root/radiance/ray/src/common/octree.c
Sun Nov 1 04:41:55 2009 UTC (15 years, 6 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.7: +13 -23 lines
Deleted unused cucopy() routine
Wed May 23 21:39:38 2007 UTC (17 years, 11 months ago) by greg
Fixed original octree bug that made it take 8 times as much memory as it should
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.4: +64 -7 lines
Mon Aug 24 16:38:44 1998 UTC (26 years, 8 months ago) by gwlarson
changed octree block size and increased node limit to 100 million leaves
Mon Aug 24 15:30:11 1998 UTC (26 years, 8 months ago) by gwlarson
fixed potential bug in octdone()
Fri Mar 7 15:45:30 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.1: +13 -0 lines
added new set routines
Tue Nov 12 16:55:14 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 2.3
Mon Sep 17 18:01:03 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.2 , to selected 2.3
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Sat Oct 14 10:56:32 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.1: +5 -3 lines
Diff to previous 1.1 , to selected 2.3
Improved efficiency of combine() by eliminating call to octfree()
Thu Feb 2 10:34:37 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.3
