root/radiance/ray/src/common/octree.c
Sun Nov 1 04:41:55 2009 UTC (14 years, 5 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.7: +13 -23 lines
Deleted unused cucopy() routine
Wed May 23 21:39:38 2007 UTC (16 years, 11 months ago) by greg
Fixed original octree bug that made it take 8 times as much memory as it should
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8
Changes since 2.4: +64 -7 lines
Mon Aug 24 16:38:44 1998 UTC (25 years, 8 months ago) by gwlarson
changed octree block size and increased node limit to 100 million leaves
Mon Aug 24 15:30:11 1998 UTC (25 years, 8 months ago) by gwlarson
fixed potential bug in octdone()
Fri Mar 7 15:45:30 1997 UTC (27 years, 1 month ago) by greg
Changes since 2.1: +13 -0 lines
Diff to previous 2.1
added new set routines
Tue Nov 12 16:55:14 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.3
Mon Sep 17 18:01:03 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.2
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Sat Oct 14 10:56:32 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.1: +5 -3 lines
Diff to previous 1.1
Improved efficiency of combine() by eliminating call to octfree()
Thu Feb 2 10:34:37 1989 UTC (35 years, 3 months ago) by greg
