--- ray/src/common/otypes.h 1991/05/07 14:53:16 1.10 +++ ray/src/common/otypes.h 2012/07/29 19:01:39 2.17 @@ -1,18 +1,29 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: otypes.h,v 2.17 2012/07/29 19:01:39 greg Exp $ */ /* * otypes.h - defines for object types. - * - * 1/28/86 */ +#ifndef _RAD_OTYPES_H_ +#define _RAD_OTYPES_H_ +#ifdef __cplusplus +extern "C" { +#endif typedef struct { char *funame; /* function name */ int flags; /* type flags */ +#ifdef FUN_ARGLIST + int (*funp)(FUN_ARGLIST); /* pointer to function */ +#else int (*funp)(); /* pointer to function */ +#endif } FUN; + +#ifdef FUN_ARGLIST +extern int o_default(FUN_ARGLIST); +#else +extern int o_default(); /* XXX conflict with radogl.h */ +#endif + /* object types in decreasing frequency */ #define OBJ_FACE 0 /* polygon */ #define OBJ_CONE 1 /* cone */ @@ -24,38 +35,50 @@ typedef struct { #define OBJ_CUP 7 /* inverted cone */ #define OBJ_BUBBLE 8 /* inverted sphere */ #define OBJ_TUBE 9 /* inverted cylinder */ -#define MAT_PLASTIC 10 /* plastic surface */ -#define MAT_METAL 11 /* metal surface */ -#define OBJ_SOURCE 12 /* distant source */ -#define MAT_GLASS 13 /* thin glass surface */ -#define MAT_TRANS 14 /* translucent material */ -#define MAT_DIELECTRIC 15 /* dielectric material */ -#define MAT_INTERFACE 16 /* dielectric interface */ -#define MAT_PFUNC 17 /* plastic brdf function */ -#define MAT_MFUNC 18 /* metal brdf function */ -#define PAT_BFUNC 19 /* brightness function */ -#define PAT_BDATA 20 /* brightness data */ -#define PAT_BTEXT 21 /* monochromatic text */ -#define PAT_CPICT 22 /* color picture */ -#define MAT_LIGHT 23 /* primary light source */ -#define MAT_ILLUM 24 /* secondary light source */ -#define MAT_GLOW 25 /* proximity light source */ -#define MAT_SPOT 26 /* spot light source */ -#define MAT_TFUNC 27 /* trans brdf function */ -#define MAT_BRTDF 28 /* brtd function */ -#define MAT_PDATA 29 /* plastic brdf data */ -#define MAT_MDATA 30 /* metal brdf data */ -#define MAT_TDATA 31 /* trans brdf data */ -#define PAT_CFUNC 32 /* color function */ -#define MAT_CLIP 33 /* clipping surface */ -#define PAT_CDATA 34 /* color data */ -#define PAT_CTEXT 35 /* colored text */ -#define TEX_DATA 36 /* surface texture data */ -#define MIX_FUNC 37 /* mixing function */ -#define MIX_DATA 38 /* mixing data */ -#define MIX_TEXT 39 /* mixing text */ +#define OBJ_MESH 10 /* mesh instance */ +#define MOD_ALIAS 11 /* modifier alias */ +#define MAT_PLASTIC 12 /* plastic surface */ +#define MAT_METAL 13 /* metal surface */ +#define MAT_GLASS 14 /* thin glass surface */ +#define MAT_TRANS 15 /* translucent material */ +#define MAT_DIELECTRIC 16 /* dielectric material */ +#define MAT_PLASTIC2 17 /* anisotropic plastic */ +#define MAT_METAL2 18 /* anisotropic metal */ +#define MAT_TRANS2 19 /* anisotropic translucent material */ +#define MAT_INTERFACE 20 /* dielectric interface */ +#define MAT_PFUNC 21 /* plastic brdf function */ +#define MAT_MFUNC 22 /* metal brdf function */ +#define PAT_BFUNC 23 /* brightness function */ +#define PAT_BDATA 24 /* brightness data */ +#define PAT_BTEXT 25 /* monochromatic text */ +#define PAT_CPICT 26 /* color picture */ +#define MAT_GLOW 27 /* proximity light source */ +#define OBJ_SOURCE 28 /* distant source */ +#define MAT_LIGHT 29 /* primary light source */ +#define MAT_ILLUM 30 /* secondary light source */ +#define MAT_SPOT 31 /* spot light source */ +#define MAT_MIST 32 /* mist medium */ +#define MAT_MIRROR 33 /* mirror (secondary source) */ +#define MAT_TFUNC 34 /* trans brdf function */ +#define MAT_BRTDF 35 /* BRTD function */ +#define MAT_BSDF 36 /* BSDF data file */ +#define MAT_PDATA 37 /* plastic brdf data */ +#define MAT_MDATA 38 /* metal brdf data */ +#define MAT_TDATA 39 /* trans brdf data */ +#define PAT_CFUNC 40 /* color function */ +#define MAT_CLIP 41 /* clipping surface */ +#define PAT_CDATA 42 /* color data */ +#define PAT_CTEXT 43 /* colored text */ +#define TEX_DATA 44 /* surface texture data */ +#define MIX_FUNC 45 /* mixing function */ +#define MIX_DATA 46 /* mixing data */ +#define MIX_TEXT 47 /* mixing text */ +#define MIX_PICT 48 /* mixing picture */ +#define MAT_DIRECT1 49 /* unidirecting material */ +#define MAT_DIRECT2 50 /* bidirecting material */ +#define MAT_ASHIKHMIN 51 /* Ashikhmin-Shirley BRDF material */ /* number of object types */ -#define NUMOTYPE 40 +#define NUMOTYPE 52 /* type flags */ #define T_S 01 /* surface (object) */ #define T_M 02 /* material */ @@ -64,10 +87,11 @@ typedef struct { #define T_X 020 /* mixture */ #define T_V 040 /* volume */ #define T_L 0100 /* light source modifier */ -#define T_F 0200 /* function */ -#define T_D 0400 /* data */ -#define T_I 01000 /* picture */ -#define T_E 02000 /* text */ +#define T_LV 0200 /* virtual light source modifier */ +#define T_F 0400 /* function */ +#define T_D 01000 /* data */ +#define T_I 02000 /* picture */ +#define T_E 04000 /* text */ /* user-defined types */ #define T_SP1 010000 #define T_SP2 020000 @@ -77,15 +101,21 @@ extern FUN ofun[]; /* our type list */ #define issurface(t) (ofun[t].flags & T_S) #define isvolume(t) (ofun[t].flags & T_V) -#define ismodifier(t) (!issurface(t)) +#define ismodifier(t) (!(ofun[t].flags & (T_S|T_V))) #define ismaterial(t) (ofun[t].flags & T_M) -#define istexture(t) (ofun[t].flags & (T_P|T_T|T_X)) +#define ispattern(t) (ofun[t].flags & T_P) +#define istexture(t) (ofun[t].flags & T_T) +#define ismixture(t) (ofun[t].flags & T_X) #define islight(t) (ofun[t].flags & T_L) +#define isvlight(t) (ofun[t].flags & T_LV) #define hasdata(t) (ofun[t].flags & (T_D|T_I)) #define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I)) #define hastext(t) (ofun[t].flags & T_E) +#define isflat(t) ((t)==OBJ_FACE || (t)==OBJ_RING) -extern int o_default(); +#define ALIASKEY "alias" /* alias keyword */ +#define ALIASMOD "inherit" /* inherit target modifier */ + /* type list initialization */ #define INIT_OTYPE { { "polygon", T_S, o_default }, \ { "cone", T_S, o_default }, \ @@ -93,16 +123,20 @@ extern int o_default(); { "texfunc", T_T|T_F, o_default }, \ { "ring", T_S, o_default }, \ { "cylinder", T_S, o_default }, \ - { "instance", T_S|T_V, o_default }, \ + { "instance", T_V, o_default }, \ { "cup", T_S, o_default }, \ { "bubble", T_S, o_default }, \ { "tube", T_S, o_default }, \ + { "mesh", T_V, o_default }, \ + { ALIASKEY, 0, o_default }, \ { "plastic", T_M, o_default }, \ { "metal", T_M, o_default }, \ - { "source", T_S, o_default }, \ { "glass", T_M, o_default }, \ { "trans", T_M, o_default }, \ { "dielectric", T_M, o_default }, \ + { "plastic2", T_M|T_F, o_default }, \ + { "metal2", T_M|T_F, o_default }, \ + { "trans2", T_M|T_F, o_default }, \ { "interface", T_M, o_default }, \ { "plasfunc", T_M|T_F, o_default }, \ { "metfunc", T_M|T_F, o_default }, \ @@ -110,12 +144,16 @@ extern int o_default(); { "brightdata", T_P|T_D, o_default }, \ { "brighttext", T_P|T_E, o_default }, \ { "colorpict", T_P|T_I, o_default }, \ + { "glow", T_M|T_L, o_default }, \ + { "source", T_S, o_default }, \ { "light", T_M|T_L, o_default }, \ { "illum", T_M|T_L, o_default }, \ - { "glow", T_M|T_L, o_default }, \ { "spotlight", T_M|T_L, o_default }, \ + { "mist", T_M, o_default }, \ + { "mirror", T_M|T_LV, o_default }, \ { "transfunc", T_M|T_F, o_default }, \ { "BRTDfunc", T_M|T_F, o_default }, \ + { "BSDF", T_M|T_D, o_default }, \ { "plasdata", T_M|T_D, o_default }, \ { "metdata", T_M|T_D, o_default }, \ { "transdata", T_M|T_D, o_default }, \ @@ -127,6 +165,14 @@ extern int o_default(); { "mixfunc", T_X|T_F, o_default }, \ { "mixdata", T_X|T_D, o_default }, \ { "mixtext", T_X|T_E, o_default }, \ + { "mixpict", T_X|T_I, o_default }, \ + { "prism1", T_M|T_F|T_LV, o_default }, \ + { "prism2", T_M|T_F|T_LV, o_default }, \ + { "ashik2", T_M|T_F, o_default }, \ } -#define ALIASID "alias" /* alias type identifier */ + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_OTYPES_H_ */
