root/radiance/ray/src/common/octree.c
Revision: 2.7
Committed: Wed May 23 21:39:38 2007 UTC (17 years, 11 months ago) by greg
Fixed original octree bug that made it take 8 times as much memory as it should
2 static const char RCSid[] = "$Id: octree.c,v 2.6 2003/02/25 02:47:21 greg Exp $";
5 * octree.c - routines dealing with octrees and cubes.
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11
12 #include "octree.h"
13
14 OCTREE *octblock[MAXOBLK]; /* our octree */
15 static OCTREE ofreelist = EMPTY; /* freed octree nodes */
16 static OCTREE treetop = 0; /* next free node */
17
18
19 OCTREE
20 octalloc() /* allocate an octree */
21 {
22 register OCTREE freet;
23
24 if ((freet = ofreelist) != EMPTY) {
25 ofreelist = octkid(freet, 0);
26 return(freet);
27 }
28 freet = treetop;
29 if (octti(freet) == 0) {
30 errno = 0;
31 if (octbi(freet) >= MAXOBLK)
32 return(EMPTY);
33 if ((octblock[octbi(freet)] = (OCTREE *)malloc(
34 (unsigned)OCTBLKSIZ*8*sizeof(OCTREE))) == NULL)
35 return(EMPTY);
36 }
37 treetop++;
38 return(freet);
39 }
40
41
42 void
43 octfree(ot) /* free an octree */
44 register OCTREE ot;
45 {
46 register int i;
47
48 if (!istree(ot))
49 return;
50 for (i = 0; i < 8; i++)
51 octfree(octkid(ot, i));
52 octkid(ot, 0) = ofreelist;
53 ofreelist = ot;
54 }
55
56
57 void
58 octdone() /* free EVERYTHING */
59 {
60 register int i;
61
62 for (i = 0; i < MAXOBLK; i++) {
63 if (octblock[i] == NULL)
64 break;
65 free((void *)octblock[i]);
66 octblock[i] = NULL;
67 }
68 ofreelist = EMPTY;
69 treetop = 0;
70 }
71
72
73 OCTREE
74 combine(ot) /* recursively combine nodes */
75 register OCTREE ot;
76 {
77 register int i;
78 register OCTREE ores;
79
80 if (!istree(ot)) /* not a tree */
81 return(ot);
82 ores = octkid(ot, 0) = combine(octkid(ot, 0));
83 for (i = 1; i < 8; i++)
84 if ((octkid(ot, i) = combine(octkid(ot, i))) != ores)
85 ores = ot;
86 if (!istree(ores)) { /* all were identical leaves */
87 octkid(ot, 0) = ofreelist;
88 ofreelist = ot;
89 }
90 return(ores);
91 }
92
93
94 void
95 culocate(cu, pt) /* locate point within cube */
96 register CUBE *cu;
97 register FVECT pt;
98 {
99 register int i;
100 int branch;
101
102 while (istree(cu->cutree)) {
103 cu->cusize *= 0.5;
104 branch = 0;
105 for (i = 0; i < 3; i++)
106 if (cu->cuorg[i] + cu->cusize <= pt[i]) {
107 cu->cuorg[i] += cu->cusize;
108 branch |= 1 << i;
109 }
110 cu->cutree = octkid(cu->cutree, branch);
111 }
112 }
113
114
115 void
116 cucopy(cu1, cu2) /* copy cu2 into cu1 */
117 register CUBE *cu1, *cu2;
118 {
119 cu1->cutree = cu2->cutree;
120 cu1->cusize = cu2->cusize;
121 VCOPY(cu1->cuorg, cu2->cuorg);
122 }
123
124
125 int
126 incube(cu, pt) /* determine if a point is inside a cube */
127 register CUBE *cu;
128 register FVECT pt;
129 {
130 if (cu->cuorg[0] > pt[0] || pt[0] >= cu->cuorg[0] + cu->cusize)
131 return(0);
132 if (cu->cuorg[1] > pt[1] || pt[1] >= cu->cuorg[1] + cu->cusize)
133 return(0);
134 if (cu->cuorg[2] > pt[2] || pt[2] >= cu->cuorg[2] + cu->cusize)
135 return(0);
136 return(1);
137 }
