root/radiance/ray/src/common/octree.c
Revision: 2.2
Committed: Fri Mar 7 15:45:30 1997 UTC (28 years, 3 months ago) by greg
Changes since 2.1: +13 -0 lines
added new set routines
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * octree.c - routines dealing with octrees and cubes.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 OCTREE *octblock[MAXOBLK]; /* our octree */
18 static OCTREE ofreelist = EMPTY; /* freed octree nodes */
19 static OCTREE treetop = 0; /* next free node */
20
21
22 OCTREE
23 octalloc() /* allocate an octree */
24 {
25 register OCTREE freet;
26
27 if ((freet = ofreelist) != EMPTY) {
28 ofreelist = octkid(freet, 0);
29 return(freet);
30 }
31 freet = treetop;
32 if (octti(freet) == 0) {
33 errno = 0;
34 if (octbi(freet) >= MAXOBLK)
35 return(EMPTY);
36 if ((octblock[octbi(freet)] = (OCTREE *)bmalloc(
37 (unsigned)256*8*sizeof(OCTREE))) == NULL)
38 return(EMPTY);
39 }
40 treetop += 8;
41 return(freet);
42 }
43
44
45 octfree(ot) /* free an octree */
46 register OCTREE ot;
47 {
48 register int i;
49
50 if (!istree(ot))
51 return;
52 for (i = 0; i < 8; i++)
53 octfree(octkid(ot, i));
54 octkid(ot, 0) = ofreelist;
55 ofreelist = ot;
56 }
57
58
59 octdone() /* free EVERYTHING */
60 {
61 register int i;
62
63 for (i = 0; i < MAXOBLK; i++) {
64 bfree((char *)octblock[i], (unsigned)256*8*sizeof(OCTREE));
65 octblock[i] = NULL;
66 }
67 ofreelist = EMPTY;
68 treetop = 0;
69 }
70
71
72 OCTREE
73 combine(ot) /* recursively combine nodes */
74 register OCTREE ot;
75 {
76 register int i;
77 register OCTREE ores;
78
79 if (!istree(ot)) /* not a tree */
80 return(ot);
81 ores = octkid(ot, 0) = combine(octkid(ot, 0));
82 for (i = 1; i < 8; i++)
83 if ((octkid(ot, i) = combine(octkid(ot, i))) != ores)
84 ores = ot;
85 if (!istree(ores)) { /* all were identical leaves */
86 octkid(ot, 0) = ofreelist;
87 ofreelist = ot;
88 }
89 return(ores);
90 }
91
92
93 culocate(cu, pt) /* locate point within cube */
94 register CUBE *cu;
95 register FVECT pt;
96 {
97 register int i;
98 int branch;
99
100 while (istree(cu->cutree)) {
101 cu->cusize *= 0.5;
102 branch = 0;
103 for (i = 0; i < 3; i++)
104 if (cu->cuorg[i] + cu->cusize <= pt[i]) {
105 cu->cuorg[i] += cu->cusize;
106 branch |= 1 << i;
107 }
108 cu->cutree = octkid(cu->cutree, branch);
109 }
110 }
111
112
113 cucopy(cu1, cu2) /* copy cu2 into cu1 */
114 register CUBE *cu1, *cu2;
115 {
116 cu1->cutree = cu2->cutree;
117 cu1->cusize = cu2->cusize;
118 VCOPY(cu1->cuorg, cu2->cuorg);
119 }
120
121
122 incube(cu, pt) /* determine if a point is inside a cube */
123 register CUBE *cu;
124 register FVECT pt;
125 {
126 if (cu->cuorg[0] > pt[0] || pt[0] >= cu->cuorg[0] + cu->cusize)
127 return(0);
128 if (cu->cuorg[1] > pt[1] || pt[1] >= cu->cuorg[1] + cu->cusize)
129 return(0);
130 if (cu->cuorg[2] > pt[2] || pt[2] >= cu->cuorg[2] + cu->cusize)
131 return(0);
132 return(1);
133 }
