--- ray/src/common/octree.h 2003/03/14 21:27:46 2.7 +++ ray/src/common/octree.h 2003/06/06 16:38:47 2.9 @@ -1,7 +1,12 @@ -/* RCSid $Id: octree.h,v 2.7 2003/03/14 21:27:46 greg Exp $ */ +/* RCSid $Id: octree.h,v 2.9 2003/06/06 16:38:47 schorsch Exp $ */ /* * octree.h - header file for routines using octrees. */ +#ifndef _RAD_OCTREE_H_ +#define _RAD_OCTREE_H_ +#ifdef __cplusplus +extern "C" { +#endif #include "copyright.h" @@ -33,10 +38,10 @@ #define octti(ot) (((ot)&03777)<<3)/* octree index in block */ #ifndef MAXOBLK -#ifdef BIGMEM -#define MAXOBLK 32767 /* maximum octree block */ -#else +#ifdef SMLMEM #define MAXOBLK 4095 /* maximum octree block */ +#else +#define MAXOBLK 32767 /* maximum octree block */ #endif #endif @@ -79,21 +84,7 @@ extern CUBE thescene; /* the main scene */ #define O_HIT 1 /* intersection */ #define O_IN 2 /* cube contained entirely */ -#ifdef NOPROTO -extern OCTREE octalloc(); -extern void octfree(); -extern void octdone(); -extern OCTREE combine(); -extern void culocate(); -extern void cucopy(); -extern int incube(); -extern int readoct(); -extern void readscene(); -extern void writescene(); - -#else - extern OCTREE octalloc(void); extern void octfree(OCTREE ot); extern void octdone(void); @@ -107,4 +98,9 @@ extern int readoct(char *fname, int load, CUBE *scene, extern void readscene(FILE *fp, int objsiz); extern void writescene(int firstobj, int nobjs, FILE *fp); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_OCTREE_H_ */ +
