--- ray/src/common/otypes.h 1990/03/30 09:58:33 1.5 +++ ray/src/common/otypes.h 1991/05/01 09:22:12 1.8 @@ -10,111 +10,117 @@ typedef struct { char *funame; /* function name */ + int flags; /* type flags */ int (*funp)(); /* pointer to function */ } FUN; - /* surface types */ -#define OBJ_MIN 0 -#define OBJ_SOURCE (OBJ_MIN+0) /* distant source */ -#define OBJ_SPHERE (OBJ_MIN+1) /* sphere */ -#define OBJ_BUBBLE (OBJ_MIN+2) /* inverted sphere */ -#define OBJ_FACE (OBJ_MIN+3) /* polygon */ -#define OBJ_CONE (OBJ_MIN+4) /* cone */ -#define OBJ_CUP (OBJ_MIN+5) /* inverted cone */ -#define OBJ_CYLINDER (OBJ_MIN+6) /* cylinder */ -#define OBJ_TUBE (OBJ_MIN+7) /* inverted cylinder */ -#define OBJ_RING (OBJ_MIN+8) /* disk */ -#define OBJ_INSTANCE (OBJ_MIN+9) /* octree instance */ -#define OBJ_CNT 10 - /* material types */ -#define MOD_MIN MAT_MIN -#define MAT_MIN (OBJ_MIN+OBJ_CNT) -#define MAT_LIGHT (MAT_MIN+0) /* primary light source */ -#define MAT_ILLUM (MAT_MIN+1) /* secondary light source */ -#define MAT_GLOW (MAT_MIN+2) /* proximity light source */ -#define MAT_SPOT (MAT_MIN+3) /* spot light source */ -#define MAT_PLASTIC (MAT_MIN+4) /* plastic surface */ -#define MAT_METAL (MAT_MIN+5) /* metal surface */ -#define MAT_TRANS (MAT_MIN+6) /* translucent material */ -#define MAT_DIELECTRIC (MAT_MIN+7) /* dielectric material */ -#define MAT_INTERFACE (MAT_MIN+8) /* dielectric interface */ -#define MAT_GLASS (MAT_MIN+9) /* thin glass surface */ -#define MAT_CLIP (MAT_MIN+10) /* clipping surface */ -#define MAT_CNT 11 - /* textures and patterns */ -#define TP_MIN (MAT_MIN+MAT_CNT) -#define TEX_FUNC (TP_MIN+0) /* surface texture function */ -#define TEX_DATA (TP_MIN+1) /* surface texture data */ -#define PAT_CFUNC (TP_MIN+2) /* color function */ -#define PAT_BFUNC (TP_MIN+3) /* brightness function */ -#define PAT_CPICT (TP_MIN+4) /* color picture */ -#define PAT_CDATA (TP_MIN+5) /* color data */ -#define PAT_BDATA (TP_MIN+6) /* brightness data */ -#define PAT_CTEXT (TP_MIN+7) /* colored text */ -#define PAT_BTEXT (TP_MIN+8) /* monochromatic text */ -#define MIX_FUNC (TP_MIN+9) /* mixing function */ -#define MIX_DATA (TP_MIN+10) /* mixing data */ -#define MIX_TEXT (TP_MIN+11) /* mixing text */ -#define TP_CNT 12 -#define MOD_CNT (MAT_CNT+TP_CNT) + /* object types in decreasing frequency */ +#define OBJ_FACE 0 /* polygon */ +#define OBJ_CONE 1 /* cone */ +#define OBJ_SPHERE 2 /* sphere */ +#define TEX_FUNC 3 /* surface texture function */ +#define OBJ_RING 4 /* disk */ +#define OBJ_CYLINDER 5 /* cylinder */ +#define OBJ_INSTANCE 6 /* octree instance */ +#define OBJ_CUP 7 /* inverted cone */ +#define OBJ_BUBBLE 8 /* inverted sphere */ +#define OBJ_TUBE 9 /* inverted cylinder */ +#define MAT_PLASTIC 10 /* plastic surface */ +#define MAT_METAL 11 /* metal surface */ +#define OBJ_SOURCE 12 /* distant source */ +#define MAT_GLASS 13 /* thin glass surface */ +#define MAT_TRANS 14 /* translucent material */ +#define MAT_DIELECTRIC 15 /* dielectric material */ +#define MAT_INTERFACE 16 /* dielectric interface */ +#define MAT_PFUNC 17 /* plastic brdf function */ +#define MAT_MFUNC 18 /* metal brdf function */ +#define PAT_BFUNC 19 /* brightness function */ +#define PAT_BDATA 20 /* brightness data */ +#define PAT_BTEXT 21 /* monochromatic text */ +#define PAT_CPICT 22 /* color picture */ +#define MAT_LIGHT 23 /* primary light source */ +#define MAT_ILLUM 24 /* secondary light source */ +#define MAT_GLOW 25 /* proximity light source */ +#define MAT_PDATA 26 /* plastic brdf data */ +#define MAT_MDATA 27 /* metal brdf data */ +#define MAT_SPOT 28 /* spot light source */ +#define PAT_CFUNC 29 /* color function */ +#define MAT_CLIP 30 /* clipping surface */ +#define PAT_CDATA 31 /* color data */ +#define PAT_CTEXT 32 /* colored text */ +#define TEX_DATA 33 /* surface texture data */ +#define MIX_FUNC 34 /* mixing function */ +#define MIX_DATA 35 /* mixing data */ +#define MIX_TEXT 36 /* mixing text */ /* number of object types */ -#define NUMOTYPE (OBJ_CNT+MAT_CNT+TP_CNT) +#define NUMOTYPE 37 + /* type flags */ +#define T_S 01 /* surface (object) */ +#define T_M 02 /* material */ +#define T_P 04 /* pattern */ +#define T_T 010 /* texture */ +#define T_X 020 /* mixture */ +#define T_V 040 /* volume */ +#define T_L 0100 /* light source modifier */ +#define T_F 0200 /* function */ +#define T_D 0400 /* data */ +#define T_I 01000 /* picture */ +#define T_E 02000 /* text */ + /* user-defined types */ +#define T_SP1 010000 +#define T_SP2 020000 +#define T_SP3 040000 -#define issurface(t) ((t) >= OBJ_MIN && (t) < OBJ_MIN+OBJ_CNT) -#define isvolume(t) ((t) == OBJ_INSTANCE) -#define ismodifier(t) ((t) >= MOD_MIN && (t) < MOD_MIN+MOD_CNT) -#define ismaterial(t) ((t) >= MAT_MIN && (t) < MAT_MIN+MAT_CNT) -#define istexture(t) ((t) >= TP_MIN && (t) < TP_MIN+TP_CNT) +extern FUN ofun[]; /* our type list */ -extern int o_source(); -extern int o_sphere(); -extern int o_face(); -extern int o_cone(); -extern int o_instance(); -extern int m_light(); -extern int m_normal(); -extern int m_dielectric(); -extern int m_glass(); -extern int m_clip(); -extern int t_func(), t_data(); -extern int p_cfunc(), p_bfunc(); -extern int p_pdata(), p_cdata(), p_bdata(); -extern int mx_func(), mx_data(); -extern int text(); +#define issurface(t) (ofun[t].flags & T_S) +#define isvolume(t) (ofun[t].flags & T_V) +#define ismodifier(t) (!issurface(t)) +#define ismaterial(t) (ofun[t].flags & T_M) +#define istexture(t) (ofun[t].flags & (T_P|T_T|T_X)) +#define islight(t) (ofun[t].flags & T_L) +#define hasdata(t) (ofun[t].flags & (T_D|T_I)) +#define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I)) +#define hastext(t) (ofun[t].flags & T_E) -#define INIT_OTYPE { { "source", o_source }, \ - { "sphere", o_sphere }, \ - { "bubble", o_sphere }, \ - { "polygon", o_face }, \ - { "cone", o_cone }, \ - { "cup", o_cone }, \ - { "cylinder", o_cone }, \ - { "tube", o_cone }, \ - { "ring", o_cone }, \ - { "instance", o_instance }, \ - { "light", m_light }, \ - { "illum", m_light }, \ - { "glow", m_light }, \ - { "spotlight", m_light }, \ - { "plastic", m_normal }, \ - { "metal", m_normal }, \ - { "trans", m_normal }, \ - { "dielectric", m_dielectric }, \ - { "interface", m_dielectric }, \ - { "glass", m_glass }, \ - { "antimatter", m_clip }, \ - { "texfunc", t_func }, \ - { "texdata", t_data }, \ - { "colorfunc", p_cfunc }, \ - { "brightfunc", p_bfunc }, \ - { "colorpict", p_pdata }, \ - { "colordata", p_cdata }, \ - { "brightdata", p_bdata }, \ - { "colortext", text }, \ - { "brighttext", text }, \ - { "mixfunc", mx_func }, \ - { "mixdata", mx_data }, \ - { "mixtext", text } } +extern int o_default(); + /* type list initialization */ +#define INIT_OTYPE { { "polygon", T_S, o_default }, \ + { "cone", T_S, o_default }, \ + { "sphere", T_S, o_default }, \ + { "texfunc", T_T|T_F, o_default }, \ + { "ring", T_S, o_default }, \ + { "cylinder", T_S, o_default }, \ + { "instance", T_S|T_V, o_default }, \ + { "cup", T_S, o_default }, \ + { "bubble", T_S, o_default }, \ + { "tube", T_S, o_default }, \ + { "plastic", T_M, o_default }, \ + { "metal", T_M, o_default }, \ + { "source", T_S, o_default }, \ + { "glass", T_M, o_default }, \ + { "trans", T_M, o_default }, \ + { "dielectric", T_M, o_default }, \ + { "interface", T_M, o_default }, \ + { "plasfunc", T_M|T_F, o_default }, \ + { "metfunc", T_M|T_F, o_default }, \ + { "brightfunc", T_P|T_F, o_default }, \ + { "brightdata", T_P|T_D, o_default }, \ + { "brighttext", T_P|T_E, o_default }, \ + { "colorpict", T_P|T_I, o_default }, \ + { "light", T_M|T_L, o_default }, \ + { "illum", T_M|T_L, o_default }, \ + { "glow", T_M|T_L, o_default }, \ + { "plasdata", T_M|T_D, o_default }, \ + { "metdata", T_M|T_D, o_default }, \ + { "spotlight", T_M|T_L, o_default }, \ + { "colorfunc", T_P|T_F, o_default }, \ + { "antimatter", T_M, o_default }, \ + { "colordata", T_P|T_D, o_default }, \ + { "colortext", T_P|T_E, o_default }, \ + { "texdata", T_T|T_D, o_default }, \ + { "mixfunc", T_X|T_F, o_default }, \ + { "mixdata", T_X|T_D, o_default }, \ + { "mixtext", T_X|T_E, o_default }, \ + } #define ALIASID "alias" /* alias type identifier */ - -extern FUN ofun[];
