root/radiance/ray/src/common/otypes.h
Sun Jul 29 19:01:39 2012 UTC (11 years, 10 months ago) by greg
Diff to previous 2.16 , to selected 2.1
Changes since 2.15: +19 -19 lines
Fri Nov 21 07:15:29 2003 UTC (20 years, 6 months ago) by greg
Mon Sep 15 17:01:52 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.12: +5 -1 lines
Added FUN_ARGLIST to handle argument type checking in C++
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.10: +12 -1 lines
*** empty log message ***
Tue Mar 11 19:29:04 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.9: +50 -41 lines
Changes since 2.7: +57 -5 lines
Wed Jan 20 13:47:26 1999 UTC (25 years, 4 months ago) by gwlarson
added "mixpict" primitive
Fri Dec 8 18:16:13 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.5: +19 -17 lines
added M_MIST (mist) material type
Fri Sep 15 14:55:08 1995 UTC (28 years, 8 months ago) by greg
added isflat() macro to test for flat surface
Wed Jan 12 15:55:08 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.3: +0 -1 lines
took out istexture() macro, which is no longer valid
Thu Mar 12 11:41:20 1992 UTC (32 years, 3 months ago) by greg
volumes are no longer surfaces
Sat Jan 4 19:51:21 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +36 -30 lines
Tue Nov 12 16:54:43 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.12
Wed Jul 17 13:41:49 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.11: +5 -1 lines
Diff to previous 1.11 , to selected 2.1
added prism1 and prism2 types
Wed Jun 19 16:09:15 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.10: +38 -34 lines
Diff to previous 1.10 , to selected 2.1
added mirror material type
Tue May 7 14:53:16 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.9: +18 -14 lines
Diff to previous 1.9 , to selected 2.1
added MAT_TFUNC and MAT_TDATA types
Tue May 7 11:02:15 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.8: +14 -12 lines
Diff to previous 1.8 , to selected 2.1
added BRTDfunc type
Wed May 1 09:22:12 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.7: +4 -0 lines
Diff to previous 1.7 , to selected 2.1
added special user-defined type flags
Thu Dec 13 11:41:31 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.6: +102 -109 lines
changed initialization and structure of ofun[] & sorted list
Thu Dec 13 08:58:30 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.5: +10 -1 lines
added plasfunc, metfunc, plasdata and metdata
Fri Mar 30 09:58:33 1990 UTC (34 years, 2 months ago) by greg
added test for volumetric objects (instance currently)
Wed Jun 7 10:07:04 1989 UTC (35 years ago) by greg
Changes since 1.3: +11 -9 lines
reinstated spot type
Wed Jun 7 08:40:24 1989 UTC (35 years ago) by greg
Changes since 1.2: +9 -11 lines
No more spot type after improved direct calculation
Tue Mar 14 11:32:57 1989 UTC (35 years, 3 months ago) by greg
Changes since 1.1: +14 -12 lines
added texdata type
Thu Feb 2 10:34:19 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.1
