root/radiance/ray/src/common/octree.h
Revision: 2.5
Committed: Sat Feb 22 02:07:22 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.4: +83 -7 lines
1 /* RCSid: $Id$ */
2 /*
3 * octree.h - header file for routines using octrees.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 /*
64 * An octree is expressed as an integer which is either
65 * an index to eight other nodes, the empty tree, or an index
66 * to a set of objects. If the octree has a value:
67 *
68 * > -1: it is an index to eight other nodes.
69 *
70 * -1: it is empty
71 *
72 * < -1: it is an index to a set of objects
73 */
74
75 #ifndef OCTREE
76 #define OCTREE int
77 #endif
78
79 #define EMPTY (-1)
80
81 #define isempty(ot) ((ot) == EMPTY)
82 #define isfull(ot) ((ot) < EMPTY)
83 #define istree(ot) ((ot) > EMPTY)
84
85 #define oseti(ot) (-(ot)-2) /* object set index */
86 #define OCTBLKSIZ 04000 /* octree block size */
87 #define octbi(ot) ((ot)>>11) /* octree block index */
88 #define octti(ot) (((ot)&03777)<<3)/* octree index in block */
89
90 #ifndef MAXOBLK
91 #ifdef BIGMEM
92 #define MAXOBLK 32767 /* maximum octree block */
93 #else
94 #define MAXOBLK 4095 /* maximum octree block */
95 #endif
96 #endif
97
98 extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
99
100 #define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
101
102 /*
103 * The cube structure is used to hold an octree and its cubic
104 * boundaries.
105 */
106
107 typedef struct {
108 OCTREE cutree; /* the octree for this cube */
109 FVECT cuorg; /* the cube origin */
110 double cusize; /* the cube size */
111 } CUBE;
112
113 extern CUBE thescene; /* the main scene */
114
115 /* flags for reading and writing octrees */
116 #define IO_CHECK 0 /* verify file type */
117 #define IO_INFO 01 /* information header */
118 #define IO_SCENE 02 /* objects */
119 #define IO_TREE 04 /* octree */
120 #define IO_FILES 010 /* object file names */
121 #define IO_BOUNDS 020 /* octree boundary */
122 #define IO_ALL (~0) /* everything */
123 /* octree format identifier */
124 #define OCTFMT "Radiance_octree"
125 /* magic number for octree files */
126 #define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
127 #define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
128 /* octree node types */
129 #define OT_EMPTY 0
130 #define OT_FULL 1
131 #define OT_TREE 2
132 /* return values for surface functions */
133 #define O_MISS 0 /* no intersection */
134 #define O_HIT 1 /* intersection */
135 #define O_IN 2 /* cube contained entirely */
136
137 #ifdef NOPROTO
138
139 extern OCTREE octalloc();
140 extern void octfree();
141 extern void octdone();
142 extern OCTREE combine();
143 extern void culocate();
144 extern void cucopy();
145 extern int incube();
146
147 extern int readoct();
148
149 #else
150
151 extern OCTREE octalloc(void);
152 extern void octfree(OCTREE ot);
153 extern void octdone(void);
154 extern OCTREE combine(OCTREE ot);
155 extern void culocate(CUBE *cu, FVECT pt);
156 extern void cucopy(CUBE *cu1, CUBE *cu2);
157 extern int incube(CUBE *cu, FVECT pt);
158
159 extern int readoct(char *fname, int load, CUBE *scene, char *ofn[]);
160
161 #endif
