| 1 |
/* RCSid $Id: octree.h,v 2.9 2003/06/06 16:38:47 schorsch Exp $ */
| 2 |
| 3 |
* octree.h - header file for routines using octrees.
| 4 |
| 5 |
#ifndef _RAD_OCTREE_H_
| 6 |
#define _RAD_OCTREE_H_
| 7 |
#ifdef __cplusplus
| 8 |
extern "C" {
| 9 |
#endif
| 10 |
| 11 |
| 12 |
* An octree is expressed as an integer which is either
| 13 |
* an index to eight other nodes, the empty tree, or an index
| 14 |
* to a set of objects. If the octree has a value:
| 15 |
| 16 |
* > -1: it is an index to eight other nodes.
| 17 |
| 18 |
* -1: it is empty
| 19 |
| 20 |
* < -1: it is an index to a set of objects
| 21 |
| 22 |
| 23 |
#ifndef OCTREE
| 24 |
#define OCTREE int
| 25 |
#endif
| 26 |
| 27 |
#define EMPTY (-1)
| 28 |
| 29 |
#define isempty(ot) ((ot) == EMPTY)
| 30 |
#define isfull(ot) ((ot) < EMPTY)
| 31 |
#define istree(ot) ((ot) > EMPTY)
| 32 |
| 33 |
#define oseti(ot) (-(ot)-2) /* object set index */
| 34 |
#define OCTBLKSIZ 04000 /* octree block size */
| 35 |
#define octbi(ot) ((ot)>>11) /* octree block index */
| 36 |
#define octti(ot) (((ot)&03777)<<3)/* octree index in block */
| 37 |
| 38 |
#ifndef MAXOBLK
| 39 |
#ifdef SMLMEM
| 40 |
#define MAXOBLK 4095 /* maximum octree block */
| 41 |
#else
| 42 |
#define MAXOBLK 32767 /* maximum octree block */
| 43 |
#endif
| 44 |
#endif
| 45 |
| 46 |
extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
| 47 |
| 48 |
#define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
| 49 |
| 50 |
| 51 |
* The cube structure is used to hold an octree and its cubic
| 52 |
* boundaries.
| 53 |
| 54 |
| 55 |
typedef struct {
| 56 |
OCTREE cutree; /* the octree for this cube */
| 57 |
FVECT cuorg; /* the cube origin */
| 58 |
double cusize; /* the cube size */
| 59 |
} CUBE;
| 60 |
| 61 |
extern CUBE thescene; /* the main scene */
| 62 |
| 63 |
/* flags for reading and writing octrees */
| 64 |
#define IO_CHECK 0 /* verify file type */
| 65 |
#define IO_INFO 01 /* information header */
| 66 |
#define IO_SCENE 02 /* objects */
| 67 |
#define IO_TREE 04 /* octree */
| 68 |
#define IO_FILES 010 /* object file names */
| 69 |
#define IO_BOUNDS 020 /* octree boundary */
| 70 |
#define IO_ALL (~0) /* everything */
| 71 |
/* octree format identifier */
| 72 |
#define OCTFMT "Radiance_octree"
| 73 |
/* magic number for octree files */
| 74 |
#define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
| 75 |
#define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
| 76 |
/* octree node types */
| 77 |
#define OT_EMPTY 0
| 78 |
#define OT_FULL 1
| 79 |
#define OT_TREE 2
| 80 |
/* return values for surface functions */
| 81 |
#define O_MISS 0 /* no intersection */
| 82 |
#define O_HIT 1 /* intersection */
| 83 |
#define O_IN 2 /* cube contained entirely */
| 84 |
| 85 |
| 86 |
extern OCTREE octalloc(void);
| 87 |
extern void octfree(OCTREE ot);
| 88 |
extern void octdone(void);
| 89 |
extern OCTREE combine(OCTREE ot);
| 90 |
extern void culocate(CUBE *cu, FVECT pt);
| 91 |
extern void cucopy(CUBE *cu1, CUBE *cu2);
| 92 |
extern int incube(CUBE *cu, FVECT pt);
| 93 |
| 94 |
extern int readoct(char *fname, int load, CUBE *scene, char *ofn[]);
| 95 |
| 96 |
extern void readscene(FILE *fp, int objsiz);
| 97 |
extern void writescene(int firstobj, int nobjs, FILE *fp);
| 98 |
| 99 |
| 100 |
#ifdef __cplusplus
| 101 |
| 102 |
#endif
| 103 |
#endif /* _RAD_OCTREE_H_ */
| 104 |
