root/radiance/ray/src/common/octree.h
Sun Nov 1 04:41:55 2009 UTC (14 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 2.11: +1 -2 lines
Diff to previous 2.11 , to selected 1.3
Deleted unused cucopy() routine
Fri Sep 23 19:04:52 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: rad3R8, rad3R9
Diff to previous 2.10 , to selected 1.3
Changes since 2.9: +1 -3 lines
Diff to previous 2.9 , to selected 1.3
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.8: +11 -15 lines
Diff to previous 2.8 , to selected 1.3
*** empty log message ***
Diff to previous 2.7 , to selected 1.3
Fri Mar 14 21:27:46 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.6: +5 -1 lines
Diff to previous 2.6 , to selected 1.3
Changes since 2.5: +2 -57 lines
Diff to previous 2.5 , to selected 1.3
Changes since 2.4: +83 -7 lines
Diff to previous 2.4 , to selected 1.3
Mon Aug 24 16:38:44 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.3: +5 -4 lines
Diff to previous 2.3 , to selected 1.3
changed octree block size and increased node limit to 100 million leaves
Wed Dec 3 11:03:51 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 2.2 , to selected 1.3
increased table sizes
Fri Sep 3 16:32:29 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 1.3
increased octree limits on big memory machines
Tue Nov 12 16:55:30 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 1.3
Wed Oct 23 11:53:36 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.4: +11 -2 lines
Diff to previous 1.4 , to selected 1.3
added conditional sizing of structures from BIGMEM
made reading of foreign octrees more flexible
Thu Apr 18 12:54:26 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +2 -0 lines
Diff to previous 1.3
added format info to headers
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Sep 6 23:32:39 1990 UTC (33 years, 8 months ago) by greg
Diff to previous 1.2
added consistency checks to detect stale octrees
Sat Oct 14 11:25:18 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.1: +4 -0 lines
Diff to previous 1.1 , to selected 1.3
Added return values for surface intersection functions.
Thu Feb 2 10:34:18 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.3
