root/radiance/ray/src/common/octree.h
Revision: 2.3
Committed: Wed Dec 3 11:03:51 1997 UTC (27 years, 6 months ago) by gregl
increased table sizes
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * octree.h - header file for routines using octrees.
7 *
8 * 7/28/85
9 */
10
11 /*
12 * An octree is expressed as an integer which is either
13 * an index to eight other nodes, the empty tree, or an index
14 * to a set of objects. If the octree has a value:
15 *
16 * > -1: it is an index to eight other nodes.
17 *
18 * -1: it is empty
19 *
20 * < -1: it is an index to a set of objects
21 */
22
23 #ifndef OCTREE
24 #define OCTREE int
25 #endif
26
27 #define EMPTY (-1)
28
29 #define isempty(ot) ((ot) == EMPTY)
30 #define isfull(ot) ((ot) < EMPTY)
31 #define istree(ot) ((ot) > EMPTY)
32
33 #define oseti(ot) (-(ot)-2) /* object set index */
34 #define octbi(ot) ((ot)>>8) /* octree block index */
35 #define octti(ot) (((ot)&0377)<<3)/* octree index in block */
36
37 #ifndef MAXOBLK
38 #ifdef BIGMEM
39 #define MAXOBLK 65535 /* maximum octree block */
40 #else
41 #define MAXOBLK 8191 /* maximum octree block */
42 #endif
43 #endif
44
45 extern OCTREE *octblock[MAXOBLK]; /* octree blocks */
46
47 #define octkid(ot,br) (octblock[octbi(ot)][octti(ot)+br])
48
49 extern OCTREE octalloc(), combine(), fullnode();
50
51 /*
52 * The cube structure is used to hold an octree and its cubic
53 * boundaries.
54 */
55
56 typedef struct {
57 OCTREE cutree; /* the octree for this cube */
58 FVECT cuorg; /* the cube origin */
59 double cusize; /* the cube size */
60 } CUBE;
61
62 extern CUBE thescene; /* the main scene */
63
64 /* flags for reading and writing octrees */
65 #define IO_CHECK 0 /* verify file type */
66 #define IO_INFO 01 /* information header */
67 #define IO_SCENE 02 /* objects */
68 #define IO_TREE 04 /* octree */
69 #define IO_FILES 010 /* object file names */
70 #define IO_BOUNDS 020 /* octree boundary */
71 #define IO_ALL (~0) /* everything */
72 /* octree format identifier */
73 #define OCTFMT "Radiance_octree"
74 /* magic number for octree files */
75 #define MAXOBJSIZ 8 /* maximum sizeof(OBJECT) */
76 #define OCTMAGIC ( 4 *MAXOBJSIZ+251) /* increment first value */
77 /* octree node types */
78 #define OT_EMPTY 0
79 #define OT_FULL 1
80 #define OT_TREE 2
81 /* return values for surface functions */
82 #define O_MISS 0 /* no intersection */
83 #define O_HIT 1 /* intersection */
84 #define O_IN 2 /* cube contained entirely */
