--- ray/src/common/otypes.h 1989/06/07 08:40:24 1.3 +++ ray/src/common/otypes.h 2003/02/22 02:07:22 2.8 @@ -1,117 +1,202 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: otypes.h,v 2.8 2003/02/22 02:07:22 greg Exp $ */ /* * otypes.h - defines for object types. + */ + +/* ==================================================================== + * The Radiance Software License, Version 1.0 * - * 1/28/86 + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . */ typedef struct { char *funame; /* function name */ + int flags; /* type flags */ int (*funp)(); /* pointer to function */ } FUN; - /* surface types */ -#define OBJ_MIN 0 -#define OBJ_SOURCE (OBJ_MIN+0) /* distant source */ -#define OBJ_SPHERE (OBJ_MIN+1) /* sphere */ -#define OBJ_BUBBLE (OBJ_MIN+2) /* inverted sphere */ -#define OBJ_FACE (OBJ_MIN+3) /* polygon */ -#define OBJ_CONE (OBJ_MIN+4) /* cone */ -#define OBJ_CUP (OBJ_MIN+5) /* inverted cone */ -#define OBJ_CYLINDER (OBJ_MIN+6) /* cylinder */ -#define OBJ_TUBE (OBJ_MIN+7) /* inverted cylinder */ -#define OBJ_RING (OBJ_MIN+8) /* disk */ -#define OBJ_INSTANCE (OBJ_MIN+9) /* octree instance */ -#define OBJ_CNT 10 - /* material types */ -#define MOD_MIN MAT_MIN -#define MAT_MIN (OBJ_MIN+OBJ_CNT) -#define MAT_LIGHT (MAT_MIN+0) /* primary light source */ -#define MAT_ILLUM (MAT_MIN+1) /* secondary light source */ -#define MAT_GLOW (MAT_MIN+2) /* emmissive non-source */ -#define MAT_PLASTIC (MAT_MIN+3) /* plastic surface */ -#define MAT_METAL (MAT_MIN+4) /* metal surface */ -#define MAT_TRANS (MAT_MIN+5) /* translucent material */ -#define MAT_DIELECTRIC (MAT_MIN+6) /* dielectric material */ -#define MAT_INTERFACE (MAT_MIN+7) /* dielectric interface */ -#define MAT_GLASS (MAT_MIN+8) /* thin glass surface */ -#define MAT_CLIP (MAT_MIN+9) /* clipping surface */ -#define MAT_CNT 10 - /* textures and patterns */ -#define TP_MIN (MAT_MIN+MAT_CNT) -#define TEX_FUNC (TP_MIN+0) /* surface texture function */ -#define TEX_DATA (TP_MIN+1) /* surface texture data */ -#define PAT_CFUNC (TP_MIN+2) /* color function */ -#define PAT_BFUNC (TP_MIN+3) /* brightness function */ -#define PAT_CPICT (TP_MIN+4) /* color picture */ -#define PAT_CDATA (TP_MIN+5) /* color data */ -#define PAT_BDATA (TP_MIN+6) /* brightness data */ -#define PAT_CTEXT (TP_MIN+7) /* colored text */ -#define PAT_BTEXT (TP_MIN+8) /* monochromatic text */ -#define MIX_FUNC (TP_MIN+9) /* mixing function */ -#define MIX_DATA (TP_MIN+10) /* mixing data */ -#define MIX_TEXT (TP_MIN+11) /* mixing text */ -#define TP_CNT 12 -#define MOD_CNT (MAT_CNT+TP_CNT) + /* object types in decreasing frequency */ +#define OBJ_FACE 0 /* polygon */ +#define OBJ_CONE 1 /* cone */ +#define OBJ_SPHERE 2 /* sphere */ +#define TEX_FUNC 3 /* surface texture function */ +#define OBJ_RING 4 /* disk */ +#define OBJ_CYLINDER 5 /* cylinder */ +#define OBJ_INSTANCE 6 /* octree instance */ +#define OBJ_CUP 7 /* inverted cone */ +#define OBJ_BUBBLE 8 /* inverted sphere */ +#define OBJ_TUBE 9 /* inverted cylinder */ +#define MAT_PLASTIC 10 /* plastic surface */ +#define MAT_METAL 11 /* metal surface */ +#define MAT_GLASS 12 /* thin glass surface */ +#define MAT_TRANS 13 /* translucent material */ +#define MAT_DIELECTRIC 14 /* dielectric material */ +#define MAT_PLASTIC2 15 /* anisotropic plastic */ +#define MAT_METAL2 16 /* anisotropic metal */ +#define MAT_TRANS2 17 /* anisotropic translucent material */ +#define MAT_INTERFACE 18 /* dielectric interface */ +#define MAT_PFUNC 19 /* plastic brdf function */ +#define MAT_MFUNC 20 /* metal brdf function */ +#define PAT_BFUNC 21 /* brightness function */ +#define PAT_BDATA 22 /* brightness data */ +#define PAT_BTEXT 23 /* monochromatic text */ +#define PAT_CPICT 24 /* color picture */ +#define MAT_GLOW 25 /* proximity light source */ +#define OBJ_SOURCE 26 /* distant source */ +#define MAT_LIGHT 27 /* primary light source */ +#define MAT_ILLUM 28 /* secondary light source */ +#define MAT_SPOT 29 /* spot light source */ +#define MAT_MIST 30 /* mist medium */ +#define MAT_MIRROR 31 /* mirror (secondary source) */ +#define MAT_TFUNC 32 /* trans brdf function */ +#define MAT_BRTDF 33 /* brtd function */ +#define MAT_PDATA 34 /* plastic brdf data */ +#define MAT_MDATA 35 /* metal brdf data */ +#define MAT_TDATA 36 /* trans brdf data */ +#define PAT_CFUNC 37 /* color function */ +#define MAT_CLIP 38 /* clipping surface */ +#define PAT_CDATA 39 /* color data */ +#define PAT_CTEXT 40 /* colored text */ +#define TEX_DATA 41 /* surface texture data */ +#define MIX_FUNC 42 /* mixing function */ +#define MIX_DATA 43 /* mixing data */ +#define MIX_TEXT 44 /* mixing text */ +#define MIX_PICT 45 /* mixing picture */ +#define MAT_DIRECT1 46 /* unidirecting material */ +#define MAT_DIRECT2 47 /* bidirecting material */ /* number of object types */ -#define NUMOTYPE (OBJ_CNT+MAT_CNT+TP_CNT) +#define NUMOTYPE 48 + /* type flags */ +#define T_S 01 /* surface (object) */ +#define T_M 02 /* material */ +#define T_P 04 /* pattern */ +#define T_T 010 /* texture */ +#define T_X 020 /* mixture */ +#define T_V 040 /* volume */ +#define T_L 0100 /* light source modifier */ +#define T_LV 0200 /* virtual light source modifier */ +#define T_F 0400 /* function */ +#define T_D 01000 /* data */ +#define T_I 02000 /* picture */ +#define T_E 04000 /* text */ + /* user-defined types */ +#define T_SP1 010000 +#define T_SP2 020000 +#define T_SP3 040000 -#define issurface(t) ((t) >= OBJ_MIN && (t) < OBJ_MIN+OBJ_CNT) -#define ismodifier(t) ((t) >= MOD_MIN && (t) < MOD_MIN+MOD_CNT) -#define ismaterial(t) ((t) >= MAT_MIN && (t) < MAT_MIN+MAT_CNT) -#define istexture(t) ((t) >= TP_MIN && (t) < TP_MIN+TP_CNT) +extern FUN ofun[]; /* our type list */ -extern int o_source(); -extern int o_sphere(); -extern int o_face(); -extern int o_cone(); -extern int o_instance(); -extern int m_light(); -extern int m_normal(); -extern int m_dielectric(); -extern int m_glass(); -extern int m_clip(); -extern int t_func(), t_data(); -extern int p_cfunc(), p_bfunc(); -extern int p_pdata(), p_cdata(), p_bdata(); -extern int mx_func(), mx_data(); -extern int text(); +#define issurface(t) (ofun[t].flags & T_S) +#define isvolume(t) (ofun[t].flags & T_V) +#define ismodifier(t) (!(ofun[t].flags & (T_S|T_V))) +#define ismaterial(t) (ofun[t].flags & T_M) +#define islight(t) (ofun[t].flags & T_L) +#define isvlight(t) (ofun[t].flags & T_LV) +#define hasdata(t) (ofun[t].flags & (T_D|T_I)) +#define hasfunc(t) (ofun[t].flags & (T_F|T_D|T_I)) +#define hastext(t) (ofun[t].flags & T_E) +#define isflat(t) ((t)==OBJ_FACE || (t)==OBJ_RING) -#define INIT_OTYPE { { "source", o_source }, \ - { "sphere", o_sphere }, \ - { "bubble", o_sphere }, \ - { "polygon", o_face }, \ - { "cone", o_cone }, \ - { "cup", o_cone }, \ - { "cylinder", o_cone }, \ - { "tube", o_cone }, \ - { "ring", o_cone }, \ - { "instance", o_instance }, \ - { "light", m_light }, \ - { "illum", m_light }, \ - { "glow", m_light }, \ - { "plastic", m_normal }, \ - { "metal", m_normal }, \ - { "trans", m_normal }, \ - { "dielectric", m_dielectric }, \ - { "interface", m_dielectric }, \ - { "glass", m_glass }, \ - { "antimatter", m_clip }, \ - { "texfunc", t_func }, \ - { "texdata", t_data }, \ - { "colorfunc", p_cfunc }, \ - { "brightfunc", p_bfunc }, \ - { "colorpict", p_pdata }, \ - { "colordata", p_cdata }, \ - { "brightdata", p_bdata }, \ - { "colortext", text }, \ - { "brighttext", text }, \ - { "mixfunc", mx_func }, \ - { "mixdata", mx_data }, \ - { "mixtext", text } } +extern int o_default(); + /* type list initialization */ +#define INIT_OTYPE { { "polygon", T_S, o_default }, \ + { "cone", T_S, o_default }, \ + { "sphere", T_S, o_default }, \ + { "texfunc", T_T|T_F, o_default }, \ + { "ring", T_S, o_default }, \ + { "cylinder", T_S, o_default }, \ + { "instance", T_V, o_default }, \ + { "cup", T_S, o_default }, \ + { "bubble", T_S, o_default }, \ + { "tube", T_S, o_default }, \ + { "plastic", T_M, o_default }, \ + { "metal", T_M, o_default }, \ + { "glass", T_M, o_default }, \ + { "trans", T_M, o_default }, \ + { "dielectric", T_M, o_default }, \ + { "plastic2", T_M|T_F, o_default }, \ + { "metal2", T_M|T_F, o_default }, \ + { "trans2", T_M|T_F, o_default }, \ + { "interface", T_M, o_default }, \ + { "plasfunc", T_M|T_F, o_default }, \ + { "metfunc", T_M|T_F, o_default }, \ + { "brightfunc", T_P|T_F, o_default }, \ + { "brightdata", T_P|T_D, o_default }, \ + { "brighttext", T_P|T_E, o_default }, \ + { "colorpict", T_P|T_I, o_default }, \ + { "glow", T_M|T_L, o_default }, \ + { "source", T_S, o_default }, \ + { "light", T_M|T_L, o_default }, \ + { "illum", T_M|T_L, o_default }, \ + { "spotlight", T_M|T_L, o_default }, \ + { "mist", T_M, o_default }, \ + { "mirror", T_M|T_LV, o_default }, \ + { "transfunc", T_M|T_F, o_default }, \ + { "BRTDfunc", T_M|T_F, o_default }, \ + { "plasdata", T_M|T_D, o_default }, \ + { "metdata", T_M|T_D, o_default }, \ + { "transdata", T_M|T_D, o_default }, \ + { "colorfunc", T_P|T_F, o_default }, \ + { "antimatter", T_M, o_default }, \ + { "colordata", T_P|T_D, o_default }, \ + { "colortext", T_P|T_E, o_default }, \ + { "texdata", T_T|T_D, o_default }, \ + { "mixfunc", T_X|T_F, o_default }, \ + { "mixdata", T_X|T_D, o_default }, \ + { "mixtext", T_X|T_E, o_default }, \ + { "mixpict", T_X|T_I, o_default }, \ + { "prism1", T_M|T_F|T_LV, o_default }, \ + { "prism2", T_M|T_F|T_LV, o_default }, \ + } #define ALIASID "alias" /* alias type identifier */ - -extern FUN ofun[];
