| 1 |
/* RCSid $Id: objutil.h,v 2.3 2020/04/02 22:14:01 greg Exp $ */
| 2 |
| 3 |
* Declarations for .OBJ file utility
| 4 |
| 5 |
* Include after <stdio.h>
| 6 |
| 7 |
* Created by Greg Ward on Wed Feb 11 2004.
| 8 |
| 9 |
| 10 |
#ifndef _OBJUTIL_H_
| 11 |
#define _OBJUTIL_H_
| 12 |
| 13 |
#ifndef DUP_CHECK_REVERSE
| 14 |
#define DUP_CHECK_REVERSE 1 /* eliminate flipped duplicates */
| 15 |
#endif
| 16 |
#ifndef POPEN_SUPPORT
| 17 |
#define POPEN_SUPPORT 1 /* support "!command" i/o */
| 18 |
#endif
| 19 |
/* face flags */
| 20 |
#define FACE_SELECTED 01
| 21 |
#define FACE_DEGENERATE 02
| 22 |
#define FACE_DUPLICATE 04
| 23 |
| 24 |
struct Face; /* forward declaration */
| 25 |
| 26 |
typedef struct {
| 27 |
int vid; /* vertex id */
| 28 |
int tid; /* texture id */
| 29 |
int nid; /* normal id */
| 30 |
struct Face *fnext; /* next in vertex face list */
| 31 |
} VertEnt;
| 32 |
| 33 |
/* Structure to hold face and its vertex references */
| 34 |
typedef struct Face {
| 35 |
struct Face *next; /* next face in main list */
| 36 |
short flags; /* face selected, etc */
| 37 |
short nv; /* number of vertices */
| 38 |
short grp; /* group/object index */
| 39 |
short mat; /* material index */
| 40 |
/* in cases where the same vertex appears twice, first has link */
| 41 |
VertEnt v[3]; /* vertex list (extends struct) */
| 42 |
} Face;
| 43 |
| 44 |
/* Structure to hold vertex */
| 45 |
typedef struct {
| 46 |
double p[3]; /* 3-D position */
| 47 |
Face *vflist; /* linked face list (no repeats) */
| 48 |
} Vertex;
| 49 |
| 50 |
/* Structure to hold texture coordinate */
| 51 |
typedef struct {
| 52 |
float u, v; /* 2-D local texture coordinate */
| 53 |
} TexCoord;
| 54 |
| 55 |
/* Array to hold surface normal */
| 56 |
typedef float Normal[3];
| 57 |
| 58 |
/* Structure to hold a loaded .OBJ file */
| 59 |
typedef struct {
| 60 |
char **descr; /* descriptive comments */
| 61 |
int ndescr; /* number of comments */
| 62 |
char **grpname; /* object/group name list */
| 63 |
int ngrps; /* number of group names */
| 64 |
int lastgrp; /* last group seen */
| 65 |
char **matname; /* material name list */
| 66 |
int nmats; /* number of materials */
| 67 |
int lastmat; /* last material seen */
| 68 |
Vertex *vert; /* vertex array */
| 69 |
int nverts; /* number of vertices */
| 70 |
TexCoord *tex; /* texture coordinate array */
| 71 |
int ntex; /* number of texture coord's */
| 72 |
Normal *norm; /* surface normal array */
| 73 |
int nnorms; /* number of surface normals */
| 74 |
Face *flist; /* linked face list */
| 75 |
int nfaces; /* count of faces */
| 76 |
} Scene;
| 77 |
| 78 |
#ifdef __cplusplus
| 79 |
extern "C" {
| 80 |
#endif
| 81 |
| 82 |
/* Allocate a new scene holder */
| 83 |
Scene * newScene(void);
| 84 |
| 85 |
/* Add a .OBJ file to a scene */
| 86 |
Scene * loadOBJ(Scene *sc, const char *fspec);
| 87 |
| 88 |
/* Duplicate a scene */
| 89 |
Scene * dupScene(const Scene *sc);
| 90 |
| 91 |
/* Transform entire scene */
| 92 |
int xfScene(Scene *sc, int xac, char *xav[]);
| 93 |
int xfmScene(Scene *sc, const char *xfm);
| 94 |
| 95 |
/* Add a descriptive comment */
| 96 |
void addComment(Scene *sc, const char *comment);
| 97 |
| 98 |
/* Clear comments */
| 99 |
void clearComments(Scene *sc);
| 100 |
| 101 |
/* Write a .OBJ file, return # faces written or -1 on error */
| 102 |
int toOBJ(Scene *sc, FILE *fp);
| 103 |
int writeOBJ(Scene *sc, const char *fspec);
| 104 |
| 105 |
/* Convert indicated faces to Radiance, return # written or -1 on error */
| 106 |
int toRadiance(Scene *sc, FILE *fp, int flreq, int flexc);
| 107 |
int writeRadiance(Scene *sc, const char *fspec,
| 108 |
| 109 |
| 110 |
/* Compute face area (and normal) */
| 111 |
double faceArea(const Scene *sc, const Face *f, Normal nrm);
| 112 |
| 113 |
/* Eliminate duplicate vertices, return # joined */
| 114 |
int coalesceVertices(Scene *sc, double eps);
| 115 |
| 116 |
/* Identify duplicate faces */
| 117 |
int findDuplicateFaces(Scene *sc);
| 118 |
| 119 |
/* Delete indicated faces, return # deleted */
| 120 |
int deleteFaces(Scene *sc, int flreq, int flexc);
| 121 |
| 122 |
/* Clear face selection */
| 123 |
void clearSelection(Scene *sc, int set);
| 124 |
| 125 |
/* Invert face selection */
| 126 |
void invertSelection(Scene *sc);
| 127 |
| 128 |
/* Count number of faces selected */
| 129 |
int numberSelected(Scene *sc);
| 130 |
| 131 |
/* Select faces by object name (modifies current) */
| 132 |
void selectGroup(Scene *sc, const char *gname, int invert);
| 133 |
| 134 |
/* Select faces by material name (modifies current) */
| 135 |
void selectMaterial(Scene *sc, const char *mname, int invert);
| 136 |
| 137 |
/* Execute callback on indicated faces */
| 138 |
int foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void *),
| 139 |
int flreq, int flexc, void *c_data);
| 140 |
| 141 |
/* Remove texture coordinates from the indicated faces */
| 142 |
int removeTexture(Scene *sc, int flreq, int flexc);
| 143 |
| 144 |
/* Remove surface normals from the indicated faces */
| 145 |
int removeNormals(Scene *sc, int flreq, int flexc);
| 146 |
| 147 |
/* Change group for the indicated faces */
| 148 |
int changeGroup(Scene *sc, const char *gname,
| 149 |
| 150 |
| 151 |
/* Change material for the indicated faces */
| 152 |
int changeMaterial(Scene *sc, const char *mname,
| 153 |
| 154 |
| 155 |
/* Free a scene */
| 156 |
void freeScene(Scene *sc);
| 157 |
| 158 |
/* Find an existing name in a list of names */
| 159 |
int findName(const char *nm, const char **nmlist, int n);
| 160 |
| 161 |
/* Verbose mode global */
| 162 |
extern int verbose;
| 163 |
| 164 |
extern char *emalloc(unsigned int n);
| 165 |
extern char *ecalloc(unsigned int ne, unsigned int n);
| 166 |
extern char *erealloc(char *cp, unsigned int n);
| 167 |
extern void efree(char *cp);
| 168 |
| 169 |
#define CHUNKSIZ 128 /* object allocation chunk size */
| 170 |
| 171 |
#define chunk_alloc(typ, arr, nold) \
| 172 |
((nold)%CHUNKSIZ ? (arr) : \
| 173 |
(typ *)erealloc((char *)(arr), sizeof(typ)*((nold)+CHUNKSIZ)))
| 174 |
| 175 |
#ifdef __cplusplus
| 176 |
| 177 |
#endif
| 178 |
| 179 |
#endif /* ! _OBJUTIL_H_ */
