root/radiance/ray/src/common/octree.c
Revision: 1.3
Committed: Mon Sep 17 18:01:03 1990 UTC (34 years, 9 months ago) by greg
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * octree.c - routines dealing with octrees and cubes.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 OCTREE *octblock[MAXOBLK]; /* our octree */
18 static OCTREE ofreelist = EMPTY; /* freed octree nodes */
19 static OCTREE treetop = 0; /* next free node */
20
21
22 OCTREE
23 octalloc() /* allocate an octree */
24 {
25 register OCTREE freet;
26
27 if ((freet = ofreelist) != EMPTY) {
28 ofreelist = octkid(freet, 0);
29 return(freet);
30 }
31 freet = treetop;
32 if (octti(freet) == 0) {
33 errno = 0;
34 if (octbi(freet) >= MAXOBLK)
35 return(EMPTY);
36 if ((octblock[octbi(freet)] = (OCTREE *)bmalloc(
37 (unsigned)256*8*sizeof(OCTREE))) == NULL)
38 return(EMPTY);
39 }
40 treetop += 8;
41 return(freet);
42 }
43
44
45 octfree(ot) /* free an octree */
46 register OCTREE ot;
47 {
48 register int i;
49
50 if (!istree(ot))
51 return;
52 for (i = 0; i < 8; i++)
53 octfree(octkid(ot, i));
54 octkid(ot, 0) = ofreelist;
55 ofreelist = ot;
56 }
57
58
59 OCTREE
60 combine(ot) /* recursively combine nodes */
61 register OCTREE ot;
62 {
63 register int i;
64 register OCTREE ores;
65
66 if (!istree(ot)) /* not a tree */
67 return(ot);
68 ores = octkid(ot, 0) = combine(octkid(ot, 0));
69 for (i = 1; i < 8; i++)
70 if ((octkid(ot, i) = combine(octkid(ot, i))) != ores)
71 ores = ot;
72 if (!istree(ores)) { /* all were identical leaves */
73 octkid(ot, 0) = ofreelist;
74 ofreelist = ot;
75 }
76 return(ores);
77 }
78
79
80 culocate(cu, pt) /* locate point within cube */
81 register CUBE *cu;
82 register FVECT pt;
83 {
84 register int i;
85 int branch;
86
87 while (istree(cu->cutree)) {
88 cu->cusize *= 0.5;
89 branch = 0;
90 for (i = 0; i < 3; i++)
91 if (cu->cuorg[i] + cu->cusize <= pt[i]) {
92 cu->cuorg[i] += cu->cusize;
93 branch |= 1 << i;
94 }
95 cu->cutree = octkid(cu->cutree, branch);
96 }
97 }
98
99
100 cucopy(cu1, cu2) /* copy cu2 into cu1 */
101 register CUBE *cu1, *cu2;
102 {
103 cu1->cutree = cu2->cutree;
104 cu1->cusize = cu2->cusize;
105 VCOPY(cu1->cuorg, cu2->cuorg);
106 }
107
108
109 incube(cu, pt) /* determine if a point is inside a cube */
110 register CUBE *cu;
111 register FVECT pt;
112 {
113 if (cu->cuorg[0] > pt[0] || pt[0] >= cu->cuorg[0] + cu->cusize)
114 return(0);
115 if (cu->cuorg[1] > pt[1] || pt[1] >= cu->cuorg[1] + cu->cusize)
116 return(0);
117 if (cu->cuorg[2] > pt[2] || pt[2] >= cu->cuorg[2] + cu->cusize)
118 return(0);
119 return(1);
120 }
