root/radiance/ray/src/common/octree.h
Revision: 2.13
Committed: Fri Mar 17 18:27:18 2023 UTC (2 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
Error occurred while calculating annotation data.
perf: Increased scene size limits
1 /* RCSid $Id: octree.h,v 2.12 2009/11/01 04:41:55 greg Exp $ */
2 /*
3 * octree.h - header file for routines using octrees.
4 */
5 #ifndef _RAD_OCTREE_H_
6 #define _RAD_OCTREE_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 /*
12 * An octree is expressed as an integer which is either
13 * an index to eight other nodes, the empty tree, or an index
14 * to a set of objects. If the octree has a value:
15 *
16 * > -1: it is an index to eight other nodes.
17 *
18 * -1: it is empty
19 *
20 * < -1: it is an index to a set of objects
21 */
22
23 #ifndef OCTREE
24 #define OCTREE int
25 #endif
26
27 #define EMPTY (-1)
28
29 #define isempty(ot) ((ot) == EMPTY)
30 #define isfull(ot) ((ot) < EMPTY)
31 #define istree(ot) ((ot) > EMPTY)
32
33 #define oseti(ot) (-(ot)-2) /* object set index */
34 #define OCTBLKSIZ 04000 /* octree block size */
35 #define octbi(ot) ((ot)>>11) /* octree block index */
36 #define octti(ot) (((ot)&03777)<<3)/* octree index in block */
37
38 #ifndef MAXOBLK
39 #ifdef SMLMEM
40 #define MAXOBLK 4095 /* maximum octree block */
41 #else
42 #define MAXOBLK 262143 /* maximum octree block */
43 #endif
44 #endif
45
46 extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
47
48 #define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
49
50 /*
51 * The cube structure is used to hold an octree and its cubic
52 * boundaries.
53 */
54
55 typedef struct {
56 FVECT cuorg; /* the cube origin */
57 double cusize; /* the cube size */
58 OCTREE cutree; /* the octree for this cube */
59 } CUBE;
60
61 extern CUBE thescene; /* the main scene */
62
63 /* flags for reading and writing octrees */
64 #define IO_CHECK 0 /* verify file type */
65 #define IO_INFO 01 /* information header */
66 #define IO_SCENE 02 /* objects */
67 #define IO_TREE 04 /* octree */
68 #define IO_FILES 010 /* object file names */
69 #define IO_BOUNDS 020 /* octree boundary */
70 #define IO_ALL (~0) /* everything */
71 /* octree format identifier */
72 #define OCTFMT "Radiance_octree"
73 /* magic number for octree files */
74 #define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
75 #define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
76 /* octree node types */
77 #define OT_EMPTY 0
78 #define OT_FULL 1
79 #define OT_TREE 2
80 /* return values for surface functions */
81 #define O_MISS 0 /* no intersection */
82 #define O_HIT 1 /* intersection */
83 #define O_IN 2 /* cube contained entirely */
84
85
86 extern OCTREE octalloc(void);
87 extern void octfree(OCTREE ot);
88 extern void octdone(void);
89 extern OCTREE combine(OCTREE ot);
90 extern void culocate(CUBE *cu, FVECT pt);
91 extern int incube(CUBE *cu, FVECT pt);
92
93 extern int readoct(char *fname, int load, CUBE *scene, char *ofn[]);
94
95 extern void readscene(FILE *fp, int objsiz);
96 extern void writescene(int firstobj, int nobjs, FILE *fp);
97
98
99 #ifdef __cplusplus
100 }
101 #endif
102 #endif /* _RAD_OCTREE_H_ */
103
