30 /* secondary light source */ |
59 |
#define MAT_SPOT 31 /* spot light source */ |
60 |
#define MAT_MIST 32 /* mist medium */ |
61 |
#define MAT_MIRROR 33 /* mirror (secondary source) */ |
62 |
#define MAT_TFUNC 34 /* trans brdf function */ |
63 |
#define MAT_BRTDF 35 /* BRTD function */ |
64 |
#define MAT_BSDF 36 /* BSDF data file */ |
65 |
#define MAT_PDATA 37 /* plastic brdf data */ |
66 |
#define MAT_MDATA 38 /* metal brdf data */ |
67 |
#define MAT_TDATA 39 /* trans brdf data */ |
68 |
#define PAT_CFUNC 40 /* color function */ |
69 |
#define MAT_CLIP 41 /* clipping surface */ |
70 |
#define PAT_CDATA 42 /* color data */ |
71 |
#define PAT_CTEXT 43 /* colored text */ |
72 |
#define TEX_DATA 44 /* surface texture data */ |
73 |
#define MIX_FUNC 45 /* mixing function */ |
74 |
#define MIX_DATA 46 /* mixing data */ |
75 |
#define MIX_TEXT 47 /* mixing text */ |
76 |
#define MIX_PICT 48 /* mixing picture */ |
77 |
#define MAT_DIRECT1 49 /* unidirecting material */ |
78 |
#define MAT_DIRECT2 50 /* bidirecting material */ |
79 |
/* number of object types */ |
80 |
#define NUMOTYPE 51 |
81 |
/* type flags */ |
82 |
#define T_S 01 /* surface (object) */ |
83 |
#define T_M 02 /* material */ |
84 |
#define T_P 04 /* pattern */ |
85 |
#define T_T 010 /* texture */ |
86 |
#define T_X 020 /* mixture */ |
87 |
#define T_V 040 /* volume */ |
88 |
#define T_L 0100 /* light source modifier */ |
89 |
#define T_LV 0200 /* virtual light source modifier */ |
90 |
#define T_F 0400 /* function */ |
91 |
#define T_D 01000 /* data */ |
92 |
#define T_I 02000 /* picture */ |
93 |
#define T_E 04000 /* text */ |
94 |
/* user-defined types */ |
95 |
#define T_SP1 010000 |
96 |
#define T_SP2 020000 |
97 |
#define T_SP3 040000 |
98 |
99 |
extern FUN ofun[]; /* our type list */ |
100 |
101 |
#define issurface(t) (ofun[t].flags & T_S) |
102 |
#define isvolume(t) (ofun[t].flags & T_V) |
103 |
#define ismodifier(t) (!(ofun[t].flags & (T_S|T_V))) |
104 |
#define ismaterial(t) (ofun[t].flags & T_M) |
105 |
#define ispattern(t) (ofun[t].flags & T_P) |
106 |
#define istexture(t) (ofun[t].flags & T_T) |
107 |
#define ismixture(t) (ofun[t].flags & T_X) |
108 |
#define islight(t) (ofun[t].flags & T_L) |
109 |
#define isvlight(t) (ofun[t].flags & T_LV) |
110 |
#define hasdata(t) (ofun[t].flags & (T_D|T_I)) |
111 |
#define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I)) |
112 |
#define hastext(t) (ofun[t].flags & T_E) |
113 |
#define isflat(t) ((t)==OBJ_FACE || (t)==OBJ_RING) |
114 |
115 |
#define ALIASKEY "alias" /* alias keyword */ |
116 |
#define ALIASMOD "inherit" /* inherit target modifier */ |
117 |
118 |
/* type list initialization */ |
119 |
#define INIT_OTYPE { { "polygon", T_S, o_default }, \ |
120 |
{ "cone", T_S, o_default }, \ |
121 |
{ "sphere", T_S, o_default }, \ |
122 |
{ "texfunc", T_T|T_F, o_default }, \ |
123 |
{ "ring", T_S, o_default }, \ |
124 |
{ "cylinder", T_S, o_default }, \ |
125 |
{ "instance", T_V, o_default }, \ |
126 |
{ "cup", T_S, o_default }, \ |
127 |
{ "bubble", T_S, o_default }, \ |
128 |
{ "tube", T_S, o_default }, \ |
129 |
{ "mesh", T_V, o_default }, \ |
130 |
{ ALIASKEY, 0, o_default }, \ |
131 |
{ "plastic", T_M, o_default }, \ |
132 |
{ "metal", T_M, o_default }, \ |
133 |
{ "glass", T_M, o_default }, \ |
134 |
{ "trans", T_M, o_default }, \ |
135 |
{ "dielectric", T_M, o_default }, \ |
136 |
{ "plastic2", T_M|T_F, o_default }, \ |
137 |
{ "metal2", T_M|T_F, o_default }, \ |
138 |
{ "trans2", T_M|T_F, o_default }, \ |
139 |
{ "interface", T_M, o_default }, \ |
140 |
{ "plasfunc", T_M|T_F, o_default }, \ |
141 |
{ "metfunc", T_M|T_F, o_default }, \ |
142 |
{ "brightfunc", T_P|T_F, o_default }, \ |
143 |
{ "brightdata", T_P|T_D, o_default }, \ |
144 |
{ "brighttext", T_P|T_E, o_default }, \ |
145 |
{ "colorpict", T_P|T_I, o_default }, \ |
146 |
{ "glow", T_M|T_L, o_default }, \ |
147 |
{ "source", T_S, o_default }, \ |
148 |
{ "light", T_M|T_L, o_default }, \ |
149 |
{ "illum", T_M|T_L, o_default }, \ |
150 |
{ "spotlight", T_M|T_L, o_default }, \ |
151 |
{ "mist", T_M, o_default }, \ |
152 |
{ "mirror", T_M|T_LV, o_default }, \ |
153 |
{ "transfunc", T_M|T_F, o_default }, \ |
154 |
{ "BRTDfunc", T_M|T_F, o_default }, \ |
155 |
{ "BSDF", T_M|T_D, o_default }, \ |
156 |
{ "plasdata", T_M|T_D, o_default }, \ |
157 |
{ "metdata", T_M|T_D, o_default }, \ |
158 |
{ "transdata", T_M|T_D, o_default }, \ |
159 |
{ "colorfunc", T_P|T_F, o_default }, \ |
160 |
{ "antimatter", T_M, o_default }, \ |
161 |
{ "colordata", T_P|T_D, o_default }, \ |
162 |
{ "colortext", T_P|T_E, o_default }, \ |
163 |
{ "texdata", T_T|T_D, o_default }, \ |
164 |
{ "mixfunc", T_X|T_F, o_default }, \ |
165 |
{ "mixdata", T_X|T_D, o_default }, \ |
166 |
{ "mixtext", T_X|T_E, o_default }, \ |
167 |
{ "mixpict", T_X|T_I, o_default }, \ |
168 |
{ "prism1", T_M|T_F|T_LV, o_default }, \ |
169 |
{ "prism2", T_M|T_F|T_LV, o_default }, \ |
170 |
171 |
172 |
173 |
174 |
175 |
#endif |
176 |
#endif /* _RAD_OTYPES_H_ */ |
