root/radiance/ray/src/common/otypes.h
Revision: 2.5
Committed: Fri Sep 15 14:55:08 1995 UTC (28 years, 9 months ago) by greg
added isflat() macro to test for flat surface
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * otypes.h - defines for object types.
7 *
8 * 1/28/86
9 */
10
11 typedef struct {
12 char *funame; /* function name */
13 int flags; /* type flags */
14 int (*funp)(); /* pointer to function */
15 } FUN;
16 /* object types in decreasing frequency */
17 #define OBJ_FACE 0 /* polygon */
18 #define OBJ_CONE 1 /* cone */
19 #define OBJ_SPHERE 2 /* sphere */
20 #define TEX_FUNC 3 /* surface texture function */
21 #define OBJ_RING 4 /* disk */
22 #define OBJ_CYLINDER 5 /* cylinder */
23 #define OBJ_INSTANCE 6 /* octree instance */
24 #define OBJ_CUP 7 /* inverted cone */
25 #define OBJ_BUBBLE 8 /* inverted sphere */
26 #define OBJ_TUBE 9 /* inverted cylinder */
27 #define MAT_PLASTIC 10 /* plastic surface */
28 #define MAT_METAL 11 /* metal surface */
29 #define MAT_GLASS 12 /* thin glass surface */
30 #define MAT_TRANS 13 /* translucent material */
31 #define MAT_DIELECTRIC 14 /* dielectric material */
32 #define MAT_PLASTIC2 15 /* anisotropic plastic */
33 #define MAT_METAL2 16 /* anisotropic metal */
34 #define MAT_TRANS2 17 /* anisotropic translucent material */
35 #define MAT_INTERFACE 18 /* dielectric interface */
36 #define MAT_PFUNC 19 /* plastic brdf function */
37 #define MAT_MFUNC 20 /* metal brdf function */
38 #define PAT_BFUNC 21 /* brightness function */
39 #define PAT_BDATA 22 /* brightness data */
40 #define PAT_BTEXT 23 /* monochromatic text */
41 #define PAT_CPICT 24 /* color picture */
42 #define MAT_GLOW 25 /* proximity light source */
43 #define OBJ_SOURCE 26 /* distant source */
44 #define MAT_LIGHT 27 /* primary light source */
45 #define MAT_ILLUM 28 /* secondary light source */
46 #define MAT_SPOT 29 /* spot light source */
47 #define MAT_MIRROR 30 /* mirror (secondary source) */
48 #define MAT_TFUNC 31 /* trans brdf function */
49 #define MAT_BRTDF 32 /* brtd function */
50 #define MAT_PDATA 33 /* plastic brdf data */
51 #define MAT_MDATA 34 /* metal brdf data */
52 #define MAT_TDATA 35 /* trans brdf data */
53 #define PAT_CFUNC 36 /* color function */
54 #define MAT_CLIP 37 /* clipping surface */
55 #define PAT_CDATA 38 /* color data */
56 #define PAT_CTEXT 39 /* colored text */
57 #define TEX_DATA 40 /* surface texture data */
58 #define MIX_FUNC 41 /* mixing function */
59 #define MIX_DATA 42 /* mixing data */
60 #define MIX_TEXT 43 /* mixing text */
61 #define MAT_DIRECT1 44 /* unidirecting material */
62 #define MAT_DIRECT2 45 /* bidirecting material */
63 /* number of object types */
64 #define NUMOTYPE 46
65 /* type flags */
66 #define T_S 01 /* surface (object) */
67 #define T_M 02 /* material */
68 #define T_P 04 /* pattern */
69 #define T_T 010 /* texture */
70 #define T_X 020 /* mixture */
71 #define T_V 040 /* volume */
72 #define T_L 0100 /* light source modifier */
73 #define T_LV 0200 /* virtual light source modifier */
74 #define T_F 0400 /* function */
75 #define T_D 01000 /* data */
76 #define T_I 02000 /* picture */
77 #define T_E 04000 /* text */
78 /* user-defined types */
79 #define T_SP1 010000
80 #define T_SP2 020000
81 #define T_SP3 040000
82
83 extern FUN ofun[]; /* our type list */
84
85 #define issurface(t) (ofun[t].flags & T_S)
86 #define isvolume(t) (ofun[t].flags & T_V)
87 #define ismodifier(t) (!(ofun[t].flags & (T_S|T_V)))
88 #define ismaterial(t) (ofun[t].flags & T_M)
89 #define islight(t) (ofun[t].flags & T_L)
90 #define isvlight(t) (ofun[t].flags & T_LV)
91 #define hasdata(t) (ofun[t].flags & (T_D|T_I))
92 #define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I))
93 #define hastext(t) (ofun[t].flags & T_E)
94 #define isflat(t) ((t)==OBJ_FACE || (t)==OBJ_RING)
95
96 extern int o_default();
97 /* type list initialization */
98 #define INIT_OTYPE { { "polygon", T_S, o_default }, \
99 { "cone", T_S, o_default }, \
100 { "sphere", T_S, o_default }, \
101 { "texfunc", T_T|T_F, o_default }, \
102 { "ring", T_S, o_default }, \
103 { "cylinder", T_S, o_default }, \
104 { "instance", T_V, o_default }, \
105 { "cup", T_S, o_default }, \
106 { "bubble", T_S, o_default }, \
107 { "tube", T_S, o_default }, \
108 { "plastic", T_M, o_default }, \
109 { "metal", T_M, o_default }, \
110 { "glass", T_M, o_default }, \
111 { "trans", T_M, o_default }, \
112 { "dielectric", T_M, o_default }, \
113 { "plastic2", T_M|T_F, o_default }, \
114 { "metal2", T_M|T_F, o_default }, \
115 { "trans2", T_M|T_F, o_default }, \
116 { "interface", T_M, o_default }, \
117 { "plasfunc", T_M|T_F, o_default }, \
118 { "metfunc", T_M|T_F, o_default }, \
119 { "brightfunc", T_P|T_F, o_default }, \
120 { "brightdata", T_P|T_D, o_default }, \
121 { "brighttext", T_P|T_E, o_default }, \
122 { "colorpict", T_P|T_I, o_default }, \
123 { "glow", T_M|T_L, o_default }, \
124 { "source", T_S, o_default }, \
125 { "light", T_M|T_L, o_default }, \
126 { "illum", T_M|T_L, o_default }, \
127 { "spotlight", T_M|T_L, o_default }, \
128 { "mirror", T_M|T_LV, o_default }, \
129 { "transfunc", T_M|T_F, o_default }, \
130 { "BRTDfunc", T_M|T_F, o_default }, \
131 { "plasdata", T_M|T_D, o_default }, \
132 { "metdata", T_M|T_D, o_default }, \
133 { "transdata", T_M|T_D, o_default }, \
134 { "colorfunc", T_P|T_F, o_default }, \
135 { "antimatter", T_M, o_default }, \
136 { "colordata", T_P|T_D, o_default }, \
137 { "colortext", T_P|T_E, o_default }, \
138 { "texdata", T_T|T_D, o_default }, \
139 { "mixfunc", T_X|T_F, o_default }, \
140 { "mixdata", T_X|T_D, o_default }, \
141 { "mixtext", T_X|T_E, o_default }, \
142 { "prism1", T_M|T_F|T_LV, o_default }, \
143 { "prism2", T_M|T_F|T_LV, o_default }, \
144 }
145
146 #define ALIASID "alias" /* alias type identifier */
