root/radiance/ray/src/common/otypes.h
Revision: 1.2
Committed: Tue Mar 14 11:32:57 1989 UTC (35 years, 3 months ago) by greg
Changes since 1.1: +14 -12 lines
added texdata type
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * otypes.h - defines for object types.
7 *
8 * 1/28/86
9 */
10
11 typedef struct {
12 char *funame; /* function name */
13 int (*funp)(); /* pointer to function */
14 } FUN;
15 /* surface types */
16 #define OBJ_MIN 0
17 #define OBJ_SOURCE (OBJ_MIN+0) /* distant source */
18 #define OBJ_SPHERE (OBJ_MIN+1) /* sphere */
19 #define OBJ_BUBBLE (OBJ_MIN+2) /* inverted sphere */
20 #define OBJ_FACE (OBJ_MIN+3) /* polygon */
21 #define OBJ_CONE (OBJ_MIN+4) /* cone */
22 #define OBJ_CUP (OBJ_MIN+5) /* inverted cone */
23 #define OBJ_CYLINDER (OBJ_MIN+6) /* cylinder */
24 #define OBJ_TUBE (OBJ_MIN+7) /* inverted cylinder */
25 #define OBJ_RING (OBJ_MIN+8) /* disk */
26 #define OBJ_INSTANCE (OBJ_MIN+9) /* octree instance */
27 #define OBJ_CNT 10
28 /* material types */
29 #define MOD_MIN MAT_MIN
30 #define MAT_MIN (OBJ_MIN+OBJ_CNT)
31 #define MAT_LIGHT (MAT_MIN+0) /* primary light source */
32 #define MAT_ILLUM (MAT_MIN+1) /* secondary light source */
33 #define MAT_GLOW (MAT_MIN+2) /* proximity light source */
34 #define MAT_SPOT (MAT_MIN+3) /* spot light source */
35 #define MAT_PLASTIC (MAT_MIN+4) /* plastic surface */
36 #define MAT_METAL (MAT_MIN+5) /* metal surface */
37 #define MAT_TRANS (MAT_MIN+6) /* translucent material */
38 #define MAT_DIELECTRIC (MAT_MIN+7) /* dielectric material */
39 #define MAT_INTERFACE (MAT_MIN+8) /* dielectric interface */
40 #define MAT_GLASS (MAT_MIN+9) /* thin glass surface */
41 #define MAT_CLIP (MAT_MIN+10) /* clipping surface */
42 #define MAT_CNT 11
43 /* textures and patterns */
44 #define TP_MIN (MAT_MIN+MAT_CNT)
45 #define TEX_FUNC (TP_MIN+0) /* surface texture function */
46 #define TEX_DATA (TP_MIN+1) /* surface texture data */
47 #define PAT_CFUNC (TP_MIN+2) /* color function */
48 #define PAT_BFUNC (TP_MIN+3) /* brightness function */
49 #define PAT_CPICT (TP_MIN+4) /* color picture */
50 #define PAT_CDATA (TP_MIN+5) /* color data */
51 #define PAT_BDATA (TP_MIN+6) /* brightness data */
52 #define PAT_CTEXT (TP_MIN+7) /* colored text */
53 #define PAT_BTEXT (TP_MIN+8) /* monochromatic text */
54 #define MIX_FUNC (TP_MIN+9) /* mixing function */
55 #define MIX_DATA (TP_MIN+10) /* mixing data */
56 #define MIX_TEXT (TP_MIN+11) /* mixing text */
57 #define TP_CNT 12
58 #define MOD_CNT (MAT_CNT+TP_CNT)
59 /* number of object types */
60 #define NUMOTYPE (OBJ_CNT+MAT_CNT+TP_CNT)
61
62 #define issurface(t) ((t) >= OBJ_MIN && (t) < OBJ_MIN+OBJ_CNT)
63 #define ismodifier(t) ((t) >= MOD_MIN && (t) < MOD_MIN+MOD_CNT)
64 #define ismaterial(t) ((t) >= MAT_MIN && (t) < MAT_MIN+MAT_CNT)
65 #define istexture(t) ((t) >= TP_MIN && (t) < TP_MIN+TP_CNT)
66
67 extern int o_source();
68 extern int o_sphere();
69 extern int o_face();
70 extern int o_cone();
71 extern int o_instance();
72 extern int m_light();
73 extern int m_normal();
74 extern int m_dielectric();
75 extern int m_glass();
76 extern int m_clip();
77 extern int t_func(), t_data();
78 extern int p_cfunc(), p_bfunc();
79 extern int p_pdata(), p_cdata(), p_bdata();
80 extern int mx_func(), mx_data();
81 extern int text();
82
83 #define INIT_OTYPE { { "source", o_source }, \
84 { "sphere", o_sphere }, \
85 { "bubble", o_sphere }, \
86 { "polygon", o_face }, \
87 { "cone", o_cone }, \
88 { "cup", o_cone }, \
89 { "cylinder", o_cone }, \
90 { "tube", o_cone }, \
91 { "ring", o_cone }, \
92 { "instance", o_instance }, \
93 { "light", m_light }, \
94 { "illum", m_light }, \
95 { "glow", m_light }, \
96 { "spotlight", m_light }, \
97 { "plastic", m_normal }, \
98 { "metal", m_normal }, \
99 { "trans", m_normal }, \
100 { "dielectric", m_dielectric }, \
101 { "interface", m_dielectric }, \
102 { "glass", m_glass }, \
103 { "antimatter", m_clip }, \
104 { "texfunc", t_func }, \
105 { "texdata", t_data }, \
106 { "colorfunc", p_cfunc }, \
107 { "brightfunc", p_bfunc }, \
108 { "colorpict", p_pdata }, \
109 { "colordata", p_cdata }, \
110 { "brightdata", p_bdata }, \
111 { "colortext", text }, \
112 { "brighttext", text }, \
113 { "mixfunc", mx_func }, \
114 { "mixdata", mx_data }, \
115 { "mixtext", text } }
116
117 #define ALIASID "alias" /* alias type identifier */
118
119 extern FUN ofun[];
