--- ray/src/common/otypes.h 1990/12/13 11:41:31 1.7 +++ ray/src/common/otypes.h 1991/05/07 14:53:16 1.10 @@ -40,19 +40,22 @@ typedef struct { #define MAT_LIGHT 23 /* primary light source */ #define MAT_ILLUM 24 /* secondary light source */ #define MAT_GLOW 25 /* proximity light source */ -#define MAT_PDATA 26 /* plastic brdf data */ -#define MAT_MDATA 27 /* metal brdf data */ -#define MAT_SPOT 28 /* spot light source */ -#define PAT_CFUNC 29 /* color function */ -#define MAT_CLIP 30 /* clipping surface */ -#define PAT_CDATA 31 /* color data */ -#define PAT_CTEXT 32 /* colored text */ -#define TEX_DATA 33 /* surface texture data */ -#define MIX_FUNC 34 /* mixing function */ -#define MIX_DATA 35 /* mixing data */ -#define MIX_TEXT 36 /* mixing text */ +#define MAT_SPOT 26 /* spot light source */ +#define MAT_TFUNC 27 /* trans brdf function */ +#define MAT_BRTDF 28 /* brtd function */ +#define MAT_PDATA 29 /* plastic brdf data */ +#define MAT_MDATA 30 /* metal brdf data */ +#define MAT_TDATA 31 /* trans brdf data */ +#define PAT_CFUNC 32 /* color function */ +#define MAT_CLIP 33 /* clipping surface */ +#define PAT_CDATA 34 /* color data */ +#define PAT_CTEXT 35 /* colored text */ +#define TEX_DATA 36 /* surface texture data */ +#define MIX_FUNC 37 /* mixing function */ +#define MIX_DATA 38 /* mixing data */ +#define MIX_TEXT 39 /* mixing text */ /* number of object types */ -#define NUMOTYPE 37 +#define NUMOTYPE 40 /* type flags */ #define T_S 01 /* surface (object) */ #define T_M 02 /* material */ @@ -65,6 +68,10 @@ typedef struct { #define T_D 0400 /* data */ #define T_I 01000 /* picture */ #define T_E 02000 /* text */ + /* user-defined types */ +#define T_SP1 010000 +#define T_SP2 020000 +#define T_SP3 040000 extern FUN ofun[]; /* our type list */ @@ -106,9 +113,12 @@ extern int o_default(); { "light", T_M|T_L, o_default }, \ { "illum", T_M|T_L, o_default }, \ { "glow", T_M|T_L, o_default }, \ + { "spotlight", T_M|T_L, o_default }, \ + { "transfunc", T_M|T_F, o_default }, \ + { "BRTDfunc", T_M|T_F, o_default }, \ { "plasdata", T_M|T_D, o_default }, \ { "metdata", T_M|T_D, o_default }, \ - { "spotlight", T_M|T_L, o_default }, \ + { "transdata", T_M|T_D, o_default }, \ { "colorfunc", T_P|T_F, o_default }, \ { "antimatter", T_M, o_default }, \ { "colordata", T_P|T_D, o_default }, \
