root/Development/ray/src/common/octree.h
Revision: 2.12
Committed: Sun Nov 1 04:41:55 2009 UTC (16 years ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad4R2P2
Changes since 2.11: +1 -2 lines
Deleted unused cucopy() routine
# User Rev Content
1 greg 2.12 /* RCSid $Id: octree.h,v 2.11 2005/09/23 19:04:52 greg Exp $ */
2 greg 1.1 /*
3     * octree.h - header file for routines using octrees.
4 greg 2.5 */
5 schorsch 2.9 #ifndef _RAD_OCTREE_H_
6     #define _RAD_OCTREE_H_
7     #ifdef __cplusplus
8     extern "C" {
9     #endif
10 greg 1.1
11     /*
12     * An octree is expressed as an integer which is either
13     * an index to eight other nodes, the empty tree, or an index
14     * to a set of objects. If the octree has a value:
15     *
16     * > -1: it is an index to eight other nodes.
17     *
18     * -1: it is empty
19     *
20     * < -1: it is an index to a set of objects
21     */
22
23 greg 1.5 #ifndef OCTREE
24     #define OCTREE int
25     #endif
26 greg 1.1
27     #define EMPTY (-1)
28
29     #define isempty(ot) ((ot) == EMPTY)
30     #define isfull(ot) ((ot) < EMPTY)
31     #define istree(ot) ((ot) > EMPTY)
32
33     #define oseti(ot) (-(ot)-2) /* object set index */
34 gwlarson 2.4 #define OCTBLKSIZ 04000 /* octree block size */
35     #define octbi(ot) ((ot)>>11) /* octree block index */
36     #define octti(ot) (((ot)&03777)<<3)/* octree index in block */
37 greg 1.1
38 greg 1.5 #ifndef MAXOBLK
39 greg 2.8 #ifdef SMLMEM
40     #define MAXOBLK 4095 /* maximum octree block */
41     #else
42 gwlarson 2.4 #define MAXOBLK 32767 /* maximum octree block */
43 greg 1.5 #endif
44     #endif
45 greg 1.1
46     extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
47
48     #define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
49
50     /*
51     * The cube structure is used to hold an octree and its cubic
52     * boundaries.
53     */
54
55     typedef struct {
56     FVECT cuorg; /* the cube origin */
57     double cusize; /* the cube size */
58 greg 2.11 OCTREE cutree; /* the octree for this cube */
59 greg 1.1 } CUBE;
60
61     extern CUBE thescene; /* the main scene */
62
63     /* flags for reading and writing octrees */
64     #define IO_CHECK 0 /* verify file type */
65     #define IO_INFO 01 /* information header */
66     #define IO_SCENE 02 /* objects */
67     #define IO_TREE 04 /* octree */
68     #define IO_FILES 010 /* object file names */
69     #define IO_BOUNDS 020 /* octree boundary */
70     #define IO_ALL (~0) /* everything */
71 greg 1.4 /* octree format identifier */
72     #define OCTFMT "Radiance_octree"
73 greg 1.1 /* magic number for octree files */
74 greg 1.5 #define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
75     #define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
76 greg 1.1 /* octree node types */
77     #define OT_EMPTY 0
78     #define OT_FULL 1
79     #define OT_TREE 2
80 greg 1.2 /* return values for surface functions */
81     #define O_MISS 0 /* no intersection */
82     #define O_HIT 1 /* intersection */
83     #define O_IN 2 /* cube contained entirely */
84 greg 2.5
85
86     extern OCTREE octalloc(void);
87     extern void octfree(OCTREE ot);
88     extern void octdone(void);
89     extern OCTREE combine(OCTREE ot);
90     extern void culocate(CUBE *cu, FVECT pt);
91     extern int incube(CUBE *cu, FVECT pt);
92
93     extern int readoct(char *fname, int load, CUBE *scene, char *ofn[]);
94 greg 2.7
95     extern void readscene(FILE *fp, int objsiz);
96     extern void writescene(int firstobj, int nobjs, FILE *fp);
97 greg 2.5
98 schorsch 2.9
99     #ifdef __cplusplus
100     }
101 greg 2.5 #endif
102 schorsch 2.9 #endif /* _RAD_OCTREE_H_ */
103
